13 IQR Gas not getting to Carb?? - HCS Snowmobile Forums
440/race/modified This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By dodger
Old 01-21-2019, 12:03 PM   #1 (permalink)
RHINO4353's Avatar
Current Sled(s): 2013 IQ 600 R & 2015 Indy 600
Previous Sled(s): 2003 Polaris Supersport
Favorite Riding Area: U.P.
Default 13 IQR Gas not getting to Carb??
New to me 13 iqr.... Ran great for about 40 minutes.... was riding on normal trail conditions... Then me and my buddy went off trail and hit this big drift and after i landed the sled went to one cylinder and shut off??? ( almost like ran out of gas)...... Checked spark plugs looked great.. then put thumb over spark hole to check compression ( seemed fine)...... sat for a bit started back up ( assuming gas from floats gave it enoguh gas to start back up... ran it down trail then it shut off...
Seems im not getting fuel to carbs.. one time i started only left cylinder would fire and then vice versa...
Is this bad fuel pump? Something caught in fuel filter?? just curious to what happend as the sled was running great and then hit the drift and shes a no go.. was it a coincedence that i happend to hit jump and it shut off at same time or was it bad fuel pump and when i was ripping on it it failed??? any help is apreeciated this is new to me IQR..
RHINO4353 is offline   Reply With Quote
Old 01-22-2019, 09:18 AM   #2 (permalink)
RHINO4353's Avatar
nothing??? and i should clarify it was not a snow drift more so a jump and low snow conditions.... Also looking for 10.5 or 12.5 if any one has a used one... i have a 8.8 i could trade/swap sell.
Old 01-22-2019, 09:32 AM   #3 (permalink)
KCM
No fuel No oil no bearings don't run them dry!!!
KCM is offline   Reply With Quote
Old 01-22-2019, 10:06 AM   #4 (permalink)
RHINO4353's Avatar
Exactly.. thats why im trying to figure out what the issue is...
Old 01-23-2019, 08:27 AM   #5 (permalink)
Member
Not saying this is your case but it would be a easy fix my buddy had his 13 out and would RIP for 10 mins then shut off pulled the air box and came to notice that when we put the air box back on after doing work to it the gas line was being pinched under the air box lmk if this helps
Tace is offline   Reply With Quote
Old 01-23-2019, 10:39 AM   #6 (permalink)
crazyman's Avatar
Current Sled(s): 15 Pro X SB
Previous Sled(s): 14 SBA 800, 08 IQ600R, 03 xc600sp mod, 98 xc 600, 92 xcr 440
Favorite Riding Area: WYOMING mtns/ditches/off trail
Riding Since: 1
how much gas is in it?
look in the tank to see if the pickup for the fuel busted off in the tank. a lot of times over years of sitting the pickup tube can rot and break off and fall in the tank. sled will run until the fuel gets below where the pickup hose goes through the tank.
or as stated above a pinched line.
or remove carbs and verify flow with the needle and seat manually.
also check the fuel pump impulse line on the mag side of the engine. should be a black hose going to the fuel pump form the crankcase.
crazyman is offline   Reply With Quote
Old 01-24-2019, 11:03 AM   #7 (permalink)
dodger's Avatar
Current Sled(s): 2019 Axys600R, 2008 IQr, 2008 IQrr,
Previous Sled(s): still have 98xc7 220 motor
Favorite Riding Area: Mancelona cabin "Oleo Acres"
I think it turned out to be his fuel filter.....I know? Fuel filter on IQR? Not there stock, but a good idea IMO
*I've never had a 10,But I've had 5 twos.
*Life is not measured by the number of breaths we take, but by those moments that take our breath away.
dodger is offline   Reply With Quote
Old 01-24-2019, 01:32 PM   #8 (permalink)
RHINO4353's Avatar
Yup.. Small in line fuel filter.... Bought about 3 extra just in case. Fuel pump seemed to be getting fuel to carbs last night........... when it didnt run we could not see any gas getting to carbs..... i blew through old filter and it was completley clogged. new one is in and its running.
Old 01-24-2019, 04:36 PM   #9 (permalink)
dodger's Avatar
I would look into what is in the tank myself. When you went over you may have stirred up some of the nasty stuff that may be in the tank and clogged the filter. Better to be safe then stranded.....If the in line was clogged, the in tank one may be getting there too.
RHINO4353 likes this.
Similar Threads
All you firecat guys. What's the rarest color scheme/build cat produced? StretchedF7 XFire 128/Firecat(03-06 & 09-?) 48 01-01-2020 11:07 AM
440 Mikuni Carb Help for old Trail Cat ZRTCFR Arctic Cat General Discussion 32 02-06-2019 11:53 AM
srv carb xc600Joe 2 Strokes 2 01-29-2018 10:19 AM
Carb balancing/sycing general question steveg_nh General Snowmobile Forum 15 12-06-2017 01:05 PM
Summit 600 carb no spark -Mike- XP/XR/XS New Style MXZ 0 02-13-2017 05:57 PM
