PSI Modblasters - XLT - Main Jet Question - HCS Snowmobile Forums
Like Tree2Likes
Old 06-14-2019, 08:00 AM   #1 (permalink)
Member
Default PSI Modblasters - XLT - Main Jet Question
Hi guys, posting this for a friend.
He bought a 93 XLT, the sled was equipped with some PSI modblaster pipes. While cleaning the carburetors, I noticed that the main jetting was 220 for Mag and Center, while the PTO end had a 230. Can anybody verify this is correct? I assume that usually the PTO end gets the richest jetting, but have heard conflicting information regarding which cylinder gets the fatter main jet - thanks for any info!
123kielbasa is offline   Reply With Quote
Old 06-14-2019, 11:49 AM   #2 (permalink)
Favorite Riding Area: Ma.
19-20 Mileage:
18-19 Mileage: not much
Riding Since: 70 s
Its basically what we ran for aaen pipes in the 93 xlt that had 34 mm carbs. Instead of the 230 on the pto cyl., we ran a 220. Lot depends on the height raised on air intake hood over the hood itself, that leads to the air box opening.
On another note those pipes are friggin loud....hopefully your buddy stays off any private trails with this sled.
Old 06-14-2019, 11:54 AM   #3 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
richer and fatter mean the same thing.
PPP Charter Member #2
Old 06-14-2019, 12:45 PM   #4 (permalink)
Member
correct, which cylinder gets it?
Old 06-14-2019, 12:57 PM   #5 (permalink)
19-20 Mileage:
Riding Since: 70 s
In your case its the pto...clutch side. I had to run a main jet size richer for the pto cyl. on my 95 xcr 600 when it ran triple pipes, seem to be a characteristic of those 600 mono blocks if running triple pipes. The earlier 580 didn't.
Old 06-14-2019, 02:13 PM   #6 (permalink)
Member
but this is a 580.....it's a 1993 XLT..........soooooo which side gets the fatter main?
Old 06-14-2019, 08:13 PM   #7 (permalink)
19-20 Mileage:
Riding Since: 70 s
Whatever side cyl appears to run leaner.
Old 08-25-2019, 05:24 PM   #8 (permalink)
xcr 600 modi's Avatar
Current Sled(s): DECKER BIG BORE
Previous Sled(s): lots of tripple polaris's cat ,doo and yamaha.
Favorite Riding Area: Cape Breton Highlands
Riding Since: 1980
There's nothing written in stone about this just base guide line ,,check piston wash and plug color
xcr 600 modi is offline   Reply With Quote
Old 08-26-2019, 07:35 AM   #9 (permalink)
northstarrick's Avatar
the mono block xlt motor usually needs the pto cylinder richer. this is the hottest cylinder in this motor. furthest from the water pump. it's the ctr, cylinder on ultra's, 800 xcr. but like was said not every motor is the same. piston wash, plug reading, and ex. gas temp should be checked and jetting adjusted on the findings.
too slow likes this.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 08-26-2019, 09:45 AM   #10 (permalink)
Brand loyal, not brand blind
racerdave's Avatar
Current Sled(s): 2020 AXYS Indy XC850 137 2015 Indy 600sp
Previous Sled(s): 2015 AXYS SWB800 Pro S
Favorite Riding Area: Vilas Co. Wisconsin
19-20 Mileage:
18-19 Mileage: 1900
17-18 Mileage: 1,500
16-17 Mileage: 1,000
Riding Since: 1975
The PTO cylinder also has the most direct shot of air on the airbox
northstarrick likes this.
First charter member of the PPP.
Member of:
Illinois Valley Winter Sports Club, Marseilles ,Il.
Sayner Barnstormers, Sayner, Wi.
racerdave is offline   Reply With Quote
