Past/present Buick owners please help - Page 2 - HCS Snowmobile Forums
Like Tree12Likes
Old 01-15-2020, 03:18 PM   #11 (permalink)
dodger's Avatar
Current Sled(s): 2019 Axys600R, 2008 IQr, 2008 IQrr,
Previous Sled(s): still have 98xc7 220 motor
Favorite Riding Area: Mancelona cabin "Oleo Acres"
Originally Posted by LIMESQUEEZE View Post
I just fixed a plugged windshield tray drain in our explorer. A little tip I got along the way was to put a de-humidifier in the car and let it run all night. It dries the places you just cant get flowing air to go. Even the carpet padding was dry as a popcorn fart.
Hitting it good with a shop vac after work. I have the trunk lined in cardboard with snow on the trunk seeing if I can pinpoint the leak area.
*I've never had a 10,But I've had 5 twos.
*Life is not measured by the number of breaths we take, but by those moments that take our breath away.
dodger is offline   Reply With Quote
Old 01-15-2020, 04:20 PM   #12 (permalink)
800renegaderider's Avatar
Current Sled(s): 11 renegade 800
Previous Sled(s): 99 mach z,00 mach z,2 96 formula z,93 mach 1,02 legend,
Favorite Riding Area: Jaffrey,Pittsburg,Maine
19-20 Mileage:
18-19 Mileage: 3246
Riding Since: 2002
Originally Posted by dodger View Post
this thing does not have a speck of rust. Close to showroom. It looks like it's in the trunk. Door barriers would leak while driving. this happens when setting only. I checked the back floor when I parked it a few days ago. The last time it happened it rained/snowed hard. this time the same
The trunk carpet over the fake tire is wet. I have not pulled the fake spare yet but I am guessing it's a pool in there. It is wet the most in the very rear, back by the latch and lights. It's warm today. I am throwing cardboard in the trunk and piling a bunch of snow on the trunk. It will melt today
Have you changed a tail light build recently? Check the tail light harness is plugged into the hole through the body(good seal) and make sure the studs for the light have the gaskets on them. You should also check the seams of the body panels up on the trunk gutter area for dry or crack seam sealer if your getting water on the trunk carpet those are 2 pretty common areas Ive seen leak. I would also just pull all the trim out of the trunk have someone get in with a flashlight and another run a hose over the lights and trunk area if it’s getting that much water coming in you will see the leak pretty easily. I would also pull the sail panel trims and luggage tray and check the rear glass to be safe. You may not think it is rusty but it could be bubbling under the window urethane and causing a leak especially if the window has been replaced before and they did a shit job.
800renegaderider is offline   Reply With Quote
Old 01-15-2020, 05:18 PM   #13 (permalink)
Super Moderator
zr sled head's Avatar
Riding Since: 1861
Had one in with plugged door drains, enough rain and fills up to the point it ran in through interior panel clip holes.
Old 01-15-2020, 06:58 PM   #14 (permalink)
thunder999's Avatar
Current Sled(s): '11/Z1turbo sp ltd 98 Thundercat / 98 ZRT 600
Previous Sled(s): '94 t'cat 96 t'cat 99 tcat
Favorite Riding Area: Northern Ontario Sudbury
Riding Since: 1967
Check under the car, in the area of the leak, there are sometimes large rubber plugs (floor) that may be missing...i had a '99 Regal GS that i had to order the plug for...good luck
Follow the litre
thunder999 is offline   Reply With Quote
Old 01-15-2020, 07:14 PM   #15 (permalink)
polaris754's Avatar
Current Sled(s): 17 xcr 800 ,2 xcr 800,s 2000
Previous Sled(s): 95 xlt sp 69 399 nordic 73 cheetta 440 84 indy 600
Favorite Riding Area: bald mnt ,houghton lake grayli
19-20 Mileage: 493
18-19 Mileage: 850
17-18 Mileage: 550
16-17 Mileage: 1175
Riding Since: 1970
most of the time its the deck lid seal
polaris754 is offline   Reply With Quote
Old 01-15-2020, 07:51 PM   #16 (permalink)
XCR518INDY's Avatar
Current Sled(s): 19 Indy XC 800 / 17 XCR 600
Previous Sled(s): 16 Rush Pro S 600 /12 Rush Pro R 800 /10 Dragon switch 800
Favorite Riding Area: northeast kingdom
Riding Since: 1980
I agree with squeeze, definitely check your windshield cowl drains. Had a 2004 Grand Prix doing the same thing. Wet at rear floor only. Water was seeping in around spot welds in A (hinge) pillar and following channel in floor and settling at lowest point(rear floor). Front floor wasn't even damp.
XCR518INDY is offline   Reply With Quote
Old 01-15-2020, 08:19 PM   #17 (permalink)
Crnr2Crnr's Avatar
Current Sled(s): Green one's with Suzuki engines
Previous Sled(s): Green, Blue & Yellow
Favorite Riding Area: Wouldn't you like to know?
Riding Since: 70's
the greatest post in HCS history
Crnr2Crnr is offline   Reply With Quote
Old 01-15-2020, 08:23 PM   #18 (permalink)
Member
19-20 Mileage:
18-19 Mileage: 700
Not a Buick, but my Dad's car had a leak at the top of the back window. The water would run down the plastic airbag trim on the inside and into the trunk, filling up the spare tire well. Had to lay in the trunk with the carpet removed while a hose was sprayed all around the outside to finally find the leak.
Yellowjacket is offline   Reply With Quote
Old 01-15-2020, 09:21 PM   #19 (permalink)
sleepybrew's Avatar
Favorite Riding Area: salisbury, speculator, cny
i found this bulletin today
Floor Pan Corrosion Perforation in Battery Compartment (Install Repair Kit) #05-08-61-002 - (Jan 11, 2005)
2000-2005 Buick LeSabre
2000-2005 Cadillac DeVille
2000-2003 Oldsmobile Aurora
2000-2005 Pontiac Bonneville
Condition
Some customers may comment on corrosion (rust) in the floor pan in the area where the battery is located.
Cause
This condition may be caused by a weeping of acid from the battery or from a battery vent tube that has become dislodged.
Correction
Repair the damaged area using the parts and information contained in the floor pan repair panel kit.. Also, clean any area of the floor pan where acid may have been present with a solution of baking soda and water. Rinse and dry the area thoroughly.
Parts Information
The floor pan repair panel kit contains a replacement section of the floor pan, a battery hold down and instructions. The adhesive needs to be ordered at the time of the repair.
Part Number
Description
88948594
Panel Kit-Floor Pan Repair
12378567 (U.*.)
88901675 (Canada)
GM Metal Bonding Adhesiv
sleepybrew is offline   Reply With Quote
Old 01-16-2020, 01:51 AM   #20 (permalink)
Current Sled(s): 2003 Yamaha Viper, Yam 600sxr, Yam Vmax 600
Favorite Riding Area: Chautauqua Lake, NY
19-20 Mileage:
18-19 Mileage: 1000
Riding Since: 1972
I have owned several LeSabres and put 200,00 plus miles on them and never had any leaks. I have an 08 Lucerne which I had a similar problem with. The trunk would always be wet after a rain. I discovered that the car had an option for a back up alarm which mine doesn't have. The problem was at the factory they sealed the holes with some kind of tape which failed. I put Gorilla rubber tape over the holes and this solved the problem. These are located above the rear bumper on the side. Pain to get to but reach up along the rear and sides of the trunk and check.
benboat is offline   Reply With Quote
