2020 Clutching Question Adjustable Weights - Page 4 - HCS Snowmobile Forums
Like Tree15Likes
Old 01-20-2020, 12:16 PM   #31 (permalink)
Current Sled(s): 18 Eltigre 8000
19-20 Mileage:
18-19 Mileage: 1200
Originally Posted by Fun11cat View Post
Thanks KLYMAXR for the information. I do run the Cat belts maybe I will get the ultimax belt, what belt number would you recommend.
Snow is loose now so I think I will keep the settings for now. Sled does pull hard out of the hole when I did find hard pack. Haven't found an area long enough to get top end.
Sled is fun to ride.
XS828 will drop your RPM's 200-300 and you will need to start all over with your clutching. Much softer belt.
F8HO is offline   Reply With Quote
Old 01-20-2020, 12:19 PM   #32 (permalink)
Fun11cat's Avatar
Current Sled(s): 2020 ZR 8000 LTD IACT
Previous Sled(s): 14 XF 7000 10 F8 SP,05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera
Favorite Riding Area: Central MN
19-20 Mileage: 1425
18-19 Mileage: 1170
17-18 Mileage: 1260
16-17 Mileage: 960
Riding Since: 1972
Originally Posted by Greg B. View Post
Try a 221 as well and see which one works better
Thanks Greg, I did try 2-2-1 and was still overrevving. At 3-2-1 sled doesn't overrev it will creep up to 8200.
As you can tell I'm not a clutch tuner guy so I appreciate everyone's input.
Fun11cat is offline   Reply With Quote
Old 01-20-2020, 12:26 PM   #33 (permalink)
Fun11cat's Avatar
19-20 Mileage: 1425
18-19 Mileage: 1170
17-18 Mileage: 1260
16-17 Mileage: 960
Riding Since: 1972
Thanks for the info.
I will stay with the Cat for now heading out Wednesday with a group so I don't want to be messing with the clutches on a trip.
Old 01-20-2020, 02:42 PM   #34 (permalink)
KLYMAXR's Avatar
Current Sled(s): ZR8000 Riot/ RS 6000
Previous Sled(s): PSI Genisis 1220 thunder cat, 1080 Genisis ZR900, 2 riots
Favorite Riding Area: northern ontario/quebec
19-20 Mileage:
18-19 Mileage: 4500
17-18 Mileage: 4487
16-17 Mileage: 2000
Riding Since: 70,s
The cat belts will always send you looking because they are temp sensitive, put the XS belt in there and set to come out at 7900 and let run out the back at 8150. it will stay the same every pass.
KLYMAXR is offline   Reply With Quote
Old 01-21-2020, 11:54 AM   #35 (permalink)
wwr
wwr's Avatar
Current Sled(s): 2020 Riot, 2020 Backcountry, 2017 XF 9000
Previous Sled(s): 2020 Riot, 2020 Backcountry, 2017 XF 9000
Favorite Riding Area: Northern Saskatchewan
19-20 Mileage:
18-19 Mileage: 2000
17-18 Mileage: 2100
16-17 Mileage: 1400
Riding Since: 1974
Just a couple things here of note. The J14-74 cat weights actually weigh at about 75 grams. They are fairly heavy biased to tip weight when you look at them compared to the Dalton's which are much more heel heavy prior to adding set screws. Part number for spring I am using is 0646-474
wwr is offline   Reply With Quote
Old 01-21-2020, 12:44 PM   #36 (permalink)
Let it Snow!'s Avatar
Current Sled(s): '16 ZR6 El Tigre, '90 Jag 340
Previous Sled(s): '02 ZL 600, '91 Indy 500
Favorite Riding Area: Wherever I am.
19-20 Mileage: 985
18-19 Mileage: 2005
17-18 Mileage: 1100
16-17 Mileage: 300
Riding Since: 1996
Originally Posted by Rod Johnson View Post
I will for sure.
Update?
Let it Snow! is online now   Reply With Quote
Old 01-22-2020, 04:56 PM   #37 (permalink)
KLYMAXR's Avatar
19-20 Mileage:
18-19 Mileage: 4500
17-18 Mileage: 4487
16-17 Mileage: 2000
Riding Since: 70,s
Fun, you are doing better than you think. your bang on with the weight. can you putanother weight in heal? if not leave it there... you should hammer out og hole to 7900 and creep to 8150...8200 out the back inLONG run is good cusz then your running on rpm. but wait till you get an xs belt.
Old 01-25-2020, 04:28 PM   #38 (permalink)
Fun11cat's Avatar
19-20 Mileage: 1425
18-19 Mileage: 1170
17-18 Mileage: 1260
16-17 Mileage: 960
Riding Since: 1972
Thanks for the information.
I ran 3-2-2 ran great on hard pack still haven't had a hard pack area long enough to hold open to top sled out, have hit 94 mph with this setup. Out of the hole hits 7800,7900 then creeps up to 8000 and then gradually gets to 8100 with Cat belt.
Raced a new 850 Ski Doo on semi hard pack (Cat 137 no studs, Doo 129 Ice Ripper) both sleds leaving exactly at the same time our skis where within 3" of each other and both where at the same height as far as ski lift we where dead even up to 80 MPH then the Doo barely started to pull away, then we ran out of lake (small lake). I know once he started pulling away there was no way I was going to catch him.
I was happy with the 155hp Cat keeping up with the 850 Doo.
Old 01-25-2020, 04:35 PM   #39 (permalink)
19-20 Mileage: 985
18-19 Mileage: 2005
17-18 Mileage: 1100
16-17 Mileage: 300
Riding Since: 1996
I've hit 100mph with everything stock. Waaaaay over reving, hits 8400 and settles at 8300.
Sent from my SM-G965W using Tapatalk
Old 01-25-2020, 04:47 PM   #40 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): too many
Favorite Riding Area: Maine
Riding Since: 1977
Time for a tune and some weights
Sent from my SM-J737V using Tapatalk
