TECH TIPS FOR EDGE 800 - HCS Snowmobile Forums
Old 11-16-2009, 02:54 AM   #1 (permalink)
kraven's Avatar
Current Sled(s): 2007 DRAGON 700, 4500 MILES
Previous Sled(s): 2002 EDGE-X 800,6400 miles, 1999 XCR 800
Favorite Riding Area: YELLOWSTONE
Riding Since: 1985
Talking
I had a 2002 EDGE-X 800 that was EXTREMELY WELL dialed in for a "Stocker" 6400+ MILES RIDDEN, NEVER BURNED IT DOWN, NEVER BROKE.WALKED away from my (3) other buddy's 800's BIG TIME !!
BEST BANG FOR THE BUCK MODS
HOLTZMANN ATAAC FUEL COMPENSATOR, spot on jetting ALL the time $ 245.00 from www.holtzmannengineering.com mileage increased from 10.5 m.p.g. to approx 13 m.p.g. noticeably more responsive on bottom end and mid-range.
SLP HI-Comp heads, for use with 91 octane ($330) improved bottom end & mid-range GRUNT!!
STUDS: I ran (168) WOODY's Megabite square tip studs in the track, traction is where it's at, all the power/clutching in the world is useless if you're not coupled to the ground.
almost FREE MODS
PRIMARY CLUTCH
1) Check your belt to primary sheave side clearance, should be .010" to .015" w/NEW belt, mine was .070" from the factory.
2) Install a new primary clutch spring @ the start of every season. (approx $31.00)
3) ALMOND/red stripe SPRING (POLARIS part # 7041988)
a) 66 gram stock weights, OR
b) SLP's 68 gram MTX'S with 3 grams in the tip, plus 2 to 3 grams in the middle, slight improvement over 66's
4) Send your primary clutch out to have it balanced. Since these sleds have a bad rep for wasting the crankshafts, put a dial indicator on the crank snout (remove primary) and periodically check the run-out. 002"-.0025" is the MOST I would want to see. Made a NOTICEABLE improvement in smoothness and extends crankshaft and clutch life, they drilled 8-9 lightening holes in mine, that's how far off it was from the factory!! SLP and others charge only $35.00 for this service. Do this after you've set the belt to sheave clearance.
SECONDARY
Button Secondary
1) Install a new secondary clutch spring @ the start of every season. (approx $31.00)
2) Stock SOLID BLUE Secondary Spring with R-49 Helix, (POLARIS Part # 5133023)
3) Replace the (3) little plastic wear buttons, they're approx $ 1.00 each
Roller Secondary TSS-98 or TSS-04
1) Install (1) DELRIN washer under the spring cup in your secondary clutch (less than $5.00)
2) Helix 70-42.46 duration SLP part # 50-90
3) Secondary spring 140/200 Red/Dark Blue SLP part # 50-4
The old style button clutch was faster on top end
BOTH PRIMARY & SECONDARY
1) Align your clutches (offset, center to center, and check for engine "crooked"), mine and my bud's were off!!!! You may have to shim behind the rear engine bracket(s) to get it perfect. Use thin Chevrolet style starter shims available @ Auto Parts stores under the “HELP” brand.
2) Lightly sand both primary and secondary clutches w/180 grit perpendicular to the way the belt rides and wipe down w/lacquer thinner.
3) Wash/scrub (plastic bristle brush) your BRAND NEW belt w/soap & hot water, and let dry overnight, sounds weird, but it removes the "mold release" compound that would otherwise would get smeared all over your nice clean clutches.
4) I prefer the #3211087 belt, it's a CLOSE TOLERANCE version of the #3211080
ENGINE LIMITERS
1) SLP push engine limiter MAG side ($47.95) SLP part # 23-50 (E-Z 20 minute installation, only one hole to drill into your aluminum bulkhead)
2) WMS Engine torque arm, P.T.O. side, in front of the engine. ($82.95) sold also by SLP part #23-53 (E-Z bolt-on installation, no holes to drill)
T.P.S. CHECKING & RE-SETTING PROCEDURE (easier than you think)
1) Check/reset your T.P.S. Pretty E-Z to do, build a tester for $10. Make sure you have EXACTLY 5.0 VOLTS FOR TESTING PURPOSES. Don't overlook this! Look at the PRO-X section @ the top, there's a "sticky". All the info is there.
2) For those that don't want to build a T.P.S. tester, I just purchased a T.P.S. tester (manufactured by KENT-MOORE / SPX) from my local POLARIS dealer for $48.76 PART # 2201519-A Comes with the pigtail, 2 plug ends, 5 volt regulator, harness. All you need then is a 9-volt battery and a voltmeter. Works on sleds, ATV's & Rangers
3) The EDGE's get set at WIDE OPEN THROTTLE, spec is 4.0-4.1 volts.
