2019 zr8000 rr secondary question - HCS Snowmobile Forums
Like Tree3Likes
Old 02-14-2020, 07:17 PM   #1 (permalink)
blindsquirrell's Avatar
Current Sled(s): 2019 8000rr 137
Previous Sled(s): 12 Turbo, 07 F1000, 03 F7, 95 ZRT800, 94 T-Cat, 90 WC650
Favorite Riding Area: Pittsburg, NH
19-20 Mileage:
18-19 Mileage: 1340
17-18 Mileage: 700
16-17 Mileage: 650
Riding Since: 1975
Default 2019 zr8000 rr secondary question
At the risk of asking a dumb question I have a couple. I was going through my sled today and decided to pull the secondary and clean and scotch brite pad both clutches and wash the belt. Well when I took the secondary off it was separated. I am not familiar with the team clutches so is this normal and should the two sheaves be aligned in some way when I put them back on the sled. Is there something broken here? I attached a couple pictures for reference. I am lost on this one.
ID:	2074898   Click image for larger version
blindsquirrell is offline   Reply With Quote
Old 02-14-2020, 07:49 PM   #2 (permalink)
Current Sled(s): 2018 ZR 6000 ES, 2020 ZR 6000 Limited iACT
Favorite Riding Area: Pinehurst area
Did the same thing. Each part is balanced so you do not need perfect alignment, but if you look at the inner half, you should see a slight mark where the belt removal tool rubbed. Align it to the bottom of that line with the adjuster hole. Dont do what I did and over tightened the bolt holding the clutch on and snapped the bolt. 60 ft. Lbs is what you need.
stronger800 likes this.
jim_ramstad@yahoo.com is online now   Reply With Quote
Old 02-14-2020, 08:05 PM   #3 (permalink)
derrek's Avatar
Current Sled(s): 18 El Tigre 8000,02 Zrxf 800 EFI,87 Jag,04 F7
Previous Sled(s): 75 John Deere JDX 8,99 ZL600 EFI,16 ZR6000
Favorite Riding Area: ditches in nw minnesota
19-20 Mileage: 2000
18-19 Mileage: 1000
17-18 Mileage: 500
16-17 Mileage: 1000
Riding Since: 1987
tighten the driven clutch bolt with the belt off the sled
Join a club and help keep our sport ALIVE!!!
A Sled is only as safe as the operator!!!!!
derrek is offline   Reply With Quote
Old 02-14-2020, 08:44 PM   #4 (permalink)
I dont think you could even get it together with the belt on.
Old 02-14-2020, 09:29 PM   #5 (permalink)
Current Sled(s): "Agri-vator"
.....sure some guys could.
Old 02-15-2020, 09:39 AM   #6 (permalink)
KLYMAXR's Avatar
Current Sled(s): ZR8000 Riot/ RS 6000
Previous Sled(s): PSI Genisis 1220 thunder cat, 1080 Genisis ZR900, 2 riots
Favorite Riding Area: northern ontario/quebec
19-20 Mileage:
18-19 Mileage: 4500
17-18 Mileage: 4487
16-17 Mileage: 2000
Riding Since: 70,s
Ps....and on another important note....do not try and open sheaves with belt tool if you have just reversed!!! Make sure you pull forward with sled first or you will snap tool or strip hole.
wanablaze likes this.
KLYMAXR is offline   Reply With Quote
