Which 2 stage snow blower? - HCS Snowmobile Forums
General Discussion Forum A place for all off topic discussions. Forum Rules inside
Like Tree12Likes
Old 11-28-2019, 04:31 PM   #1 (permalink)
Default Which 2 stage snow blower?
Please advise, thanks.
WEATHERBY460 is offline   Reply With Quote
Old 11-28-2019, 05:13 PM   #2 (permalink)
Current Sled(s): 2014 Ski Doo GSX SE 600 etec
Previous Sled(s): 1 SkiDoo 2 Arctic Cats and 8 Polaris and assorted others
Favorite Riding Area: Hayward WI area, Up North
19-20 Mileage: 600
18-19 Mileage: 800+
17-18 Mileage: 600+
16-17 Mileage: 600
Riding Since: 1982
I have owned a few different makes and they all worked just fine. Last two have been MTD. A lot depends on how big an area you need to clean and how far you have to throw the snow. Get one big enough to throw the snow as far you need it to. I always get at least a 26" wide. If your cleaning a larger area get a wider machine and an 8hp. Mine has electric start but I never use it. Always starts on first pull.
Drift19 is online now   Reply With Quote
Old 11-28-2019, 05:18 PM   #3 (permalink)
bee1971's Avatar
Current Sled(s): None Ski Doo Arctic Cat
Previous Sled(s): 2013-15 Ski Doo Renegades / 1998-06 ZR-Firecat-Crossfires
Favorite Riding Area: Ishpeming / Munising Crazy 8s
17-18 Mileage: X
16-17 Mileage: X
Age: ?
Riding Since: 1998
Search
https://www.hardcoresledder.com/foru...-opinions.html
Crnr2Crnr likes this.
Scott/Julie - SOLD 2015/2013 Ski Doo Renegade Adrenaline 600 E-Tec
2011 Dodge Ram 1500 Hemi Sport Quad Cab 4X4 / Deep Water Blue / Loaded
1971 Dodge Charger Super Bee - 383 Magnum / 432 Stroker - Slapstik - 3:91 Suregrip
bee1971 is offline   Reply With Quote
Old 11-28-2019, 05:37 PM   #4 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
19-20 Mileage:
18-19 Mileage: 450
17-18 Mileage: 1100
16-17 Mileage: 750
Age: mr
Riding Since: 1977
I sort of agree, most are all compatible with each other these days in each class
bigger [part of owning them is taking care of them, and draining old fuel out before using again following yr and treating fuel when in storage, and if possible ONLY use non ethanol fuel in them
Have a few that sit at properties not interested in hauling one to, so leave em there!
and almost every yr, NEVER get used, almosta waste having the, but the time needed there sure nice to have there LOL
for me to keep em running this way,, every yr I drain tank's, replace fuel before even trying to start them, which I do about late OCT every yr, to make sure they are ready to go if needed, then at end of season, they get put away , carbs run dry!
come following yr, again, I drain ALL old fuel, replace with new, turn fuel on prime, and BOOM they fire up easy for me, and several are of different brand names/makers
so, to me key is HOW well you care for them
I replace oil every other yr on em too, even when they DON"T get used at all, just a habit of mine?
and they all tend to start on first or second pull, some are 10-15 yrs old too
so seems to me, care and good fuel and not leaving OLD fuel in, matters more maybe than name brand!
mrbb is offline   Reply With Quote
Old 11-28-2019, 06:10 PM   #5 (permalink)
D-rail's Avatar
Current Sled(s): 850 Pro S SB, '06 Fuse 6
Previous Sled(s): Polaris, Ski-Doo, Yamadog, Rupp, G-Whiz, Scrap Iron, etc.
Favorite Riding Area: roller coaster stuff
19-20 Mileage: 165
18-19 Mileage: 3430
17-18 Mileage: 3205
16-17 Mileage: 3605
Riding Since: 1973
Some of the "cheaper" makes are flimsy, and bend up after putting them through the paces. Depends on how much snow you want to remove, and if clearing driveways where the plows build up bigger piles and chunks of ice occur.
Criminals don't obey laws so we need more laws to stop criminals.
D-rail is offline   Reply With Quote
Old 11-28-2019, 06:14 PM   #6 (permalink)
Current Sled(s): 2008 700 Switchback
Favorite Riding Area: If there is snow, I go
Riding Since: 1994
I picked up a Toro 928 this fall and used it on our 3-4 inches of very wet and heavy snow and it at it up perfectly. I was able to do my entire blocks sidewalk in 6th gear. I have no worries with it for the big storms hopefully coming.
Love the joystick control and it shoots the snow pretty much anywhere I need it too.
BobRoss is online now   Reply With Quote
Old 11-28-2019, 06:16 PM   #7 (permalink)
Current Sled(s): T660LE/ 74 Thunderjet 340 75SST F/A 440
Previous Sled(s): Starcraft Eliminator, SnoJet 340F/A, 94 580EXT EFI, 74 Thund
Favorite Riding Area: Where the snow is
Riding Since: 1965
Brand name only....
lonewolfhowling is online now   Reply With Quote
Old 11-28-2019, 06:55 PM   #8 (permalink)
WildMann's Avatar
Current Sled(s): 2020 Riot & 2009 Z1 Turbo
Previous Sled(s): Blizzard 9500+,Mercury Max 440,Skiroule Lazer,1968 Olympic
Favorite Riding Area: Anywhere I can
19-20 Mileage:
18-19 Mileage: 2300
17-18 Mileage: 1700
16-17 Mileage: 150mi
Riding Since: 1983
I have some input on this as I use a walk behind snowblower to remove snow from my 278 yard laneway. Plastic chutes suck, the wet heavy snow sticks to them. specially if it's sunny. Plugs up faster than a steel chute.
My snowblower of choice is an Ariens. Mine is nearly as old as I am and still never lets me down. I've owned it for 16 years now. was used when I bought it, from an old guy in the city who had used it since new in 1980. Have changed one internal drive wheel and had to buy the brass float for it this summer cause the needle had worn a hole right through the contact area into the float.
edit: belts and shear pins are the only other items I've changed but I look at those as consumables
WildMann is offline   Reply With Quote
Old 11-28-2019, 06:57 PM   #9 (permalink)
Current Sled(s): r and a hacked togeather Snopro
Previous Sled(s): Xf700, F7sp, F5, ZLs,Zrs, Ext, Jags, el tigre
Favorite Riding Area: Back home In the Yoop
Riding Since: 1988
An old ariens
WildMann likes this.
Greg B. is offline   Reply With Quote
Old 11-28-2019, 07:14 PM   #10 (permalink)
awful knawful's Avatar
Current Sled(s): 2019 Expedition Sport 900
Previous Sled(s): 1992 MXXTCR, 74 TNT 300
Honda/ Yamaha
New ariens are piles of shit.
awful knawful is offline   Reply With Quote
