what tools are required to remove the jackshaft to replace bearings - Page 5 - HCS Snowmobile Forums
Like Tree30Likes
Old 06-11-2019, 11:56 AM   #41 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
Will these work ?
https://www.amazon.com/Grip-Super-Th.../dp/B001HZQW0Y
ZR 800 efi likes this.
PPP Charter Member #2
Old 06-11-2019, 12:25 PM   #42 (permalink)
ZR 800 efi's Avatar
Current Sled(s): 2007 Dragon 700 ////05' switchback 600
Previous Sled(s): 03 zr 900/ 03 zr 800/99 mach z 800/03 vmax 600/95 vmax 500/
Favorite Riding Area: your sister
18-19 Mileage not enough
17-18 Mileage: not enough
16-17 Mileage: not enough
15-16 Mileage: not enough
Riding Since: 1990
Originally Posted by cfm View Post
got a set brother.the front ones are the ones being a whore though.
'...it's gonna be alot of slow singin' and flower bringin' if my burglar alarm start ringin'---the dolly lama
ZR 800 efi is offline   Reply With Quote
Old 06-11-2019, 02:17 PM   #43 (permalink)
ivar's Avatar
Current Sled(s): 2019 SBA 850
pull out a track tensioner bolt on one side, put it in the front mount and tighten the lock nut against the tunnel. Then you should have a better chance at getting out the bolt on the other side.
2019 SBA 850,2015 600 Adventure (int'l)
09 Doo 1200 GTX, 02 XC800 / 00 XCR800 - Pro-X rear skid, 99 XC700SP
RIP: 800SBA, 02 XC800, 99 SKS700, 97 XLT SKS
ivar is offline   Reply With Quote
Old 06-11-2019, 02:44 PM   #44 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
got the rear bolts out , had the other one that wouldn't start out 50 percent or so , finished removing the other , and now the 1 cunt holding me up is 50 percent out and for some reason im having a hell of a time lining up the other hole to try retightening again.
shits irritating lol.any other tricks?
Old 06-11-2019, 03:56 PM   #45 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
nvm , got em.
took the tension off the springs.those fuckers got some tension on em lol.when the block came out she almost got my finger. still got the old reflexs.
Old 06-12-2019, 12:55 PM   #46 (permalink)
Member
Current Sled(s): 2004 XC500SP, 2002 Polaris Classic 600
Previous Sled(s): 1990 Indy Trail, 1976 ColtSS, 1970 Charger 398
Riding Since: 1973
I went to a Polaris dealer and asked them to press off the bearing on the jackshaft and press a new one on. The service guy gave me a funny look and said that as long as it spins okay to leave it alone. He said they avoid replacing those until they fail.
They lost me as a customer with that comment - what a stupid thing to say. Anyway, I was mad enough that I went home, got my angle grinder out and cut the bearing off without damaging the shaft. I then tapped the new bearing on straight. Once even with the shaft, I used a 1 inch ID pipe and a hammer to pound it all the way home.
Not difficult at all, problem solved, and I'll probably never have to do that to that sled again (hopefully, assuming I sell it before it needs another one).
I once lost an entire season due to a seized jackshaft bearing and will never do that again. IMO, I don't care if it spins freely - if I have the thing apart, and it's got 4-5,000 miles on the bearing (which that one did), then it's going to be replaced, period. The All Balls kit is so cheap that it doesn't make sense not to do it.
Just make sure to keep the bearings on the clutch side greased, that's something easily overlooked.
p51mstg is offline   Reply With Quote
Old 06-12-2019, 05:11 PM   #47 (permalink)
Favorite Riding Area: Ma.
18-19 Mileage not much
15-16 Mileage: Zero
Riding Since: 70 s
Its basically the same our service manager says about the jackshaft bearing...as long as it spins freely and not rough, its ok, just be sure to keep it greased. This guy is one of the best poo techs around the area and now owns the business. Personally i've never replaced them on any of my own sleds. Had nearly 9k miles on my other 05 600, that bearing is still like new. I've always pumped a shot of low temp grease in it after every big ride. Hey if you feel that bearing isn't good or just time to replace it for peace of mind...its ok to.
