rear suspension - Page 2 - HCS Snowmobile Forums
Like Tree9Likes
Old 06-12-2019, 07:50 PM   #11 (permalink)
Favorite Riding Area: Ma.
18-19 Mileage not much
15-16 Mileage: Zero
Riding Since: 70 s
Originally Posted by polaris bob View Post
Break out the propane torch and heat the head of the bolt up while doing the alternating tighten loose and from side to side. I know I put those bolts back in with red loctite just so they won't come loose while riding and you need heat to loosen red loctite.
Never use red loctite on those bolts...bad enough using blue. I have never used loctite on any of those rail bolts. In fact i've brushed some grease on them and socked them down well.
Old 06-13-2019, 12:27 AM   #12 (permalink)
ZR 800 efi's Avatar
Current Sled(s): 2007 Dragon 700 ////05' switchback 600
Previous Sled(s): 03 zr 900/ 03 zr 800/99 mach z 800/03 vmax 600/95 vmax 500/
Favorite Riding Area: your sister
18-19 Mileage not enough
17-18 Mileage: not enough
16-17 Mileage: not enough
15-16 Mileage: not enough
Riding Since: 1990
Originally Posted by too slow View Post
Can you apply some heat on the frozen shaft bolt area with a propane torch....lock up the side well the bolt comes loose on, and then try shock hitting the wrench/socket on the frozen bolt with a hammer.
done all that minus the heat. i will definitely get the torch out next go round and try that.
'...it's gonna be alot of slow singin' and flower bringin' if my burglar alarm start ringin'---the dolly lama
ZR 800 efi is offline   Reply With Quote
Old 06-13-2019, 06:51 AM   #13 (permalink)
northstarrick's Avatar
pretty hard to beat the heat wrench. the other thing you can do is remove other cross shafts in the front area so you can spread the one rail a bit. use vise grips and hold the shaft. if the alum spacers need replacing? just grab that with the vise grip real tight. then use a air impact wrench. while a battery impacts are good. it no competition for a IR 1/2" titanium air impact. 600 ft. lbs of torque. if it won't move it will break it off.
ZR 800 efi likes this.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 06-13-2019, 08:37 AM   #14 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
Try some pb blaster or similar stuff on the joint as it cools if this doesn't work the first time...i've had pretty good luck with soaking the joint/bolt for a hr before trying again.
Old 06-13-2019, 08:51 AM   #15 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
I recently picked up a 24v kobalt cordless impact wrench at lower for $100 plus the buying a battery. That sucker will snap off those bolts id seized. I was really skeptical of those battery powered impact tools but now i'm a believer. The air tools are great more for the everyday shop guy that has to depend making a living off them, but for lighter duty, the occasional doit your seller, no hoses, no cords, you can't do much better.
ZR 800 efi and p51mstg like this.
