Zr 800 too much oil - Page 2 - HCS Snowmobile Forums
Old 02-11-2020, 10:19 AM   #11 (permalink)
Current Sled(s): "Agri-vator"
I was going to say torque arms are the way to go, but I don't know if anybody even makes one anymore, and didn't know if you'd want to fabricate one (two AC tie-rod ends, or industrial little eyelets), your welcome. With the arm, run that snubber right up pretty snug, let thrm share the load
Old 02-12-2020, 12:30 PM   #12 (permalink)
mopar4u's Avatar
I found a used cable assembly locally. Its from a 2005 zr 900 efi. Its a different part number but the assembly is much better, it has an oil cable adjuster mid assembly which would make the adjustment process much easier. Think i can use this setup? The 05 is part number 0687-174, my sled calls out part 0687-152
ID:	2074544   Click image for larger version
"THE BUZZ YOU BE GETTIN FROM CRACK DON'T LAST, I'D RATHER BE OD'IN ON THE CRACK OF HER ASS"
mopar4u is online now   Reply With Quote
Old 02-12-2020, 01:13 PM   #13 (permalink)
Super 8's Avatar
Current Sled(s): 2014 XF 8000 137" Orange Limited
I would try it, keep an eye on your oil pump timing marks, including throttle WOT etc.
No Substitute For BIG JUGS!!
Super 8 is offline   Reply With Quote
Old 02-12-2020, 11:07 PM   #14 (permalink)
X2. I bet it'll go right on
Old 02-13-2020, 07:18 PM   #15 (permalink)
mopar4u's Avatar
Damn I’m getting frustrated. Got the used cable hooked up. I’d get it set and flip the throttle, everything looked great. Start assembly and both high and low notches would be off a lot (?1/4”?). Push the lever down by hand and it seemed to go back to where it needed to be. I tried the pump arm with no cable and it went back on it’s own. I lubed the pump spring. If both high and low alignment marks are being impacted doesn’t that mean the issue is at the black rotating piece at the bottom of the oil cable that attaches to the arm?
Old 02-13-2020, 10:13 PM   #16 (permalink)
Super 8's Avatar
Does the cable you installed move freely by hand, does it need to be lubed or cleaned?
Old 02-14-2020, 12:19 AM   #17 (permalink)
The exposed cable length is the same in each cable right? Meaning, their Travel is the same? I'd think so.
Old 02-14-2020, 08:01 AM   #18 (permalink)
mopar4u's Avatar
Yeah, when i had everything lined up it worked fine, once i fiddled around, snapped the throttle a few times both alignment marks would be way off
Old 02-14-2020, 09:17 AM   #19 (permalink)
Not something loose or stripped out in the pump shaft/tabbed dial l thing is there? Seems unlikely
Old 02-14-2020, 09:41 AM   #20 (permalink)
mopar4u's Avatar
No idea or how to even check that. Wondering if when i had the engine out the cable mount bracket got bent and the angle of the dangle is too much causing a hanging up with the black plastic cable mount at times? I dont know. I have a brand new parts unlimited cable coming today.
