2010 arctic cat f5 lxr tps and throttle body settings - HCS Snowmobile Forums
Old 12-01-2019, 04:32 PM   #1 (permalink)
Newbie
Current Sled(s): 2010 arcticcat f5 lxr
Favorite Riding Area: Sault ste. Marie
Default 2010 arctic cat f5 lxr tps and throttle body settings
Ive rebuilt this sled entirely this year. it has idled rough since i got it and very boggy at low rpm and idle. mid-range amd wot is great. 10,000km and 3 previous owners
ive gone as far as i can with following the factory setup but cant find the specs for setting the throttle body or tps location. other than it says dont touch it.
Ive verified the tps with my ohm meter. at fully closed its 840 and moves fine through the slide without dropping out. but when its installed in the same location i removed it, it sits at 1000 ohm. even backing it down all the way it still dosent reach closed.
does anyone know the correct readings for the throttle body and tps at idle?
thanks in advanced!
Mart is offline   Reply With Quote
Old 12-02-2019, 11:33 PM   #2 (permalink)
Super Moderator
zr sled head's Avatar
Riding Since: 1861
Did you confirm tbodys are in sync to one another?
Did you confirm crank seals are ok or replace?
Old 12-03-2019, 06:52 PM   #3 (permalink)
Newbie
I have rebuilt the motor 50km ago. and i have checked that the flappers are in sync. i do not however have the throttle body openings set. the sled does have 10,000 km on it and i did no work on the throttle body. this problem was there when i purchased it. new reeds, pistons, rings, seals, ect.
I am currently suspecting the settings of the body, tps and oil injectors.
thanks for helping!
