brake switch replacement - HCS Snowmobile Forums
Pro-X (2001-2004) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
  • 1 Post By jeff_g
Old 01-03-2019, 01:42 AM   #1 (permalink)
stgdz's Avatar
Current Sled(s): 2000 800 xcr, 2001 edge x, 2003 pro xr 700
Previous Sled(s): 92 xcr
19-20 Mileage: 845
18-19 Mileage: 1600
17-18 Mileage: 1700
16-17 Mileage: 360
Riding Since: 91
Default brake switch replacement
Anyone know what the thread pitch is on the brake light switch? I heard you can use a motorcycle switch.
stgdz is offline   Reply With Quote
Old 01-03-2019, 09:15 AM   #2 (permalink)
BILTIT's Avatar
Current Sled(s): 2004 Pro-XR 910cc 121x1.75"
Previous Sled(s): 2011 pro rmk 800
Favorite Riding Area: Valemount BC
Riding Since: 2010
Yes i just replaced mine yesterday. I will try and find the part number.
Sent from my SM-A530W using Tapatalk
Derek B.
2000 440 XC SP (EDGE) 136''
2003 800 RMK vertical edge 162''
2004 910 Pro-XR 121x1.75 BC-Studded
2011 Pro-RMK LR800 PAR 13.6, KMOD/Raptors/37" arms/3"PC/Titanium can
BILTIT is online now   Reply With Quote
Old 01-03-2019, 09:23 AM   #3 (permalink)
BILTIT's Avatar
Riding Since: 2010
This is it here:
You also need the 2 sealing washers from polaris. I used 1 or 2 of the aluminum crush washers that came with the switch too.
Derek B.
Old 01-03-2019, 09:36 AM   #4 (permalink)
Member
Current Sled(s): 02 pro-x 440
Riding Since: 98
I think all 2001-2004 pro-x sleds used a unique pressure brake switch that is a one off part because it is incorporated into the banjo bolt on the master cylinder.
I just went through this with my 02 pro-x 440. The switch went bad and is no longer made by polaris. I was unable to find a used one so I ended up installing a brake lever/master cylinder from an IQR. Bolted right up to the handle bars and brake line. Just had to wire up the switch since the factory connectors are different. I was able to find an IQR brake lever/master cylinder with switch off ebay for $65 shipped. A slightly more expensive route, but I never have to worry about the switch failing and not being able to find a replacement. The IQR uses the common mechanical brake switch found on pretty much all edge to current Polaris sleds.
I havent ridden the sled yet so I cant verify how it works with the pro-x caliper, but the caliper part# from the pro-x cross references to the caliper on an IQR so Id imagine it will work same as before.
pooski123 is offline   Reply With Quote
Old 01-03-2019, 09:39 AM   #5 (permalink)
Member
Riding Since: 98
Originally Posted by BILTIT View Post
This is it here:
Wish I knew this before swapping the brake lever/master out lol
Old 10-29-2019, 11:38 AM   #6 (permalink)
jeff_g's Avatar
Current Sled(s): 03 ProX 700 136"
Favorite Riding Area: North Shore or Burnett County
YAAAAAAY!
Thanks for this. I got a bad one on one of my three Prox's. I'm selling one sled and my kid wants to swap out the bad brake switch from his sled to the one I'm selling.
Trying to use this as a teachable moment. I would rather spend $20 than stiff a guy.....
BILTIT likes this.
Ride Right, Way Right in the Corners!
jeff_g is online now   Reply With Quote
Similar Threads
New Brake Cylinder + High/Lo switch syrupboy XC 2 08-26-2018 08:54 AM
Brake switch check engine link Fstclassic Polaris General Discussion 0 02-11-2018 02:56 PM
Who sells TD 3 stage replacement harness / switch in USA? smokinfour Turbo 4 Stroke 3 01-27-2018 09:39 AM
Brake light switch sensitivity? Crnr2Crnr Sno Pro Chassis Pre-2012 6 01-13-2018 10:32 PM
Sled not starting.....Brake switch ate through F8HO F series (07- ) 3 12-14-2017 10:18 AM