4) Move the throttle gradually from idle to full throttle and back down again while watching the needle on your analog style voltmeter as you want it to move gradually in synch with the throttle, an erratic needle reading indicates a faulty T.P.S. and replace if necessary.
CHAIN-CASE and GEARS and CHAIN TENSION
1), Stock factory gearing is 25/40, change the bottom gear to (41), same 76 pitch chain still fits, less of a dog leg, acceleration improves a little, no loss in top end.
2) Check your chain tension in the chain case, adjust it to where the chain will almost touch the backside of the case w/finger pressure. While you're in the chain case place a metal straight edge onto the sprockets to make sure they're EXACTLY in line. Shim with thin 1" I.D. shims available from auto cylinder head shops, used as valve spring shims. Same shims also fit onto the secondary shaft for getting the offset "dialed in"
EXHAUST VALVES
1) Clean your exhaust valves AND bores, their dirtier and gummier than you think. While you're there check the bellows for small rips and tears.
2) The original exhaust valves are aluminum, which were prone to failure and severe engine damage could result. Then they went to titanium, and the latest and greatest are Stainless Steel, identifiable by the heavier weight and "relief cut outs"
3) The original exhaust bellows were blue, the latest and greatest bellows are Orange in color.
4) POLARIS part # 2202838 (order two kits) includes stainless valve, orange bellow, and 1 exhaust spring, it's only enough parts for one cylinder
OTHER: OIL PUMP CALIBRATION, TRACK TENSION, MAINTENANCE:
1) Check your oil pump calibration , mine was 38:1 stock, 55:1 to 60: 1 is better.
2) Run your track looser that specs, approx 1" to 1 1/2" sag just sitting there on the stand.
COLD START TIP
On the night before, use the choke to "kill" the engine instead of the switch. The fuel dilutes/washes the oil off of the cylinder wall and makes starting the engine on a cold morning so much easier.
SKI's
1) Check ski alignment, 1/8" toe out is preferred
2) Check out www.bergstromskis.com Very informative site, especially the info on shimming the stock skis to eliminate the "darting" issue instead of purchasing a $350.00 pair of skis
DEBATABLE
SLP Big Air Kit and Flo-Rites, ($42.95 + (2) X $19.95= approx $83.00) E-Z to install , I just didn't notice any difference that's all. However, they do cause a noticeable increase in intake noise, if you like your sled quiet, don't do this mod.
WASTE OF $$$$$ I.M.O.
1) V-Force reeds, maybe slightly more responsive on it's best day, V-force's were definitely NOT worth the $258.00 and installation time!!
2) Aftermarket Silencers, even with the weight reduction, they'll slow you down and for those of you who think it's "cool" remember that next time you come across a "trail closed" sign
3) Boost bottles
4) 8" rear wheels
5) Anti-ratchet drive wheels
HAVE A GREAT SEASON!!!!!!!!!
Byron Circa 1984, '72 Dodge Colt, Full Tube Chassis, Strange Struts, 4 Link, Koni Coil Overs, 15" x 33", Mild 426 Wedge, Torqueflite, Lexan windows, Dzus Fasteners & Quick Release Pins Everywhere, All Polished Aluminum Interior, Fuel Cell, "Weld" Superlite Wheels, 2220 lbs. w/Driver, Leaving the Starting Line Carrying the Front Wheels and Being Plastered into the Back of the Seat and Stopping it from 137+ m.p.h. by Pulling the Parachute-PRICELESS!!!
Byron, 1982, 71 Dodge Demon, 426 Wedge, Aluminum 4-speed, Narrowed Dana 4.56, Alston Bars & Floater, SS Springs, 12.20" x 31.25" Firestones, Polished Centerlines, 10 pt Rollcage, Aluminum wheel tubs, Fiberglass fenders, hood, & decklid
1986 INDY 600 LIMITED EDITION CHROME PACKAGE [/b]91 M.P.H. @ RADAR RUNS 1000' (6000+ MILES) TRAILERED TO YELLOWSTONE IN 1988
kraven is offline   Reply With Quote
Old 11-16-2009, 09:52 PM   #2 (permalink)
highrolla7's Avatar
awesome! Thanks for the info. Printing it out now
2002 Polaris 800 Edge X Sonic Blue, 136 track, SLP Pipe/can, SLP Cheater Heads, V Force Reeds, Boost Bottle, 3" Riser, Rolling on Big Wheels, blah, blah, blah
*update* Installed PERC reverse, completely rebuilt 800 motor (bottom/top), Autometer 4332 Mech temp gauge
highrolla7 is offline   Reply With Quote
Old 11-17-2009, 11:02 AM   #3 (permalink)
Thanks a bunch! Just what I was looking for! This deserves a STICKY!
