TECH TIPS FOR EDGE 800 - Page 6 - HCS Snowmobile Forums
Old 03-09-2019, 12:31 AM   #51 (permalink)
Lexuslover's Avatar
Current Sled(s): 2012 Switchback Pro R 800
Previous Sled(s): 2001 800XC 1999 XLTSP
IIRC that airbox is riveted on. If you ruin it, there is no way to get one from Polaris anymore. It is a dumb way to put an airbox on. When i had that sled i wondered the same thing. Possibly remove the gas tank and see if you can get in from that way.
you are better off starting a new thread in the polaris xc section as you will get a lot more help
Lexuslover is offline   Reply With Quote
Old 03-09-2019, 12:45 AM   #52 (permalink)
Current Sled(s): 2019 xc indy 840
Previous Sled(s): 2015 prox 17 prox 17 xcr 10 xp 09 nytro 06 apex 05 f7 03 f7
Favorite Riding Area: Tug hill- old forge
Unless the previous owner got the length wrong also on bolt it should not bottom out. So the few I’ve had to extract came out east with a reverse drill bit. Sun them right out. If it’s mocktite holding it maybe a lil heat to soften it up.
Lid2 is offline   Reply With Quote
Old 03-09-2019, 09:02 AM   #53 (permalink)
patrioticinnovations's Avatar
Previous Sled(s): 2003 XCR 1100, 2000 XCR 800 turbo, 2005 Redline Revolt 800.
19-20 Mileage: 505 so far
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
Originally Posted by kab365gtb4 View Post
I have a 2001 POLARIS 800 xc sp, what's the best way to remove the darn AIRBOX,to replace the secondary jack shaft,i having some difficultly in this matter man!...is there a EASY way to remove brake disc,& jackshaft, ...i have the chaincase opened up the disc brake top end apart,secondary clutch off,because the guy before me had a #3 or #5 grade bolt installed(and i snapped it torqueing it at 15 lbs.). .... Any tips greatly honored.
No need to remove anything.
If end of bolt is near end of jackshaft, just saw or cut a slot into end of jackshaft and broken bolt. Then use a screwdriver (or hammer driver) to unscrew it. Slot in end of jackshaft doesn't hurt anything and will be there for the next bolt you break off. BTW, there is very little need for a strong bolt in that location if you properly float the secondary. Too simple.
Old 04-22-2019, 09:21 PM   #54 (permalink)
Newbie
2002 Polaris xcsp Edge:
Needed: ignition switch and key. This switch has a key position that lets you choose Premium if using that fuel.
Muffler/can for 800. Pipe from SLP is way too loud once you blow out the plastic stuffing.
iclement is offline   Reply With Quote
Old 04-23-2019, 09:37 AM   #55 (permalink)
I have a muffler can(mbrp trail) , y pipe and a stock pipe if you needed it. Sounds nice only hase 50 miles on can bought in january
Neverfinished800 is offline   Reply With Quote
Old 05-25-2019, 06:47 PM   #56 (permalink)
Newbie
2002 Edge 800 xcsp:
1. Does the "Premium" ignition key position give you a significant/measurable performance boost?
2. How can I test this ignition setting on my machine?
3. How can I test the temperature sensor on the top of the engine?
4. Can I use this to hook it up to a temperature gauge?
4. Is there a Polaris temp gauge I can order?
5. Are the exhaust cans interchangeable between 600/700/800s? Or what is part # of 800 can?
Thanks!
