2002 ZR 600 EFI Lost PTO cylinder - HCS Snowmobile Forums
Like Tree1Likes
  • 1 Post By raylag64
Old 01-06-2020, 11:47 PM   #1 (permalink)
braaap24_7's Avatar
Current Sled(s): 85 SRV 540, 01 SXR 600 Triple, 02 ZR 600EFI
Previous Sled(s): My Uncle's
Favorite Riding Area: Northern WI
19-20 Mileage: ~400
18-19 Mileage: ~250
17-18 Mileage: ~300
16-17 Mileage: 285
Riding Since: 2011
Default 2002 ZR 600 EFI Lost PTO cylinder
I was out, beginning a ride today and lost power in the PTO cylinder. Ill give you the trouble shooting I have done so far, plug color, and settings on the machine, and overall condition
1) I unplugged the magneto spark plug and the machine would not start, I then unplugged the PTO spark plug and it started
2) Plug was wet, and appeared to have some level of aluminum paste on it, or oil, or something
3) Ethanol switch is disconnected for using unleaded fuel with up to 10% ethanol.
4) carb boots appear to be cracked, but did not leak this fall when I tested them
5) I run it on 89 octane, $4+ is simply too steep for me to pay for 91. It has run fine like this for years
6) I run Mystic lubricants 2 stroke injection oil
The question is: Did I blow a cylinder or did I likely (hopefully) loose ignition? The sled has about 5k on the odo
"I mean, it ain't rocket surgery..."
braaap24_7 is offline   Reply With Quote
Old 01-06-2020, 11:57 PM   #2 (permalink)
vince's Avatar
Current Sled(s): 2018 El Tigre 8000
Previous Sled(s): 16 ZR 6000 Ltd 14 ZR 8000 Ltd 12 F1100 T 11 F8 EXT 09 Z1T
19-20 Mileage:
18-19 Mileage: Lots
16-17 Mileage: Not enough
Riding Since: 1969
Check the compression, although the miles are low on the sled what folks forget about is the crankseals leaking and I would bet dollars to donuts that is what caused your issue, you did mention there was aluminun paste on the plug.
MORE MILES EQUALS MORE SMILES
vince is offline   Reply With Quote
Old 01-07-2020, 12:10 AM   #3 (permalink)
braaap24_7's Avatar
19-20 Mileage: ~400
18-19 Mileage: ~250
17-18 Mileage: ~300
16-17 Mileage: 285
Riding Since: 2011
@vince
I was getting ready to do the "fart on finger test" but the hood cracked me across the head so i just put it away, I dont have a compression tester either so thats the other part of the issue.
As far as the aluminum paste on the plug, I didn't touch it (idk what I was thinking) but it was wet and almost sludgie. Kinda looked like carbon and aluminum mixed together, but I didn't look close enough and I can't say for sure.
Old 01-09-2020, 10:56 AM   #4 (permalink)
raylag64's Avatar
Current Sled(s): 2010 F8 Limited
Previous Sled(s): '03 ZL550 '04 700EFI Sabercat (15,000 mls +)
Favorite Riding Area: Northern ME
19-20 Mileage:
18-19 Mileage: 1
17-18 Mileage: 1400
16-17 Mileage: 1200
Riding Since: 2004
Harbor Freight for a compression test kit $20-25
Spark tester is cheap too.
Had issue with my 700 Sabercat. Run all day long with top speed of 50, junk coil. week spark.
braaap24_7 likes this.
raylag64 is offline   Reply With Quote
Old 01-11-2020, 01:54 AM   #5 (permalink)
braaap24_7's Avatar
19-20 Mileage: ~400
18-19 Mileage: ~250
17-18 Mileage: ~300
16-17 Mileage: 285
Riding Since: 2011
I really hope it is a coil. I have to make a harbor freight run in the next couple days anyhow so Ill pick one up assuming I remember. Ill keep this tread posted as to what I find.
Compression is supposed to be 100-120, right?
Old 01-11-2020, 08:06 AM   #6 (permalink)
SShooterZ's Avatar
Current Sled(s): 2017 ZR8000 SP
Previous Sled(s): 2003 Z440 SP | 2002 ZR600 | 2000 ZR600 | 1996 580EXT EFI
Closer to 120+ IMO. 100 is getting to rebuild time depending on the compression tester.
SShooterZ is offline   Reply With Quote
