Fox Shock Rebuild - HCS Snowmobile Forums
Like Tree5Likes
Old 01-15-2020, 11:57 AM   #1 (permalink)
Member
99ZRGuy's Avatar
Current Sled(s): 1999 ZR 500 EFI
Previous Sled(s): 1999 ZRT 600
Favorite Riding Area: Northern Wisconsin
Riding Since: 1985
Default Fox Shock Rebuild
So I am new to the whole Fox shock rebuild thing. I typically put around 500-1000 miles a year on my sleds. Do the shocks really need to be rebuilt every year or every other? What wears out in them? Seems like a lot of hassle and cost. Is there another option? Could I go longer?
99ZRGuy is offline   Reply With Quote
Old 01-15-2020, 11:30 PM   #2 (permalink)
Newbie
Current Sled(s): None :(
Previous Sled(s): 74 340 El Tigre F/A, 01 RMK 800, 97 Ultra SPX, >dozen others
Riding Since: 19
I rebuilt a lot of Fox shocks back in the day. If the nitrogen and/or oil leaks out of them, they can't do their job as a shock. To really tell their internal condition, at the very least you'll need to measure the nitrogen charge. If the gas pressure is found to be low, you should rebuild them.
oldsledsrcool is offline   Reply With Quote
Old 01-16-2020, 08:35 AM   #3 (permalink)
baydog's Avatar
Current Sled(s): 2013 TZ1 Turbo, 2020 Rene 900ace,2015 XF 8000
Previous Sled(s): Turbos and Panteras
19-20 Mileage:
18-19 Mileage: 2850
16-17 Mileage: 3280
Riding Since: 70's
Most riders spend far too much time and money rebuilding shocks. They would be far better off having them revalved in the first place and only rebuilding every three or four thousand miles.....Once you have ridden a sled set up with shock valving by a pro, for you, you will have all your sleds done before they hit the snow.
Hp&Torque likes this.
baydog is offline   Reply With Quote
Old 01-16-2020, 08:52 AM   #4 (permalink)
Favorite Riding Area: Ma.
19-20 Mileage:
18-19 Mileage: not much
Riding Since: 70 s
Probably a good idea to go through them every 2 years if generally trail riding. Not only the nitrogen charge slowly leaks, shocks absorb water to. The shock oil breaks down over a season and can increase wear and hurt performance. I've see what happens to a shock that collects water inside....not pretty. Its too bad shock companies like ohlins aren't involved in producing snowmobile shocks for sled manufactures, we wouldn't need such frequent rebuilds.
too slow is online now   Reply With Quote
Old 01-16-2020, 09:03 AM   #5 (permalink)
ArcticGabe's Avatar
Current Sled(s): 2016 ZR6000 137
Previous Sled(s): 12 XF1100, 03 Firecat F5
19-20 Mileage: 1750
18-19 Mileage: 1900
17-18 Mileage: 1650
16-17 Mileage: 1300
The seals on a shock are not perfect. They are required to keep the nitrogen and oil in and the water out. But heat/cold cycles cause expansion and contraction of parts, they are a moving part, and in a rather abusive environment, all this adds up to imperfect seals.
Since shocks lose their capability very slowly, it is often hard to tell that they are going bad. Not until you have them rebuilt is the difference noticeable.
So in general, it's up to you. Do you ride such that you require your shocks in tip-top condition for every ride? If so, every 1000 miles is not a bad rule. If after 1000 miles it still doesn't feel too bad to you, well keep riding it. Every 3000 miles is not out of the question.
To baydog's point, getting your shocks re-valved for your weight and riding style will give you the optimum solution, but that is a one-time deal. You'll want this done by a professional shock tuner, not just a dude with a nitrogen tank who charges your $25/shock.
Just don't sweat it too much...
Gabe out.
ArcticGabe is offline   Reply With Quote
Old 01-16-2020, 09:07 AM   #6 (permalink)
jacksost's Avatar
Current Sled(s): 98 XC 700 98 XC 600 97 XLT LTD 80 TX,C,&L
Previous Sled(s): No many to list
Favorite Riding Area: WNY
Riding Since: 2004
I send all of my shocks to The Shock Shop in Becker MN, good quality work and quick turn around time.
jacksost is offline   Reply With Quote
Old 01-17-2020, 08:29 PM   #7 (permalink)
Member
99ZRGuy's Avatar
Riding Since: 1985
Thanks for all your advice. My shocks are on year 2 and seem ok. I might look to have them customized if i Havre to pull them out again anyway after this season. Someone mentioned a place in MN. Is the going rate about $50 each?
Old 01-17-2020, 08:46 PM   #8 (permalink)
baydog's Avatar
19-20 Mileage:
18-19 Mileage: 2850
16-17 Mileage: 3280
Riding Since: 70's
Carver performance in Fosston,Mn. has done all my shocks for years..... Mike Carver knows fox shocks as well as anyone. Might be a bit more than $50 for a revalve......
Old 01-17-2020, 09:15 PM   #9 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
Good to hear. They just built me a shock today.
jacksost likes this.
PPP Charter Member #2
Old 01-17-2020, 11:24 PM   #10 (permalink)
Deephaven's Avatar
Current Sled(s): 2017 Assault
Favorite Riding Area: Closest place with snow
Depends on what general trail riding means to whomever reading. When did you do yours last? What did it cost?
Deephaven is offline   Reply With Quote
