XF 1100 turbo ecu 15 code - HCS Snowmobile Forums
Old 01-20-2020, 09:50 PM   #1 (permalink)
Newbie
Dirtrat's Avatar
Default XF 1100 turbo ecu 15 code
I know this has probably been discussed a million times but the search function on this forum isn't working out well for me... so here it is.
I have a 2012 1100 turbo with ecu 15 code coming up after longer periods of higher rpm riding. The old o2 sensor had broken wires right ar the base of the sensor so I replaced thinking that would fix the issue right away. It did not. Same issue is happening with new sensor. (Also backfiring occasionally) I have read that an exhaust leak is common cause of this as well. I have inspected most of the exhaust that I can get to without tearing everything apart and haven't seen any cracks yet.
My question is, what do you all think is the most common point of exhaust leaks on this sled? (Exhaust manifold gasket, turbo exhaust gasket, cracked pipe etc.) I would like to get some kind of idea before I order parts.
Or do you think it is more likely a wiring issue? I wish I could just read these things like I can vehicles with obd2... I would be able to see exactly what is going on from live data.
Let me know what you all think. Thanks!
Sent from my SM-G965U using Tapatalk
Dirtrat is offline   Reply With Quote
