RX Warrior carb issues - HCS Snowmobile Forums
Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 01-20-2020, 04:22 PM   #1 (permalink)
Member
Current Sled(s): RX Warrior
Default RX Warrior carb issues
Don't know if anyone else had this problem, when i stop the sled it stays at a high idle for a while (around 2500) before it goes into a normal idle. If i shut the ignition off and turn it right back on it goes to idle. Throttle and choke cables seem to be adjusted right, idle screw has to be set at a low idle otherwise the high idle goes to 3500. Not sure if this is a carb issue or electrical.
Any help would be appreciated.
Thanks
jnails55 is offline   Reply With Quote
Old 01-20-2020, 05:52 PM   #2 (permalink)
Member
Make sure your carb boots aren't torn. Any vaccuum leaks will cause your idle to be high.
Shutting it off and starting it again might be "resealing the torn rubber until it pulls apart again. Make sure all your clamps are on the boots as well.
Gotrek is offline   Reply With Quote
Old 01-20-2020, 07:23 PM   #3 (permalink)
Michigan Brian's Avatar
Current Sled(s): '03 Yamaha RX-1 '16 Renegade Adrenaline 900
Previous Sled(s): 03 REV 800 1997 Yamaha Venture 2 up
Favorite Riding Area: Manton, Mich
Riding Since: 1938
agree with Gotrek
While idling, Take some carb cleaner with the straw on the can and carefully spray a little around the boots and other areas for suspected vac leaks. If the idle changes, you found your leak
Michigan Brian is offline   Reply With Quote
Old 01-20-2020, 08:45 PM   #4 (permalink)
Member
Thanks, I'll try to see if there are leaks
Old 01-21-2020, 11:15 AM   #5 (permalink)
Member
Propane might work better, If the tear is small carb cleaner might not make it in. But propane will. The idle will rise if propane gets sucked in. Just go around the boots with an unlit torch.
Old 01-22-2020, 08:21 AM   #6 (permalink)
Member
I took the airbox off and a couple of the boots look like crap, ordered four new ones. Looks like the boots are sealed with something in the airbox, will the new ones just seal tight enough or do i have to seal them in.
Old 01-22-2020, 08:49 AM   #7 (permalink)
Riding Since: 1938
Did you test for leaks first like we suggested?
Old 01-22-2020, 11:04 AM   #8 (permalink)
Member
Did you test if they were actually leaking first?
I don't believe there is any sealant on them from the factory but someone might of had a leak (same one you are chasing) and tried to fix it with silicon caulk or something like that. Do you have a picture of it?
All I do is spray some silicon spray to lube up the boots prior to install. I also warm them up with a heat gun / hair dryer.
It's a bit of a pain to get the airbox/boots on and off
Read this that's kind of how you do it
https://ty4stroke.com/threads/2003-r...lation.132324/
Old 01-23-2020, 07:03 AM   #9 (permalink)
Member
I did test with carb cleaner first but didn't notice much difference but looked at the boots and noticed that two of then looked distorted from bottom of clamp slipping towards airbox. I do lube the boots with WD40 before i put then on the carbs. Good info on how to install on the other thread, hard to see where the bottom of the clamps are on the middle two carbs. Thanks
Old 01-23-2020, 07:06 AM   #10 (permalink)
Member
I'll get a picture of it today
