Choosing between 2 zrs - Page 2 - HCS Snowmobile Forums
Like Tree3Likes
Old 01-11-2020, 08:58 AM   #11 (permalink)
Current Sled(s): ZRs & 500 OM Dart-- ( Ice Racer)
Previous Sled(s): Like a Zillion, all brands
Favorite Riding Area: My area when there is snow
Riding Since: 1967
Ha, Yea I just happened to have my pipe off fixin my ele start when you said that. So I looked. Did get the starter fixed after running tests on the whole system. Just some corrosion where the power cords hook to the solenoid. So I'm all ready for snow & its raining
MiModRacer is offline   Reply With Quote
Old 01-11-2020, 11:27 PM   #12 (permalink)
zr656's Avatar
The 800 will handle significantly better. The rear suspension on 02 was coupled, 01 was not. They drive very differently.
zr656 is offline   Reply With Quote
Old 01-12-2020, 03:09 AM   #13 (permalink)
derrek's Avatar
Current Sled(s): 18 El Tigre 8000,02 Zrxf 800 EFI,87 Jag,04 F7
Previous Sled(s): 75 John Deere JDX 8,99 ZL600 EFI,16 ZR6000
Favorite Riding Area: ditches in nw minnesota
19-20 Mileage: 2000
18-19 Mileage: 1000
17-18 Mileage: 500
16-17 Mileage: 1000
Riding Since: 1987
had both still have the 800 keep the eight you dont have to use all the hp if you dont want to and it will get better gas milage
Join a club and help keep our sport ALIVE!!!
A Sled is only as safe as the operator!!!!!
derrek is offline   Reply With Quote
Old 01-13-2020, 09:42 PM   #14 (permalink)
CRASH74's Avatar
Current Sled(s): '13 XF 800 High Country
Previous Sled(s): '07 Xfire 800, '08 Xfire 800 Sno Pro
Favorite Riding Area: somewhere with snow
Riding Since: 1979
Keep the 800, you'll thank yourself later. I had a 600 cross country and figured that's be enough sled for me when I bought it, I never kicked myself for buying it but I often wished it was an 800 instead.
CRASH74 is offline   Reply With Quote
Old 01-27-2020, 11:12 AM   #15 (permalink)
Newbie
Well the 600 sold and the 800 didn't so I'm keeping the 8
Not real familiar with boots and reeds to I'll have to do some searching on those. Thanks again, looking forward to it.
jefmil is offline   Reply With Quote
Old 01-27-2020, 02:23 PM   #16 (permalink)
SHOOT2KILL2's Avatar
Current Sled(s): 2017 Viper
Previous Sled(s): 52
Favorite Riding Area: C. Wi
Riding Since: 1969
The absolute first thing you do is pull the bellypan off and inspect the lower coolant hose...They have a tendency to rub on the frame and eventually start to leak coolant...Most times this happens while riding and if you don't catch it, you will cook the motor...
SShooterZ likes this.
52 sleds...200,000+ miles...$1,000,000.00 spent on the sport since 1969...
SHOOT2KILL2 is offline   Reply With Quote
Old 01-27-2020, 03:20 PM   #17 (permalink)
Current Sled(s): "Agri-vator"
easier to remove the exhaust and look down, Imo, to inspect those hoses. Front of the engine, close to the crank case, the one is a drain and the other wraps up over the recoil. Inspect them good.
Old 01-30-2020, 03:41 PM   #18 (permalink)
Newbie
Coolant hose looks fine, considering adding the oem temp gauge but 141 bucks seems high for the 1639-217 kit from country cat. Can't post links yet, lol what is this 2001?
Boots look ok to me also. Do i need to check the reeds at some point? I'm not sure how to get at them at first glance.
I'm going to pull and clean p valves this weekend and have been reading about either a shim kit or grinding down the edges so they don't contact the piston. Worth doing?
Getting 115-ish psi on both, using a crappy compression tester. I'll get my hands on a better one this weekend.
Old 01-30-2020, 03:49 PM   #19 (permalink)
Newbie
Boots
ID:	2072826   Click image for larger version
Old 01-31-2020, 04:25 PM   #20 (permalink)
Newbie
Cheap gauge left, decent gauge right.
