Fuel treatmenst all snake oil? - HCS Snowmobile Forums
Like Tree7Likes
  • 1 Post By shimxtr1
  • 1 Post By decee
  • 2 Post By 1fastpolaris
  • 1 Post By David Pumpkins
  • 1 Post By Garc
  • 1 Post By Let it Snow!
Old 01-30-2019, 09:13 AM   #1 (permalink)
Current Sled(s): 2013 Rush Pro R 800 retro 2001 XCSP 700
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
Default Fuel treatmenst all snake oil?
I watched a video on youtube, I don't do links, so you have to type in Project Farm K100 fuel treatment test. Anyhow, he tested K100, Startron, Iso-heat and 91% isopropyl alcohol from the dollar store. As far as water in the fuel, the iso-heat and Isopropyl kept the water from freezing, but it still didn't run. K100 which claims to keep water suspended so it burns off with the fuel unnoticed. Didn't work. Neither did startron, which just claims to help with phase separation, but didn't work either. Both K100 an Startron, the water froze solid in the bottom.
So, is it even worth using, I put startron in every fill up, it still is a good stabalizer and fuel system cleaner, so it's good for that, but as far as water, no dice.
Frankie406 is offline   Reply With Quote
Old 01-30-2019, 09:28 AM   #2 (permalink)
shimxtr1's Avatar
Current Sled(s): 15 XF 6000, 18 ZR 8000, z120, Indy Lite
Previous Sled(s): F5,Sabercat 500, F7, Xfire 800 Ltd, XF 7000
Favorite Riding Area: Where the snow is!
19-20 Mileage:
18-19 Mileage: 2800
17-18 Mileage: 3500
16-17 Mileage: 3000
Riding Since: 1978
I think just about all those fuel additives work just enough that they cant be accused of false advertising but for the most part don't do what they claim. I go out of my way to find non ethanol gas and even then siphon it in the fall and start with fresh.
snowcrazy1 likes this.
shimxtr1 is offline   Reply With Quote
Old 01-30-2019, 09:32 AM   #3 (permalink)
Current Sled(s): Not enough room to list my 6 Polaris's
Previous Sled(s): probably 12 Polaris', 10 Yamaha's, 10 Skidoos, zero Arctic C
Riding Since: 1964
lonewolfhowling likes this.
Make TRUDEAU a DRAMA TEACHER again !
decee is offline   Reply With Quote
Old 01-30-2019, 11:21 AM   #4 (permalink)
1fastpolaris's Avatar
Current Sled(s): 2020 SBA 850
Previous Sled(s): 12SWB600 09D8 05XC800 00XC500
Favorite Riding Area: UP and N. WI
Riding Since: 1984
Mechanic in a bottle, if you believe everything you see on the net! It does dissolve the nasty shit in the bottom of carb bowls if you leave it awhile.
tallcool 1 and Jerry 976 like this.
1fastpolaris is offline   Reply With Quote
Old 01-30-2019, 11:29 AM   #5 (permalink)
Member
Current Sled(s): Sold for a Wildcat Trail UTV
Previous Sled(s): IQ Shift 550f, Phazer RTX
Riding Since: 1995
Seafoam has always been a treatment that has seemed to help my engines run a little better. It does create HUGE smoke clouds if you let it get sucked up by a vacuum line and melt off the built up carbon. Like MASSIVE fire department called because a house must be on fire size clouds of nasty black smoke.
As a fuel additive it seems to keep my motorcycle carbs nice and clean, I run it every fill up. No idea what it does about water though.
In my diesel tractor I do Power Service winter to help keep the fuel from gelling/freezing the filters. It works okay. I still blast the torpedo heater on the thing for 45 minutes before starting so its a little easier on the engine, it sounds like a bag of hammers for a minute if I don't pre-warm it.
ndlsjk is offline   Reply With Quote
Old 01-30-2019, 11:33 AM   #6 (permalink)
Life Time Member
Jerry 976's Avatar
19-20 Mileage: 54321
18-19 Mileage: 12345
17-18 Mileage: 54321
16-17 Mileage: 12345
There's a sticky thread at the top of this forum, it's about 20 minutes long.....
Clicky below:
Ethonal, Water, Gas, Oil. Video
Jerry 976 is offline   Reply With Quote
Old 02-01-2019, 01:21 AM   #7 (permalink)
David Pumpkins's Avatar
Current Sled(s): 2005 Redline Revolt 800
Favorite Riding Area: Your mom's bedroom
17-18 Mileage: 4700
Riding Since: 1975
I used to use cheapo stabilizer (stabil) on my old ZX, and the bowls were clean every Fall.
David Pumpkins is offline   Reply With Quote
Old 02-01-2019, 08:28 AM   #8 (permalink)
Garc's Avatar
Current Sled(s): Edge/3 Holer/~200 ponies with extra long legs
Favorite Riding Area: Wherever the snow flies
The ratios are absurd for his testing. If you have a 10 gallon tank, he’s trying to mix and burn a full 2 gallons of water. The Petri dish needs to be world realistic and under 3% instead of 10-20%.
In my 30 gallon truck, even at 5% water(1.5 gallons) I’m dumping the tank.
cfm likes this.
Built, not bought...
Garc is offline   Reply With Quote
Old 02-01-2019, 08:46 AM   #9 (permalink)
Let it Snow!'s Avatar
Current Sled(s): '16 ZR6 El Tigre, '90 Jag 340
Previous Sled(s): '02 ZL 600, '91 Indy 500
Favorite Riding Area: Wherever I am.
19-20 Mileage:
18-19 Mileage: 2005
17-18 Mileage: 1100
16-17 Mileage: 300
Riding Since: 1996
No need for draining if you use:
https://fitchfuelcatalyst.com
As long as its non-eth.
Boom2 likes this.
Let it Snow! is offline   Reply With Quote
Old 02-02-2019, 11:44 AM   #10 (permalink)
timc3352's Avatar
Current Sled(s): 15 switchback 800 pro s, 13 Rush Pro R 600
Previous Sled(s): 13 rush 800 pro r, 06 fusion 900 older skidoo, arctic cats
Favorite Riding Area: Northern Minnesota
19-20 Mileage:
18-19 Mileage: 1200
17-18 Mileage: 600
16-17 Mileage: 1200
Riding Since: 1985
Anybody remember the long thread about Gas RX?
timc3352 is offline   Reply With Quote
Similar Threads
Ran out of fuel and won’t start now ippielb ProCross (2012 - ) 24 01-31-2019 09:17 PM
Fuel Sock replacement error... what was it? mrc3 Rush/Switchback (Pro-Ride Chassis) 12 01-07-2019 07:29 PM
VP MRX02 Race Gas in ZR6000 RR NHracer ProCross (2012 - ) 7 11-23-2017 03:14 PM
inconsistent running issue ballsout83 XCR 57 12-29-2016 07:38 PM
Octane SouthernTierSwitchback Rush/Switchback (AXYS Platform) 40 11-03-2016 04:31 PM
