Ford techs, alternator question. - HCS Snowmobile Forums
Like Tree2Likes
  • 1 Post By strokerswild
  • 1 Post By cfm
Old 10-09-2018, 01:01 AM   #1 (permalink)
Current Sled(s): 12 600 SB, 99xcr 800
Previous Sled(s): 09 rmk 800,edge xcr, rmks xcs
Favorite Riding Area: Northern MN &WI
Default Ford techs, alternator question.
Working on my wifes 2010 mercury mariner with a v6. The alternator lightnonthe dash comes on intermittently. I checked the battery voltage while the light was on amd the voltage is never low. Its 14.2-14.7 and the light comes and goes, so what i did to get a better picutre of what is going on is i hooked a volt meter in at the cigarette lighter to read it going down the road. Bounces aroundin the 14s then jumps up to 16-17 volts for a while.
With the intmitent light and the battery not going down i was thinking of digging into the control wiring for the alternator but if its charging at that high of voltage maybe it would have to be something internal in the alternator. I am skeptical of having the alternator tested being that it is so intermittent, otherwise i would pull it and have it bench tested.
Any thoughts?
john 800 is offline   Reply With Quote
Old 10-09-2018, 08:29 AM   #2 (permalink)
shimxtr1's Avatar
Current Sled(s): 15 XF 6000, 18 ZR 8000, z120, Indy Lite
Previous Sled(s): F5,Sabercat 500, F7, Xfire 800 Ltd, XF 7000
Favorite Riding Area: Where the snow is!
19-20 Mileage:
18-19 Mileage: 2800
17-18 Mileage: 3500
16-17 Mileage: 3000
Riding Since: 1978
Sounds like maybe the voltage regulator is on its way out...
shimxtr1 is offline   Reply With Quote
Old 10-09-2018, 09:30 AM   #3 (permalink)
strokerswild's Avatar
Current Sled(s): The Couch
Previous Sled(s): '10 RMK 800/144, '01 600 XCSP
Riding Since: ~'79
You're not gonna enjoy removing that alternator.....
thefoolsbro likes this.
Shallow and pedantic.
strokerswild is offline   Reply With Quote
Old 10-09-2018, 09:36 AM   #4 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
Is it like the older Escapes and such that tease you into thinking you can remove it without removing the pass frt axle ?
strokerswild likes this.
PPP Charter Member #2
Old 10-09-2018, 11:42 AM   #5 (permalink)
I dont think so, it is low and towards the front ofvthe vehicle. I thought the older ones were on the back near the firewall. This one may need the radiator to be moved put of the way, but yea... it looks like it could be fun, or it may not be as bad as it looks, i havent got the lower covers off yet
Old 10-09-2018, 11:49 AM   #6 (permalink)
Fourcam281's Avatar
Current Sled(s): 16 6000 RR
I've done an older V6 one that was back by the firewall. What a pain the ass that was.
Fourcam281 is offline   Reply With Quote
Old 10-09-2018, 02:27 PM   #7 (permalink)
Gocky's Avatar
Current Sled(s): '05 Sabercat 700 LX EFI
Previous Sled(s): '97 EXT 580 EFI '99 ZL 600
Riding Since: 1996
Just a suggestion, have the battery tested just to rule that out. I have run into intermittent issues like that at my shop where it was the battery itself.
Gocky is offline   Reply With Quote
Old 10-09-2018, 08:45 PM   #8 (permalink)
Current Sled(s): '15 zr5000
Previous Sled(s): ext 600,cougars,fossils T660, zl800
Favorite Riding Area: 665
19-20 Mileage: 1540
18-19 Mileage: 2189
17-18 Mileage: 1105
16-17 Mileage: 1926
Riding Since: 1978
voltage regulator is internal to the alternator, in front is a pain but not nearly as bad as
if it's mounted on the back side.
thefoolsbro is offline   Reply With Quote
Old 10-11-2018, 07:40 PM   #9 (permalink)
ndtorque's Avatar
Current Sled(s): Just passed them down to the daughter
Previous Sled(s): 2000 ZR600. and many others of all brands since 1975........
Favorite Riding Area: anywhere there is snow !!
Riding Since: 1973
Do the basics first .. clean your battery connections and make sure everything if good n tight as in both ends of the cables and all of your grounds ..
Originally Posted by LE_07F8
If you aren't feeding/f*cking/financing me, your opinion doesn't matter!!!
ndtorque is offline   Reply With Quote
Similar Threads
Ford truck owners and techs, engine questions john 800 General Discussion Forum 85 08-07-2018 11:33 PM
?? Ford Tech's ?? Fusion ?? racerdave General Discussion Forum 8 06-20-2016 08:03 AM
16 Ford Mustang GT - 16 Dodge Challenger R/T bee1971 General Discussion Forum 61 05-19-2016 07:50 PM
Ford techs .... The Silverback General Discussion Forum 26 05-18-2016 09:27 PM
