GPS not charging? - HCS Snowmobile Forums
Like Tree1Likes
  • 1 Post By sno sub
Old 01-19-2020, 11:05 PM   #1 (permalink)
Default GPS not charging?
I have a Montana 610 connected to amps mount. My sled does not have a battery. My dealer installed a heated shield plug and it is not charging my GPS when driving. What should I look for to fix my problem?
snowracer is offline   Reply With Quote
Old 01-19-2020, 11:11 PM   #2 (permalink)
Drumerjb's Avatar
Current Sled(s): 14 Indy 800/ 05 800 XC
Previous Sled(s): 72 340 Rupp Nitro,73 440 Nitro,75 440 FA,02 Edge 500
Favorite Riding Area: Any where in WI.
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 2300
16-17 Mileage: 2100
Riding Since: 1968
The GPS needs DC current your heated shield plug is AC alternating current it doesn't care if it's DC or AC on a heated shield.
Drumerjb is offline   Reply With Quote
Old 01-19-2020, 11:16 PM   #3 (permalink)
Fun11cat's Avatar
Current Sled(s): 2020 ZR 8000 LTD IACT
Previous Sled(s): 14 XF 7000 10 F8 SP,05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera
Favorite Riding Area: Central MN
19-20 Mileage: 1425
18-19 Mileage: 1170
17-18 Mileage: 1260
16-17 Mileage: 960
Riding Since: 1972
Check your voltage to your plug like mentioned above if its AC it wont work, if its DC maybe the polarity is hooked up backwards.
Fun11cat is offline   Reply With Quote
Old 01-19-2020, 11:51 PM   #4 (permalink)
Is there an adapter I can buy to change from AC to DC? Or another way to connect my GPS to my sled?
Old 01-19-2020, 11:59 PM   #5 (permalink)
Drumerjb's Avatar
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 2300
16-17 Mileage: 2100
Riding Since: 1968
You need a diode that can handle about 5 or 10 amps you need to wire that into your positive side the diode is polarity specific.
Old 01-20-2020, 12:25 AM   #6 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
OP - what year make model engine is this sled ?
PPP Charter Member #2
Old 01-20-2020, 12:28 AM   #7 (permalink)
2020 Polaris xcr
Old 01-20-2020, 09:45 AM   #8 (permalink)
sno sub's Avatar
Current Sled(s): 2017 Switchback 600, 2013 Switchback Assault
Previous Sled(s): Many Poo's
Use the plug in for the cigarette lighter / 12v power point that is behind the gauges. I installed a plug-in then plug it in there. That way I can take the mount off and use it on my sidexside. Make sure to get good locking set of plugs so you don't have problem with it coming loose.
Drumerjb likes this.
sno sub is offline   Reply With Quote
