HCS Snowmobile Forums
HCS Snowmobile Forums (https://www.hardcoresledder.com/forums/)
-   Freestyle (https://www.hardcoresledder.com/forums/331-freestyle/)
-   -   QUITS (https://www.hardcoresledder.com/forums/331-freestyle/721994-quits.html)
northdoo 03-03-2013 08:16 AM
QUITS
300 freestyle will quit but if you shut key off before it stops rolling and the put key in the on pos it will restart. Seems like it is grounding out. Is it stator or ignition module? Many people had same problem just have'nt read a definitive answer. Thanks
bpluemer 01-19-2016 06:01 PM
Not good. This happened to me. Check compression - I had to do a top-end rebuild with the symptoms you are describing.
