LED Headlights with E-Start - HCS Snowmobile Forums
Old 01-21-2020, 12:08 AM   #1 (permalink)
tbss1121's Avatar
Current Sled(s): 2014 XF 8000 High Country Limited
Previous Sled(s): '13 XF 800 HC, '12 XF 800 HC, '10 M8 SP, '08 F6 SP, etc
Favorite Riding Area: Cottonwood Pass
19-20 Mileage:
18-19 Mileage: N/A
Riding Since: 1989
Default LED Headlights with E-Start
Hi all - been scouring the internet for an answer to this question but all of the LED threads I have read are not clear on this, to run LEDs on a 2014 with E-Start do I need rectifiers?
Thanks in advance.
tbss1121 is offline   Reply With Quote
Old 01-21-2020, 07:17 AM   #2 (permalink)
I believe it depends on the motor. A 600 does not need them, as I do not have them for my 2016 600. I believe the 800 does need them. @Tommcat can answer for sure
SteveCZ is offline   Reply With Quote
Old 01-21-2020, 09:20 AM   #3 (permalink)
KLYMAXR's Avatar
Current Sled(s): ZR8000 Riot/ RS 6000
Previous Sled(s): PSI Genisis 1220 thunder cat, 1080 Genisis ZR900, 2 riots
Favorite Riding Area: northern ontario/quebec
19-20 Mileage:
18-19 Mileage: 4500
17-18 Mileage: 4487
16-17 Mileage: 2000
Riding Since: 70,s
YES you need rectifier, only buy the cyclopes lights as they are made with rectifier in line.
CIL-LED-10.0H4-Ultra-REC Cyclops 10.0 H4 LED headlight bulb
Upgrade To Ultra 10.0: Upgrade To Ultra 10.0 $10.00
Add a rectifier for AC powered applications (dirtbikes and some scooters): Add plug and play rectifier, bulb will stay on high beam $19.95 $109.90 x 2
KLYMAXR is online now   Reply With Quote
Old 01-21-2020, 09:33 AM   #4 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): too many
Favorite Riding Area: Maine
Riding Since: 1977
Thanks in advance.
the early Ctec 600 had a built in AC/DC converter and does not need rectifiers. SOME 800s had the converter from the factory and some people installed it themselves, so the best bet is to use your DVOM and check for 12v DC at the headlight connector.
if you have DC, no rectifier needed. If it's AC power, then you need rectifiers.
Old 01-21-2020, 10:12 AM   #5 (permalink)
KLYMAXR's Avatar
19-20 Mileage:
18-19 Mileage: 4500
17-18 Mileage: 4487
16-17 Mileage: 2000
Riding Since: 70,s
the 2014's had ac at lights.
