Project REDLINE - Page 2 - HCS Snowmobile Forums
Specialty Sleds Blade, Redline, CMX, Tison, SnoHawk, etc.
Like Tree47Likes
Old 01-03-2012, 01:20 AM   #11 (permalink)
Litre1000's Avatar
Current Sled(s): Nytro Hillclimb Race,IQ600RR, REDLINE REVOLT
Previous Sled(s): 05 Vector, 03 PRO X 440, 09 Assault
Favorite Riding Area: Out West, N. Wisc, U.P.
Riding Since: 1977
Trying to order some UFOs for these 44mm racked Mikunis. The guy said he's not sure he's even seen anything like that before (44mm rack-setup).
ID:	520740   Click image for larger version
Litre1000 is offline   Reply With Quote
Old 01-03-2012, 06:08 PM   #12 (permalink)
sledhead800's Avatar
Current Sled(s): Blade HPO 800 Type ST
Previous Sled(s): Polaris, Skidoo, Kawaski
Favorite Riding Area: Vt, PA, NY, NH
The tube frame on a Redline is steel right?
sledhead800 is offline   Reply With Quote
Old 01-03-2012, 09:40 PM   #13 (permalink)
Litre1000's Avatar
Riding Since: 1977
Yep. Chro-moly steel. Same type used when building a dragster or funnycar.
ID:	520906   Click image for larger version
Old 01-03-2012, 10:02 PM   #14 (permalink)
That sled is built like a tank, you can smash trees down with it... can you post a pic of the clutch setup?
Old 01-03-2012, 10:06 PM   #15 (permalink)
Does it have a recoil or just E-start?
Old 01-04-2012, 12:05 AM   #16 (permalink)
Litre1000's Avatar
Riding Since: 1977
E-start only. The frame is very beefy. But I don't think it's over-done. The sled has a different tunnel structure than the sled in the poster that's been hanging on the wall in my shop since 2003. Here's some pics of the clutching.
ID:	520927   Click image for larger version
ID:	520928   Click image for larger version
ID:	520929   Click image for larger version
Old 01-04-2012, 12:13 AM   #17 (permalink)
Litre1000's Avatar
Riding Since: 1977
It has the Comet Pro clutch with 4 weights. Was told they are no longer in business. Was also told I'm wasting my time trying to use the stock expansion chamber. It will crack in half no matter what I do. So I will use some other pipe instead. I will keep the Bassani tailpipes. I was advised NOT to take the engine apart. I'll probably follow that advise. The electrical system has a myriad of problems. Not mine. But was told they will surface. Have lots to think about.
Old 01-04-2012, 01:56 AM   #18 (permalink)
Outlaw
MotoSno963's Avatar
Current Sled(s): 07 iqr 440
Previous Sled(s): 91 indy classic 500(00blackz28 owns now)
Riding Since: ....
i would trail ride it around ur area till all these electrical problems and such arise..then have it like a trophy
[SIGPIC][/SIGPIC]
O.E.F vet(Iraq sep.07-nov.08) 06-14.
09 Yamaha YZ250F STOLEN as of 27 April 2012
07 IQR 727
MotoSno963 is offline   Reply With Quote
Old 01-04-2012, 02:00 AM   #19 (permalink)
Is the track driven off the secondary's drive shaft ? I don't see a chaincase.
Alias is offline   Reply With Quote
Old 01-04-2012, 09:04 AM   #20 (permalink)
Litre1000's Avatar
Riding Since: 1977
The drive train is similar to a Blade and/or Diamond drive. There's a set of helical-cut gears bathed in gear oil. Nobody I've yet talked to seems to know who made it. The electrical system is from France or Italy. I don't remember because it's not important. Was told the company refuses to support it and any replacements I may find on ebay are no better than what comes on the sled. Money would be better spent on retro-fitting some other, more readily available system. Thinking about just removing everything and swapping it out for an OEM system. But don't hold me to that!
ID:	520967   Click image for larger version
