Best mods for a totally stock 2008 F1000 Sno Pro? - HCS Snowmobile Forums
Like Tree3Likes
Old 12-19-2019, 11:38 PM   #1 (permalink)
nitrousman's Avatar
Current Sled(s): 2017 Arctic Cat XF8000 High Country Limited
Previous Sled(s): 2015 Polaris AXYS ProX ,2012 Assault, Boosted Nytro and more
Default Best mods for a totally stock 2008 F1000 Sno Pro?
Hey guys, picking up a super low mile unmolested F1000. Besides the Y-pipe what are some other bolt-ons that will really make it run? Does it need a clutch kit? It has the Cobra track in it and I donít plan to stud it, I like to tail slide corners and I think the Cobra is a sweet track without studs. Thanks.
Got Boost?
nitrousman is offline   Reply With Quote
Old 12-20-2019, 01:08 AM   #2 (permalink)
mnstang's Avatar
Current Sled(s): 8000 high country, SnoPro 500, zr900
Previous Sled(s): many cats
Favorite Riding Area: Northern MN
Checking motor mounts and putting a torque link on it would be high on my list. I like a torsion spring in the secondary clutch, check that clutch bushing while you're at it, they are notorious
mnstang is online now   Reply With Quote
Old 12-20-2019, 06:11 AM   #3 (permalink)
snochopper's Avatar
Current Sled(s): 2017 ZR9000 Limited
Previous Sled(s): 77 ElTigre 500 FA
Favorite Riding Area: Up North
Riding Since: 1972
Best year for stock 1000 IMHO, torsional works well (1-2 more mpg for me) but compression works good too with a Fett Bros yellow/pink spring, stock primary is pretty good. I would add at least 100? (2 per pattern) studs but I like studs for stopping also. Lastly the best money I spent on my 1000 was a pair of 6.7 Pilot skis with 7.5 shapers and 4" whatever on the outside, no darting and like power steering.
zr sled head likes this.
snochopper is online now   Reply With Quote
Old 12-20-2019, 07:22 AM   #4 (permalink)
Super Moderator
zr sled head's Avatar
Riding Since: 1861
If you can find one, Plowman mount to keep the engine in place.
Yes stock clutching is pretty darn good on the 08 but BMP torsional works just that much better.
Agree on studs, even heavily studded sled will drift the corners with ease, run down the center only.
Y pipe, works best with a fuel controller such as Boondocker, either way pipe means premium fuel only.
If it's a Sno Pro, dramatic improvement in ride ditching the air shocks for LXR version coil overs. Also good gains in ride quality having rears revalved.
Skis, after trying a bunch of em out there, settled on SLP / SLT for skis, also liked the Doo Pilot skis but lil too much push in loose snow. Loved the Simmons (tried both Gen I and Gen III but you do pay a penalty on effort to turn the skis on frozen hardpack.
Can't stress how much difference in clutch life you'll see keeping them blown clean between rides.
Be sure to remove the lower air box and add Gorilla tape to the outside where exposed.
While I really liked my 07 F1000, the 08 was a much better sled out of the box.
Old 12-20-2019, 07:30 AM   #5 (permalink)
Current Sled(s): 2019 850 Indy XC
Previous Sled(s): ZR600, F7, F8 SP, 600 Rush Pro-R
Favorite Riding Area: yooper, hayward, lakewood
17-18 Mileage: 530 sled blew up
16-17 Mileage: 1310
Riding Since: 1985
Aftermarket skis are a must
Bradd is offline   Reply With Quote
Old 12-20-2019, 10:46 AM   #6 (permalink)
zecow224's Avatar
Current Sled(s): 2017 XCR 800, 2015 M8000 Sidekick
Previous Sled(s): Lots
Favorite Riding Area: North of HWY 64 & Driftless
19-20 Mileage:
18-19 Mileage: 2000+
17-18 Mileage: 2601
16-17 Mileage: 1652
Riding Since: 1999
Remove coupler blocks
plowman mount
servo motor delete, bdx powervalves
full exhaust, be mind full of BMP products that year I blew 3 expansion chambers on my 07 because the welds and gauge metal used by bmp was too thin
torsion clutch
bdx diamond drive gears
4 arm primary is better than 3, but look for cracking on the inner sheave
Make sure airbox is sealed
bullseyes in airbox
vforce reeds
zecow224 is offline   Reply With Quote
Old 12-20-2019, 06:30 PM   #7 (permalink)
Current Sled(s): "Agri-vator"
You guys and that whole Steering business....
Old 12-22-2019, 08:36 AM   #8 (permalink)
Cap'n Pete's Avatar
Current Sled(s): '08 F1000 Nightfire
Previous Sled(s): F7, T-Cat, ZR700, Sno-Scoot
Favorite Riding Area: Paudash/Bancroft
Riding Since: 1990
Plowman mount on mine broke within the first winter. Doesn't matter. Sled still works great and doesn't vibrate like a mofo anymore.
Otherwise, the only things I did to mine were a y-pipe and BMP torsional conversion in the secondary ... works awesome. I'm also running Simmons Gen1 skis. Had this setup for 7 seasons now, and still loving it.
Cap'n Pete is offline   Reply With Quote
Old 12-22-2019, 02:36 PM   #9 (permalink)
nitrousman's Avatar
What’s the advantage of the BMP torsional conversion over stock?
Got Boost?
Old 12-22-2019, 05:18 PM   #10 (permalink)
Cap'n Pete's Avatar
Riding Since: 1990
Originally Posted by nitrousman View Post
Whatís the advantage of the BMP torsional conversion over stock?
It basically makes the clutch more "efficient", and you'll literally see a difference in fuel economy, since the heavy compression spring is thrown out and replaced with a spring that actually assists the "twisting" action of the secondary clutch. It's how all the old clutches used to work. Some guys have had success with the factory compression setup, but I just don't see the advantages of it.
Sorry, not much of a technical explanation, other than to say, the torsional is a more efficient, thus (IMO) more effective setup.
FWIW, my sled would ALWAYS beat my Dad's '07 F1000 at the pumps, until last year, we finally converted his over, and now we're basically identical (he's even beat me on mileage, which NEVER happened before). Unfortunately, we never had a chance for clean runs last year to measure changes in performance, but mine always out-ran his as well, and I do believe his was pulling harder as well, but again, never got a proper run to prove one way or the other.
