2011 XC/SX Handlebar difference? - HCS Snowmobile Forums
Sno Pro Chassis Pre-2012 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By mnstang
Old 11-14-2018, 08:31 PM   #1 (permalink)
Crnr2Crnr's Avatar
Current Sled(s): 2010 Sno Pro 500 & 2010 Sno Pro 500???
Previous Sled(s): ZR580EFI, SRV, Safari 377, Citation SS & Bogie Wheeled Sleds
Favorite Riding Area: twisty windy wooded bliss
19-20 Mileage:
18-19 Mileage: 1600ish
17-18 Mileage: 1501.5
16-17 Mileage: -18
Riding Since: 1977
Default 2011 XC/SX Handlebar difference?
What changed in 2011 that the XC model has a different handlebar? If you look it up it as described as 'Handlebar, Heavy Duty - Assembly (inc. [+]
1705-042 & 1705-155'
and is green.
https://www.babbittsonline.com/oempa...lebar-assembly
The 500 has different bars 1705-092, curious what the actual difference in the bars might be if any other than color. Riser block is/are the same part # - thicker wall tubing?
The original part # was 0705-978 and fit (but was replaced by the new #'s)
Assemblies where 0705-978 is used
2004 440 SNO PRO (S2004F4BPRUSG) - Handlebar Assembly
2005 AC 440 SNO PRO GREEN (S2005ACBPRUSG) - Handlebar Assembly
2005 AC SNO PRO MOD GREEN (S2005ACAMOUSG) - Handlebar Assembly
2006 AC 440 SNO PRO GREEN (S2006ACBPRUSG) - Handlebar Assembly
2006 AC 440 SNO PRO GREEN MODIFIED RACE SLED (S2006ACDMOUSG) - Handlebar Assembly
2007 AC 600 MODIFIED SNO PRO GREEN (S2007ACDMOUSG) - Handlebar Assembly
2008 AC 600 SNO PRO BLACK (S2008ACDPRUSB) - Handlebar Assembly
2009 600 SNO PRO GREEN (S2009ACDPRUSG) - Handlebar Assembly
2010 600 SNO PRO CROSS COUNTRY GREEN (S2010ACDCCUSG) - Handlebar Assembly
2010 600 SNO PRO GREEN (S2010ACDPRUSG) - Handlebar Assembly
2011 ARCTIC CAT SNO PRO 600 CROSS COUNTRY GREEN (S2011ACDCCUSG) - Handlebar Assembly
2011 ARCTIC CAT SNO PRO 600 GREEN (S2011ACDPRUSG) - Handlebar Assembly
Yes, I am this weird.
Crnr2Crnr is offline   Reply With Quote
Old 11-14-2018, 10:53 PM   #2 (permalink)
Fast 440's Avatar
1705-155 is more than likely just a thicker tube. The 500 and 600 bars were different due to the throttle block being an efi sled and the aluminum throttle block of the carb 600. They likely are the part number of the bar assembly and not the actual bar itself.
2008 SnoPro
Fast 440 is offline   Reply With Quote
Old 11-15-2018, 12:12 AM   #3 (permalink)
Crnr2Crnr's Avatar
19-20 Mileage:
16-17 Mileage: -18
Riding Since: 1977
well, here's a 1705-042 bar with just grips
https://www.countrycat.com/arctic-ca...ks-sp-assy-grn
the way they are described in the fiche as heavy duty makes me want to believe they are a thicker wall tubing. highly doubt I'd ever bend or break the stock bars, but I do like the look of the green bars.
google found it
https://www.google.com/url?sa=t&rct=...u9xRWGeCVh-P82
Old 12-16-2018, 02:05 AM   #4 (permalink)
Current Sled(s): r and a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
Riding Since: 1988
Put a set of fly racebend bars on it. They are thicker than the stock ones and the bend is better than stock. Cheap upgrade
Greg B. is offline   Reply With Quote
Old 12-16-2018, 10:36 PM   #5 (permalink)
Crnr2Crnr's Avatar
19-20 Mileage:
16-17 Mileage: -18
Riding Since: 1977
will look into those when the grip heaters need to be replaced.
Old 12-17-2018, 12:41 AM   #6 (permalink)
mnstang's Avatar
Current Sled(s): 8000 high country, SnoPro 500, zr900
Previous Sled(s): many cats
Favorite Riding Area: Northern MN
When you do, go with the rsi heaters, they're hotter
Crnr2Crnr likes this.
mnstang is offline   Reply With Quote
Similar Threads
ISO rear arm to tunnel bracket, F series, Procross tallcool 1 Arctic Cat Wanted 1 03-09-2018 07:28 PM
2009 800 rmk engine in 2011 assault 800 mountain-assault7 Switchback Assault/RMK (Pro-Ride Chassis) 3 02-16-2017 10:27 AM