Texashorsepower is offline   Reply With Quote
Old 11-17-2009, 11:33 AM   #4 (permalink)
polaris800rules's Avatar
Current Sled(s): 2015 MX Z SPORT 600
Previous Sled(s): 2006 Firecat F-7 SNO PRO 2003 Edge X 800
Favorite Riding Area: The river
19-20 Mileage:
18-19 Mileage: 350
Riding Since: 1986
PRIMARY CLUTCH:
4) Send your primary clutch out to have it balanced. Since these sleds have a bad rep for wasting the crankshafts, put a dial indicator on the crank snout (remove primary) and periodically check the run-out. 002"-.0025" is the MOST I would want to see. Made a NOTICEABLE improvement in smoothness and extends crankshaft and clutch life, they drilled 8-9 lightening holes in mine, that's how far off it was from the factory!! SLP and others charge only $35.00 for this service. Do this after you've set the belt to sheave clearance.[/b]
Great stuff Kraven. One Question tho. I am getting a new Primary this winter from a dealer. A brand new one. Do they come balanced? Or should I just get a rebuilt clutch and have someone balance it for me? I just had a new crank put in 500 miles ago.
2006 Firecat F7 Sno Pro Stock
2003 Edge X 800, 1.25 Ripsaw, Edge Skid,Boyesen Power Reeds, Fly Snowcross Handle Bars
Powermadd Boost Bottle, Rumble Pack Silencer
2001 Phazer, bored to 510. V-force 3's
1999 XC 700, EPI Clutch Kit, MBRP Silencer(first one to have in my region)
1998 Phazer, DG Pipe
1996 ZRT 600, Black Magic Triple Pipes
1996 Trail RMK 488, Stock
1993 RXL 650, PSI Triple Pipes/Chip
1992 Yamaha Bravo 250
polaris800rules is offline   Reply With Quote
Old 11-17-2009, 12:50 PM   #5 (permalink)
kraven's Avatar
Riding Since: 1985
Talking
Great stuff Kraven. One Question tho. I am getting a new Primary this winter from a dealer. A brand new one. Do they come balanced? Or should I just get a rebuilt clutch and have someone balance it for me? I just had a new crank put in 500 miles ago.[/b]
The clutches are balanced from POLARIS, just like they are on the sleds.
Problem is they're not perfect.
Every "Factory balanced" POLARIS clutch that I've sent out has been re-balanced, with lightening holes drilled into it.
Contact Don (XCR 1250) here on H.C.S. and he'll take care of the clutch balancing for you
Old 11-22-2009, 01:05 AM   #6 (permalink)
raysxc700's Avatar
Current Sled(s): 02 edgeX 144 08 D7 sb
Favorite Riding Area: U,P
Riding Since: 1997
i have read on here 7800 for 800's
what should my 02 800 run at
144in track 23/40 gearing stock motor
clutching ideas i want a low engagement
1997 xc 700
raysxc700 is offline   Reply With Quote
Old 11-22-2009, 02:09 AM   #7 (permalink)
kraven's Avatar
Riding Since: 1985
Talking
clutching ideas i want a low engagement[/b]
Ray,
7700-7800 R.P.M. is the max h.p. # on the dyno, as a general rule you want to run approx 200 r.p.m. higher in the real world, so 7900-8000 r.p.m is what I would target.
The spring (Almond/red) & weight combo that's posted at the top is a relatively lower trail friendly engagement.
I typically do hard trail riding, I need it to be reliable and trail friendly, and yeah, it's gotta be faster that my bud's with the identical sled.
Old 11-29-2009, 09:38 PM   #8 (permalink)
prox600rider's Avatar
Current Sled(s): 2004 XCSP 500, 2004 Pro X2 600
Previous Sled(s): 07 IQ LX 600, 97 Indy 500, 87 Indy 340
Favorite Riding Area: Tug Hill
Riding Since: 1999
Quick question. How come if you think reeds are a waste of money why do all of your past sleds have them?
I feel sorry for those who don't drink. They wake up in the morning, knowing that's as good as they're gonna feel all day. :beer_cheers:
Live to ride, Ride to live
prox600rider is offline   Reply With Quote
Old 11-29-2009, 09:43 PM   #9 (permalink)
kraven's Avatar
Riding Since: 1985
Talking
Quick question. How come if you think reeds are a waste of money why do all of your past sleds have them?[/b]
Guilty as charged,
In the never ending quest for a slight improvement and to still pass it off as stock.
As stated, there is a very slight improvement in response, just not worth the $258
If money is no object and you're willing to accept minimal gain for $258, go for it.
Note the title BEST BANG FOR THE BUCK AND FREE MODS
Old 12-07-2009, 08:01 PM   #10 (permalink)
raysxc700's Avatar
Riding Since: 1997
t-stat removal can this be done on my 02 800 144
1997 xc 700
