HCS Snowmobile Forums
HCS Snowmobile Forums (https://www.hardcoresledder.com/forums/)
-   ProCross (2012 - ) (https://www.hardcoresledder.com/forums/493-procross-2012/)
-   -   2020 front end (https://www.hardcoresledder.com/forums/493-procross-2012/1854768-2020-front-end.html)
Greg B. 03-17-2019 02:52 AM
117 Attachment(s)
Anyone know what was the actual changes? I am thinking about bolting one on my 19 if it is possible.
blindsquirrell 03-17-2019 07:30 AM
I am curious as well. When I looked at them at the Snowdeo it looks like it’s just the spindle and upper a-frame. What I don’t know is if there are different mounting points.
12meter joe 03-17-2019 10:30 AM
I bet the mounting points have not changed and it’s a direct bolt up. It would put a lot of weight to the back by raising it so some adjustments would need to be made in the back but that’s easy.
I’m sure you probably watched this
https://youtu.be/u0EXFsKJVtA
favoritos 03-17-2019 11:38 AM
I wonder if it requires a different length shock? The lower mount point is significantly higher.
I can see how the handling can change quite a bit with the new geometry. That is a bigger factor than the clearance.
Flowdaddy 03-17-2019 12:08 PM
Might have to give it a shot on my XC for a summer project.
taperk600 03-17-2019 12:21 PM
From what I've been able to find out, the only changes are the new upper A arm and the taller forged spindles. The rest stayed the same....including the mounting locations.
I can see where the extra length below the lower arm would help in giving the front end more bite. It's adding more ski pressure without having to adjust anything else (limiter straps, etc).
Zambroski 03-17-2019 12:23 PM
I'm just curious as to why you'd want to make this update? :dunno:
Greg B. 03-17-2019 01:55 PM
I'm just curious as to why you'd want to make this update? <img src="https://www.hardcoresledder.com/forums/images/smilies/dunno.gif" border="0" alt="" title=":dunno:" class="inlineimg" />
Cheap mod to have a 2020
I may have to go for it. Did the shock lengths stay the same?
Zambroski 03-17-2019 02:00 PM
Yeah...cheap and easy I guess. I just wonder what the real gains may be. I guess I'd prolly rather dump that money into some revalving or something other in the handling area.
