Dead as a rock... - HCS Snowmobile Forums
FST/4 stroke This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree3Likes
Old 04-14-2019, 01:12 PM   #1 (permalink)
Current Sled(s): 2015 Ski-Doo Renegade X 800 ETEC
Previous Sled(s): 2000 Polaris 700 SKS, 2010 Polaris IQ Turbo Dragon
Favorite Riding Area: Turtle Flambeau Flowage
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
Default Dead as a rock...
So a few weeks back we head up for our last sled trip of the year. When we left the last trip, the reverse on my 2010 fst dragon wasn't working (wouldn't engage, but could hear it spinning i'm pretty sure) but it was starting and running just fine. Parked it, threw the cover on it and left. We get there, uncover it, turn the key AND: nothing. Zero signs of life. I figured maybe a ground was corroded or loose, or the wire under the seat rubbed through and was grounding out. Neither was the case. The starter solenoid was pretty corroded so I bought a new one and installed that. Nothing, even with a jump, so clearly the circuit is dead whether it's due to something grounding out or a bad relay. So that leaves me with the five relays, right? Start solenoid, chassis, efi, ignition relay, and the one over by the exhaust. One had a bit of corrosion on it (by exhaust), cleaned that, nothing. All the others look fine. I've heard condensation can build up inside and corrode what you can't see however.
Guess i'm just throwing this out there to ask if anyone thinks it is just relays, and if you need every relay to work in order for the sled to do anything? I mean this thing does nothing. No ecu, gauges, lights, start, click, whine, anything. We parked it running, and came back to that. If you have any other experiences please shoot some suggestions my way or im probably just gonna start buying relays.
Thanks y'all
2015 Ski-Doo Renegade X 800R ETEC
IH8Summer is offline   Reply With Quote
Old 04-14-2019, 08:58 PM   #2 (permalink)
Current Sled(s): '11 IQ Turbo, '15 Axys 800, '19 850 XC
Previous Sled(s): '12 Pro-R 8, '08 IQ 8, '02 Pro-X
Favorite Riding Area: Where the snow is....
19-20 Mileage:
18-19 Mileage: 5060
17-18 Mileage: 5100
16-17 Mileage: 2050
Riding Since: 1976
Have you checked all the fuses to be sure something isn't blown? The ECU on those controls everything. If that doesn't have power, the sled would be completely dead. Didn't have a mouse get into something? Have an FST manual? It covers all the circuits in pretty good detail.
orville-x is offline   Reply With Quote
Old 04-14-2019, 11:02 PM   #3 (permalink)
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
I checked everything in the fuse/relay panel above the clutches and all other relays I could see. Don't have a manual, just going by sight. Maybe it's possible a mouse got into something, but it was still pretty cold out when this happened and it was only sitting for a week. I'll have to take out the fine toothed comb and look through to find every fuse I can. Off the top of my head though, I can't think of anything other than the fuse box and the stray relay near the exhaust.
Old 04-15-2019, 07:45 AM   #4 (permalink)
patrioticinnovations's Avatar
Previous Sled(s): 2003 XCR 1100, 2000 XCR 800 turbo, 2005 Redline Revolt 800.
19-20 Mileage: 715 so far
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
Should be a simple step by step analysis.
1. Battery charged up?
2. Ignition switch getting 12V?
3. Ignition switch sending 12V?
4. Lights working?
5. Kill switch not pushed down?
If these all check out, then use a test light to trace 12V to each component.
Frozenstiff likes this.
Old 04-15-2019, 11:35 PM   #5 (permalink)
19-20 Mileage:
18-19 Mileage: 5060
17-18 Mileage: 5100
16-17 Mileage: 2050
Riding Since: 1976
Even with the kill switch pushed down, the MFD should still turn on when you attempt to crank the sled over. I agree with the suggestion to check over the ignition switch and those connections as a starting point. Note also that there are fusible links in the electrical system as well as fuses, so keep an eye for those also.
Old 04-18-2019, 07:58 PM   #6 (permalink)
Current Sled(s): 2013 Ski Doo 1200 & 2006 FST Classic
Previous Sled(s): 2003 Polaris 700 Classic
Favorite Riding Area: WI Northwoods
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
Try switching your EFI relay with one of the other one and see if the sled powers up, pretty sure it will start without a chassis relay so maybe try switching those.
2006 FST Classic with 180 degree thermostat, notched drive shaft shield, re-routed/shielded wiring harness, block heater installed on bottom of engine, adjusted gas tank float, oil pressure light, Autometer boost gauge, Camoplast Ice Attack track, Snobeelers shock recalibration, cyclone hose re-routed to exhaust, 24-44 gears, YaYou's Stage 2 re-flash, helix and alternator pulley.
dofo1 is offline   Reply With Quote
Old 05-10-2019, 02:30 PM   #7 (permalink)
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
So ive been tracing current. Key switch good, current through three relay plug ins (not the relays, but the female terminals in the fuse box themselves) start solenoid, chassis, efi relay. But when i get to ignition relay i dont get current, my light doesnt light up even with key turned to start position. That normal? Doesn’t seem like it to me.
Old 05-11-2019, 07:46 AM   #8 (permalink)
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
I'd trace that 12V feed wire backwards to where it gets power. It may come from one of the other relays.
You also need to determine whether each relay is getting activated and is delivering 12V out.
Relays are activated by an internal coil that must
be grounded as well as sent 12V power from somewhere.
You can test relays using jumper wires to activate them and feed 12V to their inputs so you can see the test light illuminate at the output terminal.
You really need a wiring diagram to make tracing easier.
dskofich likes this.
Old 07-08-2019, 05:42 PM   #9 (permalink)
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
Just a quick update, haven't been able to spend much time on it. Fusible links I checked, all are good. The only things I haven't checked is that the relays themselves are all functioning, and I haven't traced the ignition relay wiring to see why it isn't getting 12V when I turn the key. I examined all of the wiring down the by ecu, grounds, connections, looked for any rubbed spots or fraying and there was nothing.
One question I have is do ECU's fail? Is that a possibility/anybody have that happen? I have a spare ECU I'm tempted to throw in just to check.
I also don't have a wiring diagram, which makes things a bit more difficult.
Old 07-08-2019, 05:57 PM   #10 (permalink)
Current Sled(s): '17 XCR 800;'15 Pro S; 2011 Doo Grand Touring
Previous Sled(s): '12 Turbo IQ; '06 FST classic; '97 ski doo 500 deluxe
Favorite Riding Area: Da U.P., Conover WI
19-20 Mileage:
18-19 Mileage: 2500
16-17 Mileage: 1000
Riding Since: 2009
its been a few years since I worked on my FSTs (I had 2 of them in the past). I do remember them having wire chaffing issues up where the harness passes by the handlebar neck or post, next to the top cowling cover.
Dirty70Bird is offline   Reply With Quote
Similar Threads
Hurricane at race on the rock hurricaneperformance Turbo 4 Stroke 3 04-14-2018 11:09 PM
Not starting dead after boosting Bskilliter2017! IQ chassis 0 12-15-2017 10:43 AM
Rock music you just can't gut? dodger General Discussion Forum 53 12-31-2016 11:30 AM
South Bend Service - Don Rock 3illmesmart General Snowmobile Forum 1 08-10-2016 03:28 PM
Rangeley Rock Maple & Pro Vintage Race jonny dw Maine 2 03-15-2016 02:24 PM
