14 mxz800xrs etec Cranks but doesn’t start. Please Help - HCS Snowmobile Forums
XP/XR/XS New Style MXZ This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 06-15-2019, 07:54 PM   #1 (permalink)
Newbie
Dfree's Avatar
Default 14 mxz800xrs etec Cranks but doesn’t start. Please Help
Hello! New to the forum! Looking for advice. My 14 mxz800xrs etec Cranks but won’t start. Usually when cranking with the electric start the cluster and headlights flicker then it starts. Worked fine when I put it away in my temp controlled garage In February, just tried starting to to move it and it cranks fine but no cluster or headlight flicker and no start. Checked the two fuses above battery, reseated cluster connector, removed secondary cover and looked in for chewed wires, all looks good. Any ideas where to go from here? Thanks so much!
Dfree is offline   Reply With Quote
Old 06-16-2019, 09:16 AM   #2 (permalink)
northstarrick's Avatar
make sure your battery is fully charged and in good condition. e-tec's won't start if voltage is below 10 vdc. ecu shuts everything down to protect it'self. these D.I. sleds use a lot of juice when running. when starting the sled the starter is using power. so it here if below 10 volts it won't start. if that's o.k. then it could be a bad capacitor or even a bad stator?
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
