need advice on missing studs - HCS Snowmobile Forums
Like Tree3Likes
Old 10-11-2018, 07:45 PM   #1 (permalink)
Default need advice on missing studs
I have about 10-15 missing studs on my track after inspection from last season and I am looking for advice on which route I should take to remedy this situation. It appears where the studs came out it is not ripped very bad at all, like a hole with a very slight slit in it. The sled is a 2013 F800 SnoPro LTD.
Should I:
Remove all the studs and replace them with brand new studs? (I feel as if the reason for losing them is incorrect installation by previous owner)
Or completely remove studs altogether and run no studs at all? Would this be okay on the track? (I have ran no studs in the past, and while I prefer some studs I am not completely ruling this option out. I understand traction will be lost on lakes)
njrumbo is offline   Reply With Quote
Old 10-11-2018, 08:36 PM   #2 (permalink)
fourh-ds's Avatar
Current Sled(s): 00 XCR 800, 04 XC 800
Riding Since: 1988
A few pics might help, but if the hole is torn you will probably not get a stud to stay put for very long. Do you spin a lot in low snow conditions? Rocks and stumps will tear up a studded track that is spinning.
Are the missing studs scattered over the entire track or in a concentrated area? If they're scattered somewhat even you might be able to run it for a while longer. Removing the studs will probably give you the longest track life at this point.
fourh-ds is offline   Reply With Quote
Old 10-11-2018, 09:21 PM   #3 (permalink)
Current Sled(s): r and a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
Riding Since: 1988
Should I:
If the stud came out you canít fix it. You would have to replace the track
snowcrazy1 likes this.
Greg B. is offline   Reply With Quote
Old 10-11-2018, 09:43 PM   #4 (permalink)
simba's Avatar
Current Sled(s): 2013 F1100 turbo
Previous Sled(s): 04 f7 efi snopro 04 f7 efi std 03 z570(wifes) 97 ext 600
I have a track that is studded, make me an offer probably studded to heavy for an 800 but you can always remove some
simba is offline   Reply With Quote
Old 10-11-2018, 10:49 PM   #5 (permalink)
snowcrazy1's Avatar
Current Sled(s): 2016 ZR 6000 LTD
Previous Sled(s): 98 srx700
Favorite Riding Area: lost pines lodge
dont blow the sled up playing with track rip outs, when you stud you have to be careful where and when you mat it or this will be a every season thing , i have learned that the hard way
snowcrazy1 is offline   Reply With Quote
Old 10-12-2018, 08:45 AM   #6 (permalink)
Below is a picture for reference. I figured it probably wouldn't be a good idea to put new studs back in a hole that ripped out. At this point I feel as if simply removing all the studs would be my best option, given the amount/location that are ripped out. (and the likelyhood that more come out)
https://imgur.com/RONuLOe
Old 10-12-2018, 10:19 AM   #7 (permalink)
Yamaha-40th's Avatar
Current Sled(s): 2018 Arctic Cat Turbo RR
Previous Sled(s): 2013 Turbo RR 2008 Apex GT
Favorite Riding Area: Saint Germain
19-20 Mileage:
18-19 Mileage: 2500
17-18 Mileage: 1000
16-17 Mileage: 2000
Riding Since: 2006
It needs a new track .
Is it snowing yet??????
Yamaha-40th is offline   Reply With Quote
Old 10-12-2018, 10:44 AM   #8 (permalink)
Seems a bit excessive the track only has 1,800 miles on it.
Old 10-15-2018, 10:32 AM   #9 (permalink)
19-20 Mileage:
18-19 Mileage: 2500
17-18 Mileage: 1000
16-17 Mileage: 2000
Riding Since: 2006
It's not the millage it's the "extra" holes in it from the studs pulling out.
I have seen a track come apart while the sled was being driven it's not pretty .
Old 10-15-2018, 07:38 PM   #10 (permalink)
NDN
NDN's Avatar
Current Sled(s): 2019 XC 850 Indy & CAT 2016 800 HC
Favorite Riding Area: U.P. MICH
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 1200
16-17 Mileage: 1800
Ever heard of a "BEAR CLAW"? Like mentioned, not pretty.
Also check around to see there is no damage to any heat exchangers.
NDN is online now   Reply With Quote
Similar Threads
Interesting article on Studs MCXcat7000 Turbo 4 Stroke 0 01-03-2018 12:12 PM
Missing studs, small tears in track a major issue, should I put new ones in? Alahsuxnuts General Snowmobile Forum 13 11-13-2017 05:51 PM
