Gearing/traction/clutching options 04 pro x2 600 - HCS Snowmobile Forums
Pro-X (2001-2004) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree2Likes
Old 04-17-2019, 11:33 AM   #1 (permalink)
Xx08BRAAAPPP22xX's Avatar
Current Sled(s): 04 Pro-X2 600
Previous Sled(s): 01Edgex 600, 04 pro-x 600, 95 XCR 600
Favorite Riding Area: Lewis County, N.Y
18-19 Mileage 0, No sled
17-18 Mileage: 507
16-17 Mileage: 500
15-16 Mileage: 0, No Sled
Riding Since: 2004
Default Gearing/traction/clutching options 04 pro x2 600
Looking for some gearing options to follow my clutching on my pro x2 600 along with how many studs I should add to my track. Clutching is as follows: 150/310 venom blue primary spring with 10-60 weights, stock 58-42.36 secondary helix with red/blue secondary spring. Wondering if I should try for 22/40 gearing as I’ve seen I here a lot of people liked the gearing set up. Also have a 1 1/2” track, looking to see how many studs I should put in and the size of stud to use. The sled seems to pull decent but I’m wondering if gearing may help more especially with studs being added to the track. I’m 205lbs in my gear. Thanks in advanced guys!
Xx08BRAAAPPP22xX is offline   Reply With Quote
Old 04-19-2019, 04:48 PM   #2 (permalink)
Favorite Riding Area: Ma.
18-19 Mileage not much
15-16 Mileage: Zero
Riding Since: 70 s
22/40 sprockets works well in most conditions for really aggressive riding. Depending on the stud pattern, at least 120 in the middle belt. 144 is as much as i'd go. This works well with the rest of those components you have, other than running a team tied clutch
Old 04-21-2019, 11:15 AM   #3 (permalink)
ZR 800 efi's Avatar
Current Sled(s): 2007 Dragon 700 ////05' switchback 600
Previous Sled(s): 03 zr 900/ 03 zr 800/99 mach z 800/03 vmax 600/95 vmax 500/
Favorite Riding Area: your sister
18-19 Mileage not enough
17-18 Mileage: not enough
16-17 Mileage: not enough
15-16 Mileage: not enough
Riding Since: 1990
if you seldom hold your sled open any further then 1000 ft, my xc 6 with the 1 1/4 really liked 21/41.it pulled harder then the 22-40 and seemed to top out close to the same on 1000.
my xc liked the 62s better then 60s.your spring is a solid choice, i liked 165/310, but some say its too much engagement.
'...it's gonna be alot of slow singin' and flower bringin' if my burglar alarm start ringin'---the dolly lama
ZR 800 efi is online now   Reply With Quote
Old 04-21-2019, 12:16 PM   #4 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
I found 62 weights with the team blue 150/310 spring worked well in 1000' also using the stock tss-98 driven and 23/40 gearing on the xc, but if you ran over 1/2 mile the rpm would drop between 7700-7800. Speedo showed a bit over 105 mph. We were running on a large snow packed bay at lac st. jean quebec. Must of been at least -10 F that evening.
Imo, 60 weights work better when on trails.
Old 04-21-2019, 01:01 PM   #5 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
21/42 in my rmk.its NR according to the polaris chart, but it sure made that 144 into a hauler on 1000.If the studs can hook and you want a short blast acceleration, that gearing abesolutely kicks ass.its a tight squeeze to get on though.
I liked it so much im gearing my switchback 6 i just picked up the same. its got 22/40 stock, my rmk was basically the same sled so i cant see why it wont rock in this thing.(21/42)
Old 04-21-2019, 01:14 PM   #6 (permalink)
17-18 Mileage: 507
16-17 Mileage: 500
Riding Since: 2004
Too slow, I’m probably looking at a different track, I noticed the other day I have a few lugs torn. Maybe going with the 1.25” kimpex shotgun track. That may help with the weight compared to the 1.50” I have on the sled now? I tried 23/40 gear and wasn’t really that impressed I guess. So I figured I’d try the 22/40 gear for that extra snap and what not. My clutching seems to be about where it needs to be I feel and what most others run and like. Is there anything else you’d recommend? Thanks.
Old 04-21-2019, 01:22 PM   #7 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
1.95 to 1 (21/41).you'll like it.
Old 04-21-2019, 02:29 PM   #8 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
As for kimpex products, i'm not impressed...lets just leave it at that. We ran 1.25'' predator camoplast tracks in the past on older 600 xc's, their a good bang for the buck. 120-144 studs and good to go. A 23/40 was perfect when riding up in quebec...22/40 works much better for the tight trails here in ma. Only improvement i though was bigger than anything i did in the past was going to a team tied clutch. The acceleration out of the hole and off slow corners is amazing compared to the tss-98 team roller. Biggest issue was dialing it in...some of the clutching specs. for the tied were listed for another planet. Wear on the tied clutch appears better than the stock team roller.
Old 04-21-2019, 02:34 PM   #9 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
That ratio is more for the drag racer, its harder on parts. I use run that on my old 440's that were modded. After 900 mile aggressive trail ride, my clutches were worn out, and the motor needed pistons and rings.
Old 04-21-2019, 03:12 PM   #10 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
don't be negative bro lol
Similar Threads
Primary Clutch AnthonyD Indy (Pro-Ride Chassis) 6 01-29-2019 02:10 PM
SKS 146 Track options xc8rider Switchback Assault/SKS/RMK (AXYS Platform) 4 04-07-2017 08:50 AM
2018 Specs, Changes, Features ExcursionPSD Rush/Switchback (AXYS Platform) 43 04-06-2017 10:01 PM
Indy600 to 660 bigbore CFI?? Owners? racerdave Indy (Pro-Ride Chassis) 42 02-18-2017 01:56 AM
Poo new race sled rear skid alsled General Discussion Forum 149 12-13-2016 12:49 PM
