Start Switch Issues - HCS Snowmobile Forums
XP/XR/XS New Style MXZ This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-13-2019, 03:39 PM   #1 (permalink)
Member
Snowmobaron's Avatar
Default Start Switch Issues
Looking to see if anyone else has had a similar issue using the E start for Ski-Doo. I have a 2011 Backcountry and the start button doesn't work all the time. Seems if you play with the wires from the assembly behind the housing the button will work and she will fire right up. Previous owner replaced the relay but it still has the issue. The sled seems to go into reverse just fine though. I'm under the impression the button needs to be replaced.
Any input would be greatly appreciated. Thanks!
Snowmobaron is offline   Reply With Quote
Old 10-13-2019, 04:47 PM   #2 (permalink)
JHELREY's Avatar
Current Sled(s): 2015 XRS 800
19-20 Mileage:
18-19 Mileage: 1050
Replace the 5amp fuse before you go crazy with anything else. Even if it looks okay!
JHELREY is offline   Reply With Quote
Old 10-15-2019, 09:10 PM   #3 (permalink)
Zert6's Avatar
Current Sled(s): Ski Doo Grand Touring le & GSX se
Previous Sled(s): Cats
Riding Since: 1974
I had the same issue with my 12 GSX. I found the micro switch was poorly designed and moves around a lot on its mounting pin. I glued it in place ,and have been testing it all summer with 100 % success. Hope this helps
Zert6 is offline   Reply With Quote
Old 10-16-2019, 09:42 AM   #4 (permalink)
jethroxlt's Avatar
Current Sled(s): 2019 Ski Doo Renegade 900T Enduro
Previous Sled(s): Yamaha, Cat, Polaris
Favorite Riding Area: Allagash
19-20 Mileage:
18-19 Mileage: 950
I had a buddy that had major issues on his '12 Freeride. He ended up installing an aftermarket switch.
jethroxlt is offline   Reply With Quote
Old 12-09-2019, 10:39 AM   #5 (permalink)
Member
So update on the repair. Tested the switch and it checks out fine. Charged the battery and also cleaned a couple of ground connections that had some corrosion. Now it seems a lot better to start however every once in a while I’ll have to press and hold the button then it will start. Any ideas?
