Picked up our Limiteds / Trailer Tire Question - HCS Snowmobile Forums
Like Tree8Likes
Old 10-09-2019, 03:58 PM   #1 (permalink)
Current Sled(s): 2016 El Tigre' 8000, 2 2016 6000 LXR's
Previous Sled(s): 08 & 12 F8, Prowler, EXT, 3 ZRT's, Firecat, CFR 800 HO
Favorite Riding Area: Northern Wisconsin
Riding Since: 1975
Default Picked up our Limiteds / Trailer Tire Question
My Brother and I picked up our 2020 Limiteds last weekend and man do they look sweet in person! The only thing I didnt like was the small bag that comes on it so we had the dealer swap them out for mid-sized bags. He also threw in a free tool kit since it didnt come with one.
Trailer Tire Question - When we got back we noticed one of the trailer tires on my Triton 2 place enclosed was wearing really funny on the outside of the tire. (see pictures) There is proper air pressure in them and I always grease my bearings once a year. Any idea what would cause the tire to wear like that? The other one looks totally fine.
Name:	2020 Limiteds.jpg
ID:	2059452   Click image for larger version
Name:	Trailer Tire 1.jpg
ID:	2059454   Click image for larger version
Name:	Trailer Tire 2.jpg
Bulldog is offline   Reply With Quote
Old 10-09-2019, 04:15 PM   #2 (permalink)
3wheelerdude's Avatar
Current Sled(s): 2019 Voyageur 600 - Ovt 340 - XLV 540 - Zr200
Previous Sled(s): - 97 Vmax, 07 Phazer, '16 Bearcat
Riding Since: 1997
Any play in the wheel bearing?
Or possibly a bent axle....
3wheelerdude is offline   Reply With Quote
Old 10-09-2019, 04:56 PM   #3 (permalink)
Riding Since: 1975
I dont know how the axle would have got bent. Gonna have to jack it up and check the wheel bearing. Could the tire just be dry rotted or bad? It did sit for a few years in a shed without being used until last winter when I borrowed it to my brother in law and then this trip up to Hazelhurst, WI and back from Madison, WI.
Old 10-09-2019, 05:07 PM   #4 (permalink)
gwilburn's Avatar
Current Sled(s): 2017 XF CC 8000 & 2017 ZR 6000 137 LTD
Previous Sled(s): 12 F8, 08 F8, 06 CF6, 03 F7
Favorite Riding Area: Ontario & da UP
19-20 Mileage:
18-19 Mileage: 2785
17-18 Mileage: 1100
16-17 Mileage: 1415
Riding Since: 1972
Jack it up... I'll bet money your torsion band broke (inside the axle). This happened to me on my 4-place Triton (it's a 2001 so....)
You can also check the alignment of the axle... see if it moved. Measure from a point on the tongue to each hub. They should be the same.
Meanwhile... you could "store" those sleds in my garage
p51mstg likes this.
gwilburn is offline   Reply With Quote
Old 10-09-2019, 05:15 PM   #5 (permalink)
nosajlleb's Avatar
Current Sled(s): Cataha 998T Cross Country
Previous Sled(s): 14 Proclimb12 M1100T 153,97 zrt600, 01 mc600, 07 xfire1000sp
Favorite Riding Area: U.P.
19-20 Mileage:
18-19 Mileage: 2000
17-18 Mileage: 1200
16-17 Mileage: 2000+
Riding Since: 1981
Why does one sled have the front shock turned out (normal) and the other facing in. Seems like that'd be a bitch to adjust.
nosajlleb is offline   Reply With Quote
Old 10-09-2019, 05:19 PM   #6 (permalink)
drako1's Avatar
Current Sled(s): 14 XF8000 LMTD
Previous Sled(s): 05 F7,01 ZR8,98 ZR6XC,94 ZR7,91 EXT SP,90 650 WILDCAT
Favorite Riding Area: Off trail
Riding Since: 75
One has IACT.
drako1 is offline   Reply With Quote
Old 10-09-2019, 05:20 PM   #7 (permalink)
Let it Snow!'s Avatar
Current Sled(s): '16 ZR6 El Tigre, '90 Jag 340
Previous Sled(s): '02 ZL 600, '91 Indy 500
Favorite Riding Area: Wherever I am.
19-20 Mileage:
18-19 Mileage: 2005
17-18 Mileage: 1100
16-17 Mileage: 300
Riding Since: 1996
one has iact and the other doesn't
edit: drako beat me to it
nosajlleb likes this.
Let it Snow! is offline   Reply With Quote
Old 10-09-2019, 05:41 PM   #8 (permalink)
snowcrazy1's Avatar
Current Sled(s): 2016 ZR 6000 LTD
Previous Sled(s): 98 srx700
Favorite Riding Area: lost pines lodge
my tritons . i have 2 both do the same after many miles i turn them around on the rim on the older one that stays in the area and wear em right down the other that rolls back and forth to chitown gets new tires often . just my way of use . never slow on hiway . if ya were real crafty you could bend your axle to adjust the tire to ground contact pattern to match the crown on the roads ya travel on mostly i'm not that picky . one is a 2003 the other a new 2015 both do same crap after lot's of hi speed trailer runs worse unloaded than loaded they are so light
snowcrazy1 is offline   Reply With Quote
Old 10-09-2019, 06:01 PM   #9 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
19-20 Mileage:
18-19 Mileage: 450
17-18 Mileage: 1100
16-17 Mileage: 750
Age: mr
Riding Since: 1977
yes tires can go bad, they have dates on them for a reason
NEXT, I will guess bearinsg are BAd or need adjusting
OR a few other things like
could be axle slide back, the normally have a little wiggle room to adjust for straightness!
your heavier sled rides on one side of trailer more often?
trailer BENT
axle bents?
or just BAD tires out of round or balance
as these small tires cannot be balanced, as they center on lugs , there not like car and truck tires! that can be balanced!
I replace mine ever 5 yrs MAX
after that there ticking time bombs IMO
get lucky or NOT,
and down time and changing tires on side of roads SUCK!
mrbb is offline   Reply With Quote
Old 10-09-2019, 06:02 PM   #10 (permalink)
Current Sled(s): 2012 XF 1100 RETRO + 2019 ZR7000-PURPLE
Previous Sled(s): Many Many KITTYS
Favorite Riding Area: northern wis.-da UP.-On SNOW
19-20 Mileage:
18-19 Mileage: 2000
17-18 Mileage: 1200
16-17 Mileage: 600
Riding Since: 70s
Balance those tires and you wont have that problem
70GMCTRUCKS is offline   Reply With Quote
