99 vs. 02 ZR Rear Suspension - HCS Snowmobile Forums
Old 01-14-2020, 10:28 AM   #1 (permalink)
Member
99ZRGuy's Avatar
Current Sled(s): 1999 ZR 500 EFI
Previous Sled(s): 1999 ZRT 600
Favorite Riding Area: Northern Wisconsin
Riding Since: 1985
Default 99 vs. 02 ZR Rear Suspension
All, looking to see if someone can explain the differences between my 1999 ZR rear suspension and 2002 ZR rear. I have found a lot of info on the 02 stuff but not much on my 99. Mainly looking for setup tips and part interchangeability as mine seems to sag as others have complained about here. I will likely be changing the rear springs to start.
99ZRGuy is offline   Reply With Quote
Old 01-14-2020, 12:50 PM   #2 (permalink)
Current Sled(s): "Agri-vator"
Minimal to no difference. (Very much the same as whats found in modern cats, essentially). The 02 has coupler blocks in the rear, that most guys removed anyway. Having both of your shocks rebuilt, replacing the springs, and inspecting the skid in general for wear, is where you would start if you are looking to improve the ride.
Old 01-14-2020, 02:20 PM   #3 (permalink)
Member
99ZRGuy's Avatar
Riding Since: 1985
Thanks for the response. I thought that might be the case but did not want to assume. The sled was basically torn completely down and rebuilt bolt by bolt by the last owner. Very clean unit but the rear suspension seems soft to me. I had a 99 ZRT6 that rode better and I assume that had a similar if not the same suspension as mine. Again, assuming the rear springs are the OE springs, I am going to replace them first. The shocks were done last year. I have the fox shocks but can't say I'm a big fan of pulling these things out every couple years to rebuild.
Old 01-14-2020, 10:56 PM   #4 (permalink)
feelthethunder's Avatar
Current Sled(s): 02 T-Cat - 00 T-Cat - 01 Pantera 1000
Previous Sled(s): Wildcat 650/700 ElTigre 5000FA - 6000AFS
Favorite Riding Area: Whiteshell/Ontario
19-20 Mileage:
18-19 Mileage: 1480
17-18 Mileage: 1280
16-17 Mileage: 1225
Riding Since: 1979
They are essentially the same but not too much interchangeable parts. Wheels were different, spring and shock mounting was different. Also on my 99 there was no rail brace which I added. Ride quality will be mostly the same. I did remove my coupler blocks from my 02 T-Cat.
~~~Keep The Rubber Side Down!~~~
feelthethunder is offline   Reply With Quote
Old 01-15-2020, 01:35 AM   #5 (permalink)
derrek's Avatar
Current Sled(s): 18 El Tigre 8000,02 Zrxf 800 EFI,87 Jag,04 F7
Previous Sled(s): 75 John Deere JDX 8,99 ZL600 EFI,16 ZR6000
Favorite Riding Area: ditches in nw minnesota
19-20 Mileage: 150
18-19 Mileage: 1000
17-18 Mileage: 500
16-17 Mileage: 1000
Riding Since: 1987
coupled sus 02 un coupled 99
Join a club and help keep our sport ALIVE!!!
A Sled is only as safe as the operator!!!!!
derrek is offline   Reply With Quote
