Dead as a rock... - Page 3 - HCS Snowmobile Forums
FST/4 stroke This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree3Likes
Old 08-27-2019, 10:31 PM   #21 (permalink)
patrioticinnovations's Avatar
19-20 Mileage:
18-19 Mileage: 849 so far
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
Originally Posted by IH8Summer View Post
So iíve tested all the relays. All click with power supplied and show 0 ohm resistance. Replacing them anyways when they come in the mail.
I crossed the solenoid posts and it turns over fine. Still zero life to gauges, efi, etc.
Im thinking kill switch is bad or grounding out somewhere, but i have a question. When the key is turned, how many prongs on the key switch should be sending current? So far as I can tell, only one is on mine.
Probably only one if just powering the display. Two if cranking. EFI likely doesn't run off the battery.
Old 09-04-2019, 02:35 PM   #22 (permalink)
Current Sled(s): 2015 Ski-Doo Renegade X 800 ETEC
Previous Sled(s): 2000 Polaris 700 SKS, 2010 Polaris IQ Turbo Dragon
Favorite Riding Area: Turtle Flambeau Flowage
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
Well my key is sending power from one of the terminals but nothing happens. That probably means it's grounding out somewhere then.
2015 Ski-Doo Renegade X 800R ETEC
IH8Summer is offline   Reply With Quote
Old 10-03-2019, 06:16 PM   #23 (permalink)
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
Another question: are the relays for the FST's open until closed or closed until open? I got some advice from someone the other day I've been mulling over but I'm not sure it's accurate.
I was debating disconnecting the key, as the key (theoretically) is what closes the circuit if they are open until closed. At that point if I jumped the solenoid posts the relays would all open and therefore, assuming no other unknown problems, start the sled. Does this add up?
Old 10-23-2019, 05:50 PM   #24 (permalink)
Current Sled(s): 2013 Ski Doo 1200 & 2006 FST Classic
Previous Sled(s): 2003 Polaris 700 Classic
Favorite Riding Area: WI Northwoods
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
Did you ever replace the relays or switch out the EFI relay with the chassis relay? Have you ever unplugged the ignition switch? If so you can plug the wires back on incorrectly. It's also possible the the ignition switch to be bad.
2006 FST Classic with 180 degree thermostat, notched drive shaft shield, re-routed/shielded wiring harness, block heater installed on bottom of engine, adjusted gas tank float, oil pressure light, Autometer boost gauge, Camoplast Ice Attack track, Snobeelers shock recalibration, cyclone hose re-routed to exhaust, 24-44 gears, YaYou's Stage 2 re-flash, helix and alternator pulley.
dofo1 is offline   Reply With Quote
Old 11-04-2019, 06:02 PM   #25 (permalink)
19-20 Mileage:
18-19 Mileage: 2143
17-18 Mileage: 1565
16-17 Mileage: 1980
Riding Since: 2007
Yeah i did unplug it. While I was home briefly I unplugged the key switch and crossed the solenoid posts. Nada. Might just take it in as I don't have time to check through every wire on the sled.
Old 12-29-2019, 03:25 PM   #26 (permalink)
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
Did you ever get it running?
Similar Threads
Hurricane at race on the rock hurricaneperformance Turbo 4 Stroke 3 04-14-2018 11:09 PM
Not starting dead after boosting Bskilliter2017! IQ chassis 0 12-15-2017 10:43 AM
Rock music you just can't gut? dodger General Discussion Forum 53 12-31-2016 11:30 AM
South Bend Service - Don Rock 3illmesmart General Snowmobile Forum 1 08-10-2016 03:28 PM
Rangeley Rock Maple & Pro Vintage Race jonny dw Maine 2 03-15-2016 02:24 PM
