Fusion 600 jetting and carb adjustment - HCS Snowmobile Forums
Old 12-28-2019, 10:55 PM   #1 (permalink)
Default Fusion 600 jetting and carb adjustment
I picked up 2 Fusion 600s this fall and finally got a chance to get them ready for winter. While cleaning the carbs I found that 1 has 420 mains and the fuel screw is 1.5 out, while the other has 400 mains and the fuel screw is 2.5 out. I do most of my riding between 1000' & 2000' at -10F to 30F. These will be ridden by my boys, so I plan on running them as they came to see which (if either) is better. I can have them switch to get multiple opinions. I've read that taking mains down 1 size from Polaris factory is usually a good rule of thumb, but 2? Does anybody know where I can find a chart detailing elevation/temperature to jet size? Does anybody have general input on this topic based on personal knowledge?
Thanks in advance,
E
Sent from my Pixel 2 XL using Tapatalk
BigE is offline   Reply With Quote
Old 01-13-2020, 04:18 PM   #2 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
Manyu big threads on this back in the day.
One of the larger and later threads was this one:
https://www.hardcoresledder.com/foru...o-stumble.html
BTW, I don't know what happened to the long list of stickies (and one's that worked) that used to be at the top of this 600HO forum. Oh well.
PPP Charter Member #2
Old 01-13-2020, 05:13 PM   #3 (permalink)
drewma's Avatar
Current Sled(s): Polaris 2006 600 Fusion Dragon
Previous Sled(s): 74 and counting
Location: NW suburb of water crisis USA...cottage in Boyne City
Favorite Riding Area: Elmira, Michigan
19-20 Mileage: 1
18-19 Mileage: 900
17-18 Mileage: 404
16-17 Mileage: 900
Riding Since: 1970
Thanks in advance,
E
This is a picture of notes I have on my iPhone 4...yes I have graduated from that phone model😂
Anyway, I think the 420 main is a little on conservative side. I am at sea level.
Unfortunately, I have SLP on one sled, Bikeman on the other and stock on one also. The PAJ, starter jet, air jet and amount of turns should work on all to cure your low end stumble. The main is your call based on altitude and brand of exhaust you have.
A Hardcore guy named Mudripper used to run 390 on his...I have never went below 400. All Fusion 600s on my notes. Sorry twisted pic. Will try to post picture right way up in next post.
drewma is offline   Reply With Quote
Old 01-13-2020, 05:18 PM   #4 (permalink)
drewma's Avatar
19-20 Mileage: 1
18-19 Mileage: 900
17-18 Mileage: 404
16-17 Mileage: 900
Riding Since: 1970
Twisted pic for you
Note, fuel screw was closed from stock and tuned out 1.5 turns. Fuel screw was supposedly turned out 2 full turns from closed when set at factory. Hope this helps
Old 02-06-2020, 04:41 PM   #5 (permalink)
2TurnsAndGone's Avatar
Current Sled(s): 2015 Rush Pro-S 800 HO
Previous Sled(s): Fusion 600HO, Arctic cats
390 mains. Bigger PAJs, play with the screws, but memory tells me somewhere around 1.5 turns. Bump timing 2 degrees, switch to 22/40 gears, slp pipe/can, slp aribox mod, add 2 grams to clutch weight... beat up on 800s of the day, all day long. Put 5000 miles on this setup before selling it. What an awesome sled it was. Literally would destroy my buddies on their f8s.
Also get some spindles from an '09 I think, makes steering effort so much easier.
2TurnsAndGone is offline   Reply With Quote
Old 02-06-2020, 05:01 PM   #6 (permalink)
Brand loyal, not brand blind
racerdave's Avatar
Current Sled(s): 2020 AXYS Indy XC850 137 2015 Indy 600sp
Previous Sled(s): 2015 AXYS SWB800 Pro S
Favorite Riding Area: Vilas Co. Wisconsin
19-20 Mileage:
18-19 Mileage: 1900
17-18 Mileage: 1,500
16-17 Mileage: 1,000
Riding Since: 1975
Best of my memory. 2 degree timing bump for sure, Actual best mod for the Fuse 6. 400 main with Holtzman Tempa flow. Gutted air box SLP air horn. V Force. BMP pipe mod, BMP head mod. 64 weights I think, Searching my memory for springs and helix. Ran this on my first new Fuse6 in 2006-2007, and my second used Fuse6 from 2010 to 2015.
First charter member of the PPP.
Member of:
Illinois Valley Winter Sports Club, Marseilles ,Il.
Sayner Barnstormers, Sayner, Wi.
racerdave is offline   Reply With Quote
Old 02-06-2020, 05:56 PM   #7 (permalink)
Administrator
sayatodaU.P.eh?'s Avatar
Current Sled(s): 2015 RMK 800
Previous Sled(s): 600 H.O. Fusion
These are my plugs after a good rip. 400 mains, 47.5 pilots, stock needle jet and needle position. 93 E10 premium fuel. Sled has a BMP modded pipe, SLP air box and silencer. Stock timing. At this time I cant pull a 66/44-.46 helix, in a TSS04 clutch with all other clutching stock other than two delrin washers under the spring cup. Ignition timing is wherever the factory set it. Engine mechanicals all check out. 22:40 gearing.
Sled is a pooch with this setup. It barley pulls 8100 out of the hole, pulls back to 7800 and struggles to get past that. From a roll, its a flat pig. Struggles to get past 7700. Never had this issue until after I put the TSS04 clutch on it. The sled is getting some miles on it too but I dont think the engine is weak yet.
Went up to 440 mains, stock 50 pilots and Im going to try the stock TSS98 secondary back on it.
Ive always run .8 PAJs and 1.25 turns on the fuel screws.
sayatodaU.P.eh? is offline   Reply With Quote
