2006 M6 temp sensor - HCS Snowmobile Forums
XFire 136"-141"/Mtn. Cat/M-series This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By fastcat800
Old 02-22-2018, 10:29 PM   #1 (permalink)
fastcat800's Avatar
Current Sled(s): 2014 XF 7000 SP LTD, 2006 M6
Previous Sled(s): 2006 XF 700, 2001 ZR 800, 1996 ZRT 800
Favorite Riding Area: MN's North Shore and ID, MT
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
Default 2006 M6 temp sensor
I am in Island Park for a couple more days and have a code 7 temp sensor blinking. The sled ran perfect all day today. I am guessing it has a broken wire and that is why it flashing the code. It has to be that or it has out of range high resistance. I don't have an ohm meter to check it. I don't have a problem riding it the way it is but do not want to burn it down. Any one have any input.
fastcat800 is offline   Reply With Quote
Old 02-23-2018, 10:05 PM   #2 (permalink)
fastcat800's Avatar
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
Ran fine all day but has a little hesitation when it is cold.
Old 03-02-2018, 07:32 PM   #3 (permalink)
bee1971's Avatar
Current Sled(s): None Ski Doo Arctic Cat
Previous Sled(s): 2013-15 Ski Doo Renegades / 1998-06 ZR-Firecat-Crossfires
Favorite Riding Area: Ishpeming / Munising Crazy 8s
17-18 Mileage: X
16-17 Mileage: X
15-16 Mileage: 1500
Age: ?
Riding Since: 1998
Cold - They all did from what i remember , even when the temp sensor was working properly
With the engine running , grab the wire harness where it enters the sensor on the pipe and wiggle it around and see if you can get the light to cut out
You will not burn it down running a bad temp sensor on a 2006
Scott/Julie - SOLD 2015/2013 Ski Doo Renegade Adrenaline 600 E-Tec
2011 Dodge Ram 1500 Hemi Sport Quad Cab 4X4 / Deep Water Blue / Loaded
1971 Dodge Charger Super Bee - 383 Magnum / 432 Stroker - Slapstik - 3:91 Suregrip
bee1971 is offline   Reply With Quote
Old 03-03-2018, 11:58 AM   #4 (permalink)
fastcat800's Avatar
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
After the light came on it has less hesitation when it is cold, but it is still there. I will check the wiring. I ordered a new GM sensor that guys on snow west say works. All you have to do is change the connector. $30 for the GM sensor $135 for the Cat one.
Old 04-06-2019, 01:31 PM   #5 (permalink)
fastcat800's Avatar
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
Put the new sensor in and it runs fine at sea level but still has the bog when cold at 7000 feet. Runs perfect once it is hot
Old 04-14-2019, 12:38 AM   #6 (permalink)
Ballistic17's Avatar
Current Sled(s): 2009 M8 Sno Pro Le
Previous Sled(s): 94 Xlt, 98 Xc 600, 04 F7 Snopro
Favorite Riding Area: Central MN
18-19 Mileage 1200+
Riding Since: 1994
Would you happen to have the part number for the gm temp sensor?
09 M8 Snopro LE
Ballistic17 is offline   Reply With Quote
Old 04-14-2019, 05:51 PM   #7 (permalink)
fastcat800's Avatar
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
GM OEM-Oxygen O2 Sensor 12643246
https://www.ebay.com/itm/GM-OEM-Oxyg...QAAOSwkNpadpiD
Ballistic17 likes this.
Old 04-14-2019, 05:53 PM   #8 (permalink)
18-19 Mileage 1200+
Riding Since: 1994
Originally Posted by fastcat800 View Post
Thanks
09 M8 Snopro LE
Old 04-15-2019, 12:36 PM   #9 (permalink)
fastcat800's Avatar
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
I found this info in a HCS discussion about the 800 temp sensor problems. Someone had researched the resistance values through the temperature range and they were the same as the Cat sensor and the 600 and and 800 use the same sensor.
