Low RPM run quality of 2020 800 C-Tec - HCS Snowmobile Forums
Like Tree22Likes
Old 02-01-2020, 09:43 AM   #1 (permalink)
oldcrow's Avatar
Current Sled(s): 2020 ZR 8000 RR 137
Previous Sled(s): 2018 ZR 8000 RR 137 2014 ZR 6000 RR 129
Favorite Riding Area: Northern MN
Default Low RPM run quality of 2020 800 C-Tec
Since new felt the sled ran a little rough at lower rpm's (below 6000)
Going by sound it was hard to notice but you could feel the difference.
If idling around at a steady throttle, when the sled hit 6000 it would noticeably increase in speed and rpms.
Sled ran good throughout the rpm range, just hard to hold consistently in that 6000 rpm range
Now have over 1000 miles on the sled and low rpm run quality seem to be getting worse.
The engine now sounds rough at lower rpm's and when coasting to a stop you can actually feel the sled chug
When out on the trail the sled runs good
Anyone else notice the same?
Ski-Doo rider famous quotes:
"Why don't we slow the F??? down and get there 5 minutes later?"
"You got to stop every once in awhile and let everyone catch the F??? up"
"I didn't want to break my drive chain"
"It's the best sled I ever had" 15 miles later "The chain case blew up"
"I can't go over 60mph, my EGT's get too hot"
"Sold"
oldcrow is offline   Reply With Quote
Old 02-01-2020, 10:19 AM   #2 (permalink)
skidooboy's Avatar
6000 is when the power valves open fully, you may want to check your cables for adjustment spec. the spec is 36.5mm +or- .5mm
Ski
"you are only as smart as your right thumb"
skidooboy is offline   Reply With Quote
Old 02-01-2020, 11:10 AM   #3 (permalink)
Let it Snow!'s Avatar
Current Sled(s): '16 ZR6 El Tigre, '90 Jag 340
Previous Sled(s): '02 ZL 600, '91 Indy 500
Favorite Riding Area: Wherever I am.
19-20 Mileage: 985
18-19 Mileage: 2005
17-18 Mileage: 1100
16-17 Mileage: 300
Riding Since: 1996
I've only managed about 350 miles but mines the same as yours. Very stumbly down low but good over 6k rpm.
^^^^ says valves are open at 6k but I thought its 7k, I dont see this as a power valve issue.
I will likely go the aftermarket flash route once the season is over to clean it up all around.
Sent from my SM-G965W using Tapatalk
Let it Snow! is online now   Reply With Quote
Old 02-01-2020, 02:28 PM   #4 (permalink)
catdog800's Avatar
Current Sled(s): 19 ZR 8000 LTD
Previous Sled(s): 15 ZR 4000 72 PUMA
Favorite Riding Area: Whiteshell
19-20 Mileage:
18-19 Mileage: 2200
17-18 Mileage: 2000
16-17 Mileage: 1000
Riding Since: 1972
Might be loading up, fouling plugs, clears out at higher RPM. Try the EIX models of BR 9 series, as they harder to foul. Valves open at 7ish RPM
catdog800 is offline   Reply With Quote
Old 02-02-2020, 07:40 AM   #5 (permalink)
kevin's Avatar
Current Sled(s): 2016 High Country 6000
Previous Sled(s): 1971 Moto Ski Mini Sno
Favorite Riding Area: U.P. Forest Roads
Riding Since: 1979
Agree with the low rpm issue. I have a Riot 800 that rumbles in that 4600-4900 range so it’s happening every time I let off the throttle coming into corners, etc and results in an exhaust drone type sound
dskofich likes this.
kevin is offline   Reply With Quote
Old 02-02-2020, 08:42 AM   #6 (permalink)
oldcrow's Avatar
I agree, power valves open around 6900 rpm
I'm thinking this is just a first year tune issue and given a little time they will get it cleaned up.
Oil consumptions seems a little high.
They low oil light will start to flicker around 250 miles which is about 2 quarts.
My 18 800 was better than this and I could go 500 miles on my 14 600 before the low oil light would flicker
Riding at an aggressive/smart trail pace we can easily go around 130 miles on a tank of fuel before fuel light starts to flicker which takes about 9-10 gallons to fill
"Sold"
Old 02-02-2020, 12:12 PM   #7 (permalink)
Newbie
Hillbillyjoe's Avatar
Current Sled(s): 2017 Polaris Switchback 800 Pro S
Mine also runs rough around 5K RPM. It started to break up at higher RPMs but found my throttle switch wasn’t quite working properly. I applied a small amount of lube to the throttle and now just the low end glitch is present again. Hopefully Cat will get us an update on the fuel map to clean it up. Guess they will leave it up to the consumer or aftermarket to straighten out the clutching. Anyone tried a kit they really like to pull down rpms and speed up back shift.
Hillbillyjoe is offline   Reply With Quote
Old 02-02-2020, 12:46 PM   #8 (permalink)
favoritos's Avatar
Current Sled(s): 2019 RR 800 137"
Previous Sled(s): F8 EXT, Lots of Crossfires and ProCross
19-20 Mileage:
18-19 Mileage: What?
17-18 Mileage: 3500
I'll add a quick cut and paste I've noticed about the sound and oil consumption.
I keep a running review going on the comparison between machines.
"2. Sound and feel. The changes are subtle. Some riders may not notice. The 2020 has a low speed growl. Some is related to the clutching. It also has a different tone/feel, that you notice on the low end up through upper mid range. It is kinda like the old big bore twins. There is more feeling the motor working when it pulls hard.
3. Fuel and oil. Can't figure this one out. (Maybe this machine is an oddball.) The '20 started out using less fuel than all the other sleds. The fuel consumption has leveled off and is very close to stock 18 machine. Oil usage was obviously high during break in hours. It still uses a lot of oil in comparison. The 2020 oil light comes on about 30-40 miles before the 18 with hard riding. I honestly thought the sensor might be wrong and verified the oil levels. This '20 just uses more."
I have not figured out exactly what is causing the difference in sound. I can verify that it does use considerably more oil.
I'm still learning.
favoritos is online now   Reply With Quote
Old 02-02-2020, 02:09 PM   #9 (permalink)
Procross225's Avatar
Current Sled(s): '18 el tigre 8k 129, '17 XF 8k CC LTD
Previous Sled(s): Lots of Cats
Favorite Riding Area: Northern Minnesota
19-20 Mileage: .5
18-19 Mileage: 550
17-18 Mileage: 715
16-17 Mileage: 500
Riding Since: 1993
My 18 runs messed up too. Doesnt idle very well, has a delay in the throttle from a roll. Hopefully its just a idle air control thats not functioning correctly.
Procross225 is online now   Reply With Quote
Old 02-02-2020, 04:01 PM   #10 (permalink)
F7RAT's Avatar
Current Sled(s): 18XC 16ZR-T 16ZR 15XC 15RR 14RR 12ZR 10SP
Previous Sled(s): Not Enough Room!
Favorite Riding Area: Out my home & Northern Mn/Wi
19-20 Mileage:
18-19 Mileage: 3244
17-18 Mileage: 2780
16-17 Mileage: 1630
Riding Since: 1976
Can someone confirm if the low end issues still exist with the Precision flash ?
I have heard that it has gained some low end crispness with the flash.
Member MnUSA
Active member and Trail Coordinator North Branch Snow Drifters
F7RAT is offline   Reply With Quote
