Inner Bogie Wheel Solution? - HCS Snowmobile Forums
Pro-X (2001-2004) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-14-2019, 12:11 PM   #1 (permalink)
jeff_g's Avatar
Current Sled(s): 03 ProX 700 136"
Favorite Riding Area: North Shore or Burnett County
Default Inner Bogie Wheel Solution?
I know this has been a big issue and I have to assume someone has a alternative to $130 for bogie wheels that won't last very long.
I don't have it apart yet but not only are the wheels really worn but they have a ton of play so I'm afraid there going to grenade in the skid.
Ride Right, Way Right in the Corners!
jeff_g is online now   Reply With Quote
Old 10-14-2019, 12:21 PM   #2 (permalink)
p51mstg's Avatar
Current Sled(s): 2004 XC500SP, 2002 Polaris Classic 600
Previous Sled(s): 1990 Indy Trail, 1976 ColtSS, 1970 Charger 398
Favorite Riding Area: Bowstring, Bigfork, Marcell
Riding Since: 1973
Do you need the entire wheel or just the $5 bearing?
I've never seen an idler wheel actually wear out, but have replaced a lot of bearings.
p51mstg is offline   Reply With Quote
Old 10-14-2019, 12:54 PM   #3 (permalink)
jeff_g's Avatar
I assume everything. The wheels are definitely junk. They wobble bad so I'm sure the bearing and maybe even the shaft is bad.
The wheels are plastic and wear out almost immediately after replacing them, so in my other sled I don't even replace them. But these are really bad.
Bad design.
Old 10-14-2019, 01:06 PM   #4 (permalink)
jeff_g's Avatar
I may have answered my own question but open to other ideas as well.
Name:	10-14-2019 11-02-57 AM.jpg
Old 10-16-2019, 01:45 PM   #5 (permalink)
Current Sled(s): 17 rush prox
Previous Sled(s): xlt ultra xcr 800 04prox
Riding Since: ween
as i remember correctly running a slightly smaller diameter wheel fixed the problem forever as far as the rubber consumption bearings are always a problem if you do a tread search it should be on here 8-10 years ago
trottlejo is offline   Reply With Quote
Old 10-21-2019, 02:53 PM   #6 (permalink)
1995xcr600's Avatar
I ran a set of Doo wheels and bearings when I had mine. Cant find what the part# was. I got them from a buddy who said they were off either a SC4 & 5 XP 440. These wheels are 141mm where the stock ones on my 03 ProX 600 were 142.748mm (5.62")
1995xcr600 is offline   Reply With Quote
Old 10-21-2019, 10:21 PM   #7 (permalink)
AMPro-x's Avatar
Current Sled(s): 16 SKS 155, ProX2R mod thing
Previous Sled(s): Boa Ski, Scorp, MotoSki, Sno Jet, Lots o Poo
Favorite Riding Area: You got snow?
19-20 Mileage: Bring it
18-19 Mileage: Lots
17-18 Mileage: Better
16-17 Mileage: Not enough
Age: ??
Riding Since: 1969
Press the spacers out.
Get two wheels from an old wedge suspension, they are slightly smaller.
Drill the hole for bolt removal.
Press in the spacers.
Never fix again.
AMPro-x is offline   Reply With Quote
Old 10-25-2019, 11:15 AM   #8 (permalink)
jeff_g's Avatar
Never fix again.
That makes alot of sense and I have a bunch of old wheels. Unfortunately too late as I already ordered and installed the ones from Dennis Kirk.
Also, the shaft was very worn. And the back up skid I have I already took the shaft out of that because apparently my other sled had the same problem at one point.
So I bought two shafts, one for a back up.
Thanks all.
