Gearing/traction/clutching options 04 pro x2 600 - Page 2 - HCS Snowmobile Forums
Pro-X (2001-2004) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree2Likes
Old 04-23-2019, 07:40 AM   #11 (permalink)
northstarrick's Avatar
we are big fans of gearing lower rather than higher. just get your clutching right. to where the power is.( the right wot rpm) and a slight under rev will always be better than over rev. if out of the motors power band you will hit a flat spot. if under revving it will pull with no flat spot.
i've said this before. get your gearing and jetting right first. than clutching will be much easier.
too slow likes this.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
northstarrick is online now   Reply With Quote
Old 05-16-2019, 02:57 AM   #12 (permalink)
ZR 800 efi's Avatar
Current Sled(s): 2007 Dragon 700 ////05' switchback 600
Previous Sled(s): 03 zr 900/ 03 zr 800/99 mach z 800/03 vmax 600/95 vmax 500/
Favorite Riding Area: your sister
18-19 Mileage not enough
17-18 Mileage: not enough
16-17 Mileage: not enough
15-16 Mileage: not enough
Riding Since: 1990
agree with rick.been my findings as well. biggest gain i got out of an edge was a gearing change.if at sea level , my rmk 6 ves liked 400 mains for jetting, 2 to 1 ratio or very close to it(1.95 worked well too).
all sleds are geared too tall imo. Every sled i own i always gear down.way more fun and the powers more useable everywhere except wide open down a lake.
'...it's gonna be alot of slow singin' and flower bringin' if my burglar alarm start ringin'---the dolly lama
ZR 800 efi is offline   Reply With Quote
Old 05-17-2019, 11:51 AM   #13 (permalink)
Favorite Riding Area: Ma.
18-19 Mileage not much
15-16 Mileage: Zero
Riding Since: 70 s
Gearing is all relevant for optimum performance, just depends what the sled will be run for. You not going to run 2-1 ratio while trail riding a stock 8k rpm sled on the wide open trails or lake crossings quebec has.
too slow is online now   Reply With Quote
Old 05-17-2019, 03:26 PM   #14 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
nope. true.i should specify that's for tight wood roads and short (660-1000ft) passes and that's what I liked that ratio for.
1.8 or 1.7 is fine if its neverending ponds wide open or driving on trails 50 feet wide and flat as a board.
personally even then the tallest id personally run is 1.8 to 1 on a 144 track.
Old 05-17-2019, 03:55 PM   #15 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
I ran 22/40 on my 121'' xc 600 in quebec....most of the time on their trans quebec trails the sled felt flat and out of gear once you got into the upper 80's...it needed more of a load put on the motor. Found 23/40 nearly perfect up there on that sled, pulled really hard to 105 mph. I ran 22/40 down here for multiple seasons which work fine on our tight trails. I admit i can claim squat if the sled turns a 144 track.
Old Yesterday, 08:22 PM   #16 (permalink)
ZR 800 efi's Avatar
Riding Since: 1990
if holding open longer then 1000 feet, 2 to 1s too short. at that distance or less though, the 600 edge in a 144 is near perfect gearing from my experience.very competitive with sleds it shouldn't have been on 660-1000, particularly if they struggle at all off the line.
Old Today, 08:16 AM   #17 (permalink)
15-16 Mileage: Zero
Riding Since: 70 s
Straights on some of quebec's trails seem to go forever.....dreamed at night setting shop up there labeling the ''shop piston city.'' Anything under 1000' would be considered a short drag race.
Similar Threads
Primary Clutch AnthonyD Indy (Pro-Ride Chassis) 6 01-29-2019 02:10 PM
SKS 146 Track options xc8rider Switchback Assault/SKS/RMK (AXYS Platform) 4 04-07-2017 08:50 AM
2018 Specs, Changes, Features ExcursionPSD Rush/Switchback (AXYS Platform) 43 04-06-2017 10:01 PM
Indy600 to 660 bigbore CFI?? Owners? racerdave Indy (Pro-Ride Chassis) 42 02-18-2017 01:56 AM
Poo new race sled rear skid alsled General Discussion Forum 149 12-13-2016 12:49 PM
