Ethanol tester that fits in your pocket. - Page 3 - HCS Snowmobile Forums
Like Tree3Likes
Old 02-25-2012, 05:38 PM   #21 (permalink)
applerows's Avatar
Current Sled(s): 16 PRO S LE 8- 98 INDY 500
Previous Sled(s): 2012 PRO R SB 8
Favorite Riding Area: Maine
Riding Since: 2010
Originally Posted by rigid1 View Post
startron does not work at all!!!!! this stuff does...
Watch Videos Online | Ethanol and Other Fuel Problems ELIMINATED | Veoh.com
20 Min.
How about the cliffnotes version..5 min. or less
applerows is offline   Reply With Quote
Old 12-02-2012, 12:52 PM   #22 (permalink)
Member
Current Sled(s): 99' XC 700SP, 98 XLT classic
Previous Sled(s): 98 Indy 500, 95 XLTSP, 00 XC600SP
Favorite Riding Area: Concord, Loudon, Caterbury
Riding Since: 2003
Thanks Rigid1 , me having lived out in your area for a couple of years (Phoenix N.Y.) I feel with the deep cold you would have a major ethanol separation issue there. I will check out the site to see if I can buy it local. Wondering if I can even buy ethanol free fuel here in N.H. I remember when I moved to CNY my truck ran like crap! N.Y. already have ethanol then 03'.
PeckervillePosse is offline   Reply With Quote
Old 01-30-2013, 10:57 PM   #23 (permalink)
700xc's Avatar
Current Sled(s): 2014 Polaris Rush SW
Previous Sled(s): 2014 Rush SB, 2010 Rush, 06 700 FUSE , 02 700 XCSP
Favorite Riding Area: Bluebear Trail area Bear Lake
19-20 Mileage:
18-19 Mileage: 1700
17-18 Mileage: 1200
16-17 Mileage: 1500
Riding Since: 1970
just had 2 sleds burn down in1 day 40 miles apart everyone is telling me its got to be gas . My wifes sled 07 IQLX 600 4300 miles 2010 rush 3300 miles melted pistons enough to cause crank prob
700xc is offline   Reply With Quote
Old 02-12-2013, 09:18 AM   #24 (permalink)
HCS Lifetime Premium
rigid1's Avatar
Current Sled(s): 16 Pro S Switch, 02 ZL550
Previous Sled(s): 09 Nytro RTX SE, 07 Phazer FX and GT, 09 Nytro RTX
Favorite Riding Area: CNY
19-20 Mileage:
18-19 Mileage: 1565
17-18 Mileage: 965
16-17 Mileage: 832
Riding Since: 2007
B3C has modified its ethanol shield product with a new additive called CCT (cylinder cooling technology) non-ethanol fuel in an engine is burning at 409deg, ethanol fuel is burning at 458deg because of the alcohol content, by adding ethanol shield with CCT they got it back down to 409deg.. good for all you 2stroke guys that are melting your engines..
rigid1 is offline   Reply With Quote
Old 02-12-2013, 09:24 AM   #25 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
Riding Since: 1959
Alcohol should burn cooler than gasoline. You have to make heat to make Horsepower.
Old 02-12-2013, 10:01 AM   #26 (permalink)
rigid1's Avatar
19-20 Mileage:
18-19 Mileage: 1565
17-18 Mileage: 965
16-17 Mileage: 832
Riding Since: 2007
http://www.b3cfuel.com/documentation...-CCT-Final.pdf
Old 02-12-2013, 10:22 AM   #27 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
Ethanol burns much cooler than 100% Gasolinehit's one reason you need bigger jets.ttp://www.weedcenter.org/mrwc/cig/documents/Heating%20Value%20of%2020%20CommonFuels.pdf
Old 02-12-2013, 10:30 AM   #28 (permalink)
rigid1's Avatar
19-20 Mileage:
18-19 Mileage: 1565
17-18 Mileage: 965
16-17 Mileage: 832
Riding Since: 2007
good link!!!, do you know why ethanol fuel burn hotter??? is it the power of the explosion with the added ethanol???
Old 02-12-2013, 10:34 AM   #29 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
I don't believe it burns hotter, it's why fuel mileage suffers with Ethanol mixed fuels, you need to burn more of it to go the same distance, it purduces less energy per gallon. I used to run alcohol carbs many years ago, the jets were much larger than carbs set up for straight gasoline.
Old 02-12-2013, 11:04 AM   #30 (permalink)
rigid1's Avatar
19-20 Mileage:
18-19 Mileage: 1565
17-18 Mileage: 965
16-17 Mileage: 832
Riding Since: 2007
well i talked to my buddy that is a bit more knowledgeable on this topic.. and it looks like we are both right in a way.. the increased temp in a 2stroke cylinder is due to the ethanol in the fuel, but not because of the temp it burn at (you are 100% correct) but the fact that it does not allow good lubrication of the cylinder creating more friction,..we all know by rubbing our hands together that friction creates heat. just below a guy has some pics of his piston.. the center doesnt look to bad but the sides.. burned bad.. thanks for your help xcr!!!
im on my 3rd season of using the B3C products and have really found them to work as they claimed and am completely satisfied..
