Engine noise - HCS Snowmobile Forums
FST/4 stroke This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By dofo1
Old 01-15-2015, 03:26 PM   #1 (permalink)
Backcountry8's Avatar
Current Sled(s): 05 rx warrior
Previous Sled(s): 800 edge,z1 cat,800rev
Favorite Riding Area: anywhere
Riding Since: 1976
Default Engine noise
Just bought an 08 and it's quiet idling but giving small amounts of throttle it sound like a little desiel don't heard wot is this normal?
Backcountry8 is offline   Reply With Quote
Old 01-17-2015, 02:10 PM   #2 (permalink)
Current Sled(s): 2013 Ski Doo 1200 & 2006 FST Classic
Previous Sled(s): 2003 Polaris 700 Classic
Favorite Riding Area: WI Northwoods
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
Take a look at the shields under the hood to make sure they are secured, also check that the muffler has all the springs installed and that the shielding has not come loose.
If you are sure the noise is in the engine cut open your oil filter and look any bits of metal.
2006 FST Classic with 180 degree thermostat, notched drive shaft shield, re-routed/shielded wiring harness, block heater installed on bottom of engine, adjusted gas tank float, oil pressure light, Autometer boost gauge, Camoplast Ice Attack track, Snobeelers shock recalibration, cyclone hose re-routed to exhaust, 24-44 gears, YaYou's Stage 2 re-flash, helix and alternator pulley.
dofo1 is offline   Reply With Quote
Old 01-17-2015, 03:53 PM   #3 (permalink)
Riding Since: 1976
Default noise
thanks just waiting for a new filter from the dealer ,shields seem good if you put a long piece of wood against the engine its got a pretty loud clicking in you ear
Old 01-17-2015, 04:58 PM   #4 (permalink)
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
These engines are so quiet that you may be hearing injector noise of the cam chain, before can get too involved can you find another FST to listen too?
There have been some rod bearings that have failed but the noise is a more of deeper knock then a click.
Old 01-17-2015, 07:16 PM   #5 (permalink)
Riding Since: 1976
Default fst
its the worst when driving and putting firm amount of throttle on
Old 02-03-2019, 07:11 PM   #6 (permalink)
Newbie
I’m having the same issues with my 06 ! What did you find out your problem was?
Mkeites is offline   Reply With Quote
Old 02-03-2019, 08:32 PM   #7 (permalink)
19-20 Mileage:
18-19 Mileage: 3500
16-17 Mileage: 2500
Riding Since: 1978
Cut your oil filter open, if you find any metal you will need to tear the engine down to find the source, unfortunately it may have spun a rod bearing. Sometimes caused by blowing a belt and overreving for a second.
If you can pull your clutch off (Be careful not to rev it up) start it and see if the noise is gone, if so you got lucky and it's just the clutch rattling.
Drumerjb likes this.
Old 02-05-2019, 02:22 PM   #8 (permalink)
1fast444's Avatar
Current Sled(s): 2009 polaris iq shift 600 128" 1.25 Ice Attac
Previous Sled(s): 74customII530,76tx340,79txl,86indy4,95ss,97xcf,99xc6sp,2002
Location: xc6sp, 01xc6sp, 02xc7sp, 07fst, 11 IQ turbo and SE WIS.
Favorite Riding Area: U.P.
19-20 Mileage:
18-19 Mileage: 2600
17-18 Mileage: 1600
Riding Since: 1988
Rod Bearing, I spun 2 of them in my 2011.
1fast444 is offline   Reply With Quote
