2012 F800 Sno Pro leaking oil - HCS Snowmobile Forums
Like Tree1Likes
  • 1 Post By bowanna03
Old 09-05-2019, 11:31 AM   #1 (permalink)
Member
Default 2012 F800 Sno Pro leaking oil
Please see the attached pictures. I purchased this sled and haven't even used it yet and noticed the other day that it is leaking oil from the bottom of the sled and it looks like a decent amount and consistent. I am going to purchase a service manual but was wondering if anyone has had the same issue and if they know what could be causing it or needs to be repaired
ID:	2056842   Click image for larger version
bowanna03 is offline   Reply With Quote
Old 09-05-2019, 12:33 PM   #2 (permalink)
Procross225's Avatar
Previous Sled(s): Lots of Cats
Favorite Riding Area: Northern Minnesota
19-20 Mileage:
18-19 Mileage: 550
17-18 Mileage: 715
16-17 Mileage: 500
Riding Since: 1993
Looks like your airbox is filling with oil from the reed lines. Odd the oil is red. If it was coming from chaincase area id expect it to be wet in that area but its not.
Try cleaning up a good portion, loosen oil cap and see if it stops. Your cap may not be venting and its forcing built up pressure through the pump to the reed housings and filling up your air box
Procross225 is online now   Reply With Quote
Old 09-05-2019, 02:15 PM   #3 (permalink)
Member
Thank you!!!
Old 09-06-2019, 12:30 AM   #4 (permalink)
Current Sled(s): "Agri-vator"
What he said. Pretty common, and not an issue. (As long as your cap is venting. If it doesn't rattle when you rattle it, replace it). Looks like your hood was On in those pics. Remove it and look in the air box, you'll likely see a red puddle. We have learned not to store the sled's with the oil tanks very full, as that adds to expansion and pressure that pushes on the checkvvalves
Old 09-06-2019, 08:20 AM   #5 (permalink)
Member
Thank you for your help with this! Much appreciated
Old 09-06-2019, 12:00 PM   #6 (permalink)
SShooterZ's Avatar
Current Sled(s): 2017 ZR8000 SP
Previous Sled(s): 2003 Z440 SP | 2002 ZR600 | 2000 ZR600 | 1996 580EXT EFI
Originally Posted by Procross225 View Post
Odd the oil is red.
Could be Ski Doo XPS. It looks a lot like it.
SShooterZ is offline   Reply With Quote
Old 09-06-2019, 12:17 PM   #7 (permalink)
The Meat Man
Badger's Avatar
Current Sled(s): MY19 850 Doo mXz TnT
Previous Sled(s): Black MY15 ProS 800 SB ANV
Favorite Riding Area: Summit Lake WI
Riding Since: 1776
Check you oil cap I had a bad one and in the summer the sled would leak oil all over the place. it's a long shot but it happen on my 2003.
"The Meat Man"
Sent from my HP Media Center Via RoadRunner...so bite me.
Badger is offline   Reply With Quote
Old 09-06-2019, 02:46 PM   #8 (permalink)
Member
I took the oil cap off and shook it and I could hear a rattle. I loosened it and put it back on. I also cleaned the bottom off and after two days there is nothing showing leaking yet
SShooterZ likes this.
