2000 mxz 700 no lights or rpm gauge. - HCS Snowmobile Forums
ZX Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 01-29-2019, 03:20 PM   #1 (permalink)
Member
Default 2000 mxz 700 no lights or rpm gauge.
I have a 2000 mxz 700. It runs great and always starts. The lights went out and my room gauge doesnt work. I checked wires and fuses. Everything checks out but still no lights or rpm. Anybody have an idea? Could it be the stator?
Gordiek88 is offline   Reply With Quote
Old 01-29-2019, 05:14 PM   #2 (permalink)
Gaboon1's Avatar
Favorite Riding Area: On snow and ice
Riding Since: 1983
I would lean towards the voltage regulator.
Gaboon1 is offline   Reply With Quote
Old 02-09-2019, 01:36 PM   #3 (permalink)
Everything you mention as not working is on the lighting circuit. A short to ground in the taillight wiring or any wire that feeds from the lighting coils could cause everything to quit. I had a faulty electric face shield cord once that killed everything. It could also be a stator problem. Have you checked the stator resistances with an ohmmeter?
retiredpop is offline   Reply With Quote
Old 02-09-2019, 05:33 PM   #4 (permalink)
Member
I tore the sled apart and took stator put. I ohmed tested it and everything was fine. I put it all back together and cleaned the voltage regulator and made sure it was getting good ground. I fired it up and lights worked for about 10 seconds and then nothing again.
Old 02-09-2019, 05:55 PM   #5 (permalink)
Member
I just ohmed tested the stator again and now it says O.L. could the stator have a bad spot in it? I'm confused at this point.
Old 02-09-2019, 06:41 PM   #6 (permalink)
I would lean more towards an intermittent open where the external wires are connected to the coil windings. It's possible you have a cold solder joint in there. Have a close look or take a soldering iron and heat up any solder joints if you can see any.
Old 02-11-2019, 06:43 AM   #7 (permalink)
Member
I have a new stator coming in Tuesday. I will let you know if that fixes the problem! I appreciate the help.
Old 02-11-2019, 01:00 PM   #8 (permalink)
Newbie
Same problem on my 2002 700 Legend. Relay mounted near the fuses.
Easy fix, mine would work if I gave it a tap, now has been replacedp
jfh57 is offline   Reply With Quote
Old 02-11-2019, 07:36 PM   #9 (permalink)
Member
Mine doesnt have any relays or fuses.
Old 02-16-2019, 01:31 PM   #10 (permalink)
Member
The stator fixed the problem. Then a day later my coil shit the bed. Fml
Similar Threads
Engine filling with gas bob7 XC 14 12-17-2018 10:38 AM
Sled floods when shut off. Kilabeez00 XC 23 02-13-2017 06:41 AM
2 new Gates GForce Belts, 40G4683, cat 0627012,0627020 mikesnowman Arctic Cat 3 01-27-2017 12:31 PM
NS1 Gauge System App Preview izzni ProCross (2012 - ) 11 10-07-2016 10:28 AM
NS1 Gauge System App Preview izzni Polaris General Discussion 0 07-24-2016 12:47 AM
