Modern day horsepower - Page 4 - HCS Snowmobile Forums
Like Tree13Likes
Old 05-08-2019, 07:57 PM   #31 (permalink)
fourh-ds's Avatar
Current Sled(s): 00 XCR 800, 04 XC 800
Riding Since: 1988
https://m.youtube.com/watch?v=glxlaI19w5M
It seemed fitting to put this video here. Even though it was mostly wheel hop that broke this truck, the video shows the power upgrades available when an engine has forced breathing, (turbo or SC) vs a naturally aspirated engine of twice the displacement.
fourh-ds is offline   Reply With Quote
Old 05-09-2019, 05:44 AM   #32 (permalink)
ivar's Avatar
Current Sled(s): 2019 SBA 850
Originally Posted by northstarrick View Post
it is actually very simple. and only added about ten pounds of weight. and this sled clutch set-up had about 10,000 test miles without one hiccup. but i would suspect cost is what's holing it back.
I'm thinking , to make a cost effective setup, one way would be to keep todays components , ie weights/springs/helix, and just use electronics to modify/tweak the shift curve as desired.
Also, this way, if the fancy shit breaks , there's still old school tech in the clutches to get you home
2019 SBA 850,2015 600 Adventure (int'l)
09 Doo 1200 GTX, 02 XC800 / 00 XCR800 - Pro-X rear skid, 99 XC700SP
RIP: 800SBA, 02 XC800, 99 SKS700, 97 XLT SKS
ivar is online now   Reply With Quote
Old 05-15-2019, 03:43 PM   #33 (permalink)
Current Sled(s): 2000 mxz 600
Previous Sled(s): 1986 poo indy 400 -1999 z370 cat -94 440 super sport poo -
Riding Since: 1997
Originally Posted by MR WEEZ View Post
Huda thunk it that this electronic doo-hicky is giving me more horsepower with a couple touches of a keyboard. I miss the old days installing pipes, reeds and jetting etc. trying to find that little edge over my buddies.
Get a Polaris problem solved they make the most hp an are easy to mod my buddys 800 blows the 850s doors off .
Sent from my SM-N960U using Tapatalk
cat eater
Fast DoO is offline   Reply With Quote
Old 05-15-2019, 07:15 PM   #34 (permalink)
Current Sled(s): Sidewinder RTX Le
Previous Sled(s): Nytro
Favorite Riding Area: District 8
18-19 Mileage 5000km
16-17 Mileage: 3000
15-16 Mileage: 3500km
Originally Posted by Tommcat View Post
no worries.
i've heard that yammie is trying closed loop for 2020, but only on the NA 1049 motor, which is pretty much the last place that needed it.
I always thought that closed loop was not desirable for a boosted application. I know when you go bigger power on a WRX many convert to speed density. Something with the MAF and boost and having to reroute the BOV back after the MAF or you get run problems.
big_phil is offline   Reply With Quote
Old 05-15-2019, 08:14 PM   #35 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): too many
Favorite Riding Area: Maine
Riding Since: 1977
Speed density is still closed loop, at least on any modern system.
And the reason those particular wrx guys remove the MAF is likely because they insist on using an atmosphere dump BOV because it sounds cool, but can't get it to work.
Sent from my SM-J737V using Tapatalk
Old 05-16-2019, 08:18 PM   #36 (permalink)
TommCat Performance
Tommcat's Avatar
Riding Since: 1977
What problem does he have that owning any Polaris would solve?
Making too much power? Going too fast? Easiest to make more power? Engine stays together too long?
Similar Threads
2018 Axys Horsepower validation videos [email protected] Switchback Assault/SKS/RMK (AXYS Platform) 4 12-04-2017 05:52 PM
Horsepower? D.bellamy55 ZRT/Thundercat 3 11-19-2016 03:39 PM
2016 6000R XC Horsepower Michman 1 ProCross (2012 - ) 3 03-24-2016 02:02 PM
Tribute to the godfather of the modern snowmobile. krom General Discussion Forum 69 03-19-2016 01:39 PM
Tribute to the godfather of the modern snowmobile krom General Snowmobile Forum 2 03-13-2016 03:20 PM
