Starting issue on 700 Classic. - Page 3 - HCS Snowmobile Forums
Like Tree30Likes
Old 11-28-2019, 09:32 AM   #21 (permalink)
Favorite Riding Area: Ma.
19-20 Mileage:
18-19 Mileage: not much
Riding Since: 70 s
Originally Posted by sayatodaU.P.eh? View Post
I've been doing automotive electrical repair for 20+ years. When it comes to lead acid and agm batteries:
12.6 = 100% state of charge (SOC)
12.5 = 75% SOC
12.4 = 50% SOC
12.2 = 25% SOC
Sled batteries are no different.
I was reading through my booklet on the tester i have. Your correct also. Says some battery manufactures state that 12.6 volts can be interrupted as fully charged.
NYH1 likes this.
too slow is online now   Reply With Quote
Old 11-28-2019, 09:34 AM   #22 (permalink)
19-20 Mileage:
Riding Since: 70 s
Forgot to mention this testing a battery at rest.
NYH1 likes this.
Old 11-28-2019, 09:45 PM   #23 (permalink)
Current Sled(s): Polaris Classic's; son '01 600, me '04 700.
Previous Sled(s): Ski Doo's; '87 Stratos,'94 MX470, '98 Formula 500.
Favorite Riding Area: CNY and Tug Hill NY.
Riding Since: 1992
Originally Posted by patrioticinnovations View Post
I suggest a quick spark test while cranking with starter, not rope. If there isn't any spark, fix that first.
No spark at the plugs while turning it over with electric starter. It still seems to be turning over slow.
Starts right up with pull starter.
NYH1.
NYH1 is offline   Reply With Quote
Old 11-28-2019, 10:07 PM   #24 (permalink)
HCS Advertiser
northstarrick's Avatar
NYH1.
you need to put the positive side of the multi tester on the positive terminal at the starter. and black to ground side of the battery. dc voltage and see what the voltage is once e-start is tried. this will take two people. my bet is the brushes or armature in the starter motor is toast? drawing to many amps which also pulls voltage down. it should not drop below 12 volts while starter is turning over.
NYH1 likes this.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 11-29-2019, 07:19 AM   #25 (permalink)
patrioticinnovations's Avatar
19-20 Mileage:
18-19 Mileage: 849 so far
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
There should still be spark, even turning over slow IMO.
Disconnect the black ground wire at the switch and check again with e-start for spark.
If there is now spark, the switch is grounded in the start position and must be replaced.
The starter problem is likely due to a worn out bushing behind the pinion gear. This can be replaced. Item #8 and 9 in pic.
https://www.partspitstop.com/oempart...-4988458845e07
NYH1 likes this.
Old 11-29-2019, 09:49 AM   #26 (permalink)
19-20 Mileage:
Riding Since: 70 s
I've seen cases where the battery voltage is so low that it barely turns over the motor or turns it so slowly you'll see no spark or an extremely weak one.
NYH1 likes this.
Old 11-29-2019, 03:35 PM   #27 (permalink)
Riding Since: 1992
I wasn't able to put my Fluke meter on the pos. (+) side of the starter motor and the neg.(-) side of the battery while cranking with the electric starter. My son isn't home. So I'm on my own right now, maybe later.
I did however put my Fluke directly on the battery while cranking the electric starter and the voltage drops down into the mid 10 volt range.
NYH1.
Old 11-29-2019, 05:54 PM   #28 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
Riding Since: 1959
Use long test leads with alligator clips on the ends..
Old 12-01-2019, 10:50 PM   #29 (permalink)
Riding Since: 1992
Still haven't had time to mess with the electrical starter issue. Maybe tomorrow after I'm done plowing I'll have some time to.
We finally got to ride it today so that was good.
Trying to find my son an Edge chassis XC or Classic. Last season there were a ton of 500 and 600's for sale, 700 and 800's were few and far between. So far this season there are a ton of 700's, followed by 800's, a few 500's and hardly any 600's. Probably going to get him a 700 if I can't find a good 600 soon.
NYH1.
Old 12-07-2019, 09:33 PM   #30 (permalink)
Riding Since: 1992
I think I'm going to need a new starter. Mine appears to be missing the return spring assembly and cover that go's over the end of the starter. The starter gear is staying engaged in the teeth on the clutch. It pops right out with the slightest pull on the recoil.
I think the gear got caught on the clutch teeth while trying to start it and it caused the other damage.
NYH1.
