I love beating Arctic Cats - Page 34 - HCS Snowmobile Forums
General Discussion Forum A place for all off topic discussions. Forum Rules inside
Like Tree269Likes
Old 04-16-2019, 10:46 AM   #331 (permalink)
fortune46x's Avatar
Current Sled(s): 2016 Zr8000 Limited, 2014 zr6000r
Previous Sled(s): 14 xf7000 limited, 12 F800,Sp500 , F7
I feel the need to chime in here in someones newfound absence..
F7
fortune46x is offline   Reply With Quote
Old 04-16-2019, 10:52 AM   #332 (permalink)
Site Moderator - Chris
Bontz's Avatar
Current Sled(s): 2019 Indy XC 850
Previous Sled(s): '16 SB Pro-X; '15 Rush Pro-S; '12 SB Pro-R; '09 Dragon -Cats
Favorite Riding Area: Lake Namakagon/Cable, WI
19-20 Mileage:
18-19 Mileage: 1352
17-18 Mileage: 2032
16-17 Mileage: 825
Riding Since: 1975
F7
I really shouldn't laugh ... but damn, that's funny
Bontz is offline   Reply With Quote
Old 04-16-2019, 11:23 AM   #333 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
Ignore function worked fine, other than the dimschits quoting him.
sayatodaU.P.eh? likes this.
PPP Charter Member #2
Old 04-16-2019, 11:57 AM   #334 (permalink)
stinkipinki's Avatar
Current Sled(s): 2010 F8 Sno Pro HO / 2000 MXZ 600 Trail
Previous Sled(s): Lots of Cats and Doo's, few Yammys
Riding Since: 1990
@BattleStorm, on your lake setups, are you running two, three or four per row? If I do grab a 998 I might upgrade the track to a 1.25 or 1.5, but if I leave the 137 1.0 on there, I was thinking three per row with double backers. I just want it to hook up enough on the trails but without sacrificing top speed, if I can get the 1.0 to hook it will save me the better part of $1000.
stinkipinki is offline   Reply With Quote
Old 04-16-2019, 12:30 PM   #335 (permalink)
BattleStorm's Avatar
Current Sled(s): Polaris INDY
Favorite Riding Area: A Race Track
17-18 Mileage: 1200
Riding Since: 1986
4 per row, fill the track with iron for drags! I’ve had really good luck with 1inch hacksaw tracks.
BattleStorm is offline   Reply With Quote
Old 04-16-2019, 12:33 PM   #336 (permalink)
Riding Since: 1990
Wont sleds lose top speed with too many studs, or studs that are too long? I want a healthy balance of top speed and traction, might look into a ZR 9000 as they have meatier stock tracks. Just a little concerned, the last time I drove a 1.0 with studs, albeit it was a very snowy day, that damn thing slid all over, however it was a shorter track then a 137.
Old 04-16-2019, 12:51 PM   #337 (permalink)
krom's Avatar
Current Sled(s): 09 Sno Xer
Favorite Riding Area: South of the Hill
F7
I'm not complaining, but did i miss why?
my thought on the 850 patriot. the whole fucking motor is junk. 18 miles on mine and the coating is stuck in the rings, it's in the crank, etc. pistons are complete garbage. Kelsey had one of these apart and told me the motor was junk, now Indy Dan says it is.
bone stock 2019 Arctic Cat 800 at BMP
krom is offline   Reply With Quote
Old 04-16-2019, 01:39 PM   #338 (permalink)
Life Time Member
Jerry 976's Avatar
19-20 Mileage: 54321
18-19 Mileage: 12345
17-18 Mileage: 54321
16-17 Mileage: 12345
Disregard, I misread your post........
Jerry 976 is offline   Reply With Quote
Old 04-16-2019, 01:52 PM   #339 (permalink)
17-18 Mileage: 1200
Riding Since: 1986
There is a give and take with studs and adding almost any studs to a track on snow will slow it down but it’s not that much vs how much better the traction will be off the line. Longer studs do hook up noticeably better but will slightly loose more top speed. It all depends on how far you are racing, 1000ft or less then error on more studs. If you are racing a 1/2 mile or further then run less or none. Most trail sleds will hardly notice a speed loss from studs while racing. A really good speed setup sled on plowed ice will be affected much more by the number of studs.
I will also say I’ve hardly ever seen a sled loose a drag race because of too many studs and I’ve seen many loose because they didn’t have enough studs or the studs were too short.
fastsleddr and stinkipinki like this.
Old 04-16-2019, 01:54 PM   #340 (permalink)
Rodeo Rider's Avatar
Current Sled(s): 2016 MXZ-X 800 E-Tec, 2010 MXZ 800 P-Tec
Previous Sled(s): 15 so far
Favorite Riding Area: Maine
19-20 Mileage:
18-19 Mileage: 1800
17-18 Mileage: 1596
Riding Since: 1965
Hahahahaha! If you all watch the first race closely, I let the cat have the jump, I even completely let off the throttle on assault a few feet out and you can see me doing that. I wanted a vid if the assault pulling past the cat.
The cats engine has been set to Arctic Catís spec, the same thing the pro racers do for stock class racing. The engine is strong but the clutching is off, it revs too high. Compared to the stock xf8000 I used to have this hcr is a lot quicker. On the other side the assault is 100 percent stock as it came out of the factory and would also gain from clutching.
I saw that..you did the head bob thing, let the cat go first. I also heard you let off too.
"When the power of love overcomes the love of power then the world will know peace" Jimmy Hendrix
Rodeo Rider is offline   Reply With Quote
Similar Threads
New Exhaust Valve Gasket kit for power valves PN 3006-329 trdehmer Arctic Cat 38 09-26-2019 01:36 PM
Arctic Cat's plowing through snow bobby26 General Discussion Forum 138 03-21-2019 08:23 PM
2019 Snocross Thread fortune46x General Discussion Forum 813 03-20-2019 11:00 AM
Paydays race results??? NIGHTFIRE SP General Discussion Forum 38 09-13-2018 02:28 PM
