Cracked chain case cover on Wifes 2014 ZR 7K LTD - HCS Snowmobile Forums
Like Tree2Likes
  • 1 Post By Greg B.
  • 1 Post By Rubrsidedown
Old 06-19-2018, 09:32 PM   #1 (permalink)
Rubrsidedown's Avatar
Current Sled(s): 17 XFXC 9k LTD and a 14 ZR 7k LTD
Previous Sled(s): Many (all Cats)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
Default Cracked chain case cover on Wifes 2014 ZR 7K LTD
2014 ZR 7000 Ltd
Chain case cover issue.
Cracked cover. (two of the ears broke off)
Need new one (chaincase cover) as there isn't a fix for it.
Replace only.
Also, What is the possible cause of this wear in the bottom of the cover itself? ( inside wear)
Final issue...
Late Last season the speedometer wasn't working properly. It was bit or miss.
Figured it was a bad Speedo sensor.
Friggen thing pops right out of position.
Time for some lovin I guess.
ID:	2017322   Click image for larger version
ID:	2017324   Click image for larger version
ID:	2017326   Click image for larger version
Jeff B In Maine
Rubrsidedown is offline   Reply With Quote
Old 06-19-2018, 09:57 PM   #2 (permalink)
jjlrrw's Avatar
Current Sled(s): '16 High Country
Favorite Riding Area: UP / near Irons
Push on your dealer you have some time, my bubby has a '14 I was at the dealer and told them he has a broken ear on his cover, they told me to have him bring it in and they would take care of it. The Cover is like $175
Bring up the fact the part number changed because of this issue
Cover, Chain Case (inc. 42-47)
was 1702-368 is 1702-495
jjlrrw is offline   Reply With Quote
Old 06-19-2018, 10:06 PM   #3 (permalink)
snowcrazy1's Avatar
Current Sled(s): 2016 ZR 6000 LTD
Previous Sled(s): 98 srx700
Favorite Riding Area: lost pines lodge
there were many broke/cracked right from factory those 13/14's as far as wear could your bearings be going bad ? never took a driveshaft out of procross sled do they have set screws to hold shaft ?
snowcrazy1 is offline   Reply With Quote
Old 06-19-2018, 11:06 PM   #4 (permalink)
Current Sled(s): "Agri-vator"
I'd loosen the track, unbolt the caliper, pull lower gear off, and stare at the bearings while wiggling the shaft. Although that little wear mark is not entirely uncommon, and it could be just fine and never wear any more than that anyway. New cover might not even make contact.
Old 06-19-2018, 11:24 PM   #5 (permalink)
Current Sled(s): r and a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
Riding Since: 1988
How many miles? Me experience with the 7000 once the shafts get a bit of wear the reverse will bind up and not work right. That reverse chain case is complete nightmare of an engineering job.
snowcrazy1 likes this.
Greg B. is offline   Reply With Quote
Old 06-20-2018, 06:26 AM   #6 (permalink)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
It has approx 5500 miles on it.
Jeff B In Maine
Old 06-20-2018, 06:27 AM   #7 (permalink)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
I will certainly speak with my dealer.
I don't have high hopes but it's worth a shot.
Pricy chaincase cover that's for sure.
Jeff B In Maine
Old 06-20-2018, 10:08 AM   #8 (permalink)
jjlrrw's Avatar
Is this the first time you removed the CC? I think the only way to crack the ears would be installing.
Old 06-20-2018, 10:21 AM   #9 (permalink)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
Yes it is.
All original
Sent from my LGUS991 using Tapatalk
Jeff B In Maine
Old 06-21-2018, 10:38 PM   #10 (permalink)
snappydave's Avatar
Current Sled(s): '15 ZR9000LTD and '15 XF9000LTD
Previous Sled(s): '07 F1000S/P,'07 Z1
Favorite Riding Area: HoughtonLake,Caddy, Raco,Seney
19-20 Mileage:
18-19 Mileage: 1200
17-18 Mileage: 800
16-17 Mileage: 350
Riding Since: 1968
My '15 XF9000 LTD had the rear cover tab busted off just like yours,, you could see the o-ring . That was at 1300 miles. Was having a Hyvo gear/chain installed and that's when it was noticed.
"He who dies with the most toys,,still dies."
snappydave is offline   Reply With Quote
