My 2003 viper not charging battery. Fires up no issues with a fully charged battery but wont charge. New battery, new regulator/rectifier. I'm kinda a noob with wireing. Any help would be great.
you need to get a volt meter, check battery voltage static, ie engine not running,start the sled and recheck voltage at battery , should be higher, then increase rpms to 3gs, most sleds dont put out high voltage at idol speeds,it should get higher as rpms go up, if u have no increase, u will need to back track voltage outputs from the stattor to the battery and so on,question i have is when the sled is running r the lights brite? dose the light get briter , with rpms? if this is all good, charging system is werking . u need to find out y it isnt getting to the battery, good luck
Yes anything is possible. Lol. I am dealing with the same issue and did testing for the last year. Mine is either cdi box or main wiring harness.
Related Threads
Hardcore Sledder
8.8M posts
150.6K members
Since 2002
