0627-047 Belt Options? - Page 2 - HCS Snowmobile Forums
Sno Pro Chassis Pre-2012 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
Old 02-14-2020, 12:34 PM   #11 (permalink)
Current Sled(s): SP500, SKS, Polaris 340 & 700 Classic
[QUOTE=Crnr2Crnr;20388970]Thanks for the feedback Bang. Get some miles on this year?
Zero miles so far but we're heading north tonight and the trails in our area are finally open so we'll get a few in.
The shocks I got from you last year are working nice BTW. Although I'm still undecided about the lower rate front ski spring. It definitely sits lower and helps with cornering but they bottom a lot easier on bigger hits. I may switch back.
The rears are great except I bumped the fitting loose on the remote reservoir and it leaked a bit. I suppose there was nitrogen in there? Anyway, I'll ship them off to Hygear in the summer.
Bang! is offline   Reply With Quote
Old 02-14-2020, 12:52 PM   #12 (permalink)
Crnr2Crnr's Avatar
Current Sled(s): Green one's with Suzuki engines
Previous Sled(s): Green, Blue & Yellow
Favorite Riding Area: Wouldn't you like to know?
Riding Since: 70's
The shocks I got from you last year are working nice BTW. Although I'm still undecided about the lower rate front ski spring. It definitely sits lower and helps with corning but they bottom a lot easier on bigger hits. I may switch back.
Good to hear on the shocks. I've run the green front springs and Carver shocks valved specifically for them on my stock sled for two seasons now (couple thousand miles) and I prefer them on chatter, cornering and for general riding but our trails are generally groomed very well locally so there's not a lot of mogul mashing to deal with. I am also still using the sway bar. Can't say that I've ever bottomed them that I recall, but if I get time today I'll check the measured/installed height they are set at currently and edit this post.
Have fun riding!
edit: I have the green springs set at 11-3/4" as installed height.
the greatest post in HCS history
Crnr2Crnr is offline   Reply With Quote
Old 02-14-2020, 01:03 PM   #13 (permalink)
Fast 440's Avatar
Dayco
XTX5056
XTX5038
XTX5024
XTX5034 longer and wider than stock.
Gates
43G4289
49C4266
Not sure on those new Gboost belts. Might look into that too.
I run the original -066 belt on my 600, but that was a 1 year deal. I have a quite a few of them so i will keep running them. After that, probably try that XTX5034.
2008 SnoPro
Fast 440 is offline   Reply With Quote
Old 02-14-2020, 01:10 PM   #14 (permalink)
Crnr2Crnr's Avatar
Riding Since: 70's
Originally Posted by Fast 440 View Post
Dayco XTX5034 longer and wider than stock.
what would be the advantage of the longer/wider belt?
Old 02-14-2020, 01:13 PM   #15 (permalink)
Fast 440's Avatar
I dont exactly know how it works, but when the R-XC went to the idler bearing primary, they went to a longer and wider belt. It seemed to really help those. I figured it would help any sled? Maybe i am wrong.
2008 SnoPro
Old 02-14-2020, 03:11 PM   #16 (permalink)
Crnr2Crnr's Avatar
Riding Since: 70's
idk either?
no belt deflection adjustment on the secondary?
https://www.snowest.com/forum/thread...clutch.430898/
Old 02-14-2020, 04:21 PM   #17 (permalink)
mnstang's Avatar
Current Sled(s): 8000 high country, SnoPro 500, zr900
Previous Sled(s): many cats
Favorite Riding Area: Northern MN
I think the 066 is what came on my z1 turbo and those were upgraded to the 073 which was supposed to be better and more durable.
Originally Posted by Crnr2Crnr View Post
idk either?
Not on sleds with the bearing primary. The secondary closes as tight as it can. This keeps the belt tight for a better smoother take off with a slightly lower gear ratio too. I think all 18+ sleds got the bearing in the primary it's a good idea.
mnstang is offline   Reply With Quote
Old 02-14-2020, 06:02 PM   #18 (permalink)
Crnr2Crnr's Avatar
Riding Since: 70's
I forgot about that innovation. While riding Greg's RR the engagement seemed low and buttery smooth, the polar opposite of our S/P's which bang into engagement. Would assume your High Country is the same.
Old 02-14-2020, 08:46 PM   #19 (permalink)
Current Sled(s): r and a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
Riding Since: 1988
For performance the 047 is only good for about 300 before it goes to shit for up shift. The 076 will last 3 times that. I am talking actual performance not how long before the fails. I blew a 47 around 1500. The 76 I ran for a lot more miles with out an issue
Greg B. is offline   Reply With Quote
Old 02-15-2020, 02:10 AM   #20 (permalink)
mnstang's Avatar
Probably more so because of the lower gearing. That primary really is nice when off trail putsing through tight trails and brushy areas like I did alot of today. Very controllable.
Maybe I'll try the 076 next in 500. Greg do you know if clutching will need to be changed for that belt compared to the 047?
